Lights turning on by theirselves
I was playing with a new scene I have setup in my bathroom and was trying to see if the status updated on my virtual 3-way. The scene is controlled by a KPL button, I did not include the non-load 3-way switch so it did not update. I turned the scene on and off a few times and the 3-way on and off a few times then 15 seconds later the light opened by itself.
I believe I read somewhere that the ISY is always a controller on any scenes created on it. Would that behavior occur because the ISY isn't getting confirmation of the light turned on and replaying the command a few seconds later ?
  • 3 weeks later...
Hello,
Programs were not the culprit, since I only had one to Turn on and off outside lights based on time.
Now, I repeated the problem and reviewing the LOGS on the ISY shows ELK as being responsible ?!
At the time I didn't have any lighting info imported into my ELK.
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:14 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:14 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:14 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:14 System Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:16 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:16 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:17 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:17 System Log
Stairs - Bottom Off 0 Sun 2011/08/07 16:44:21 ELK Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:22 System Log
Stairs - Top Off 0 Sun 2011/08/07 16:44:23 ELK Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:23 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:26 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:26 System Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:26 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:26 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:27 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:27 System Log
Stairs - Bottom Off 0 Sun 2011/08/07 16:44:33 ELK Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:44:34 System Log
Stairs - Top Off 0 Sun 2011/08/07 16:44:35 ELK Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:35 System Log
Stairs - Bottom Status 100% Sun 2011/08/07 16:44:38 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:44:38 System Log
Stairs - Top Off 0 Sun 2011/08/07 16:44:41 ELK Log
Stairs - Top Status 0% Sun 2011/08/07 16:44:41 System Log
Stairs - Top Status 100% Sun 2011/08/07 16:50:09 System Log
Stairs - Bottom Status 0% Sun 2011/08/07 16:50:13 System Log
Stairs - Top Status 0% Sun 2011/08/07 16:50:13 System Log
But no lighting data was configured on the ELK, but maybe this is the problem.
Anyway, I uploaded the ELK Export from ISY this weekend, so I shouldn't see my lights doing this anymore if it was the issue.
I will play with the lights tonight and report back with my findings.
Just out of curiosity, how did this caused lights to turn on and off like this?
Ok, so when the M1XEP is configured in ISY, the ISY will send lighting status information to the ELK?
