The 2.6.1 beta release is now available. If interested, please send an email to support@universal-devices.com
Fixes
- Workaround for KPLs (1.5+) showing as LampLinc BIPHY
- Power outage issue: ISY will use a new IP address if one is issued any time after the boot up. Previously, ISY would give up (slow routers) after 3 retries
- Java Exception when removing a device the table was not updated correctly
- Daylight Saving flag was always set to true when adjusting the time to the computers clock
- The slider for a relay in a scene was not being updated back to its original state if the operation was canceled (neither on nor off)
- Clicking to the left/right of the slider or using the left/right arrow keys were ignored
- Enable Internet Access: null now shows a failure message instead
- No replacement menu available for RemoteLincs
- 'Program Run/Program Run Else' failed if a program tried to run itself
- SocketTimeout exception when loading a large number of programs
- Explicit Query no longer clears the status of non-load devices (such as KPL secondary buttons, RL buttons, IRLinc buttons, etc.)
Enhancements
UDMobile Support
- HTTPS Support
- HTTP and HTTPS ports can now be changed using the CWP Shell Command
- HTTP default port is now 80
- HTTPS default port is now 443
- Simple HTML page both in HTTP/HTTPS which can be used by Mobile devices ... no more Java
- Certificate issues remain to be resolved
X10
- Added support for sending/testing for X10 unit code separate from X10 command code and vice-versa
Programming
- Added Fade Up/Down/Stop to programs (both conditions and actions)
- Can use a program to set other programs to 'Run/Not Run At Reboot' (for power outage recovery)
- Specify from 0-100% for dimmable devices (100% shows as 'On', 0% shows as 'Off')
GUI
- Changed Reset History to Clear Log
- In case of non-Linux clients, one can now selectively decide to save the log (CSV) or view it in Excel
- Applied Locally is now on the main view as well
- AutoUpdate no longer pops up whenever the Admin Console is started. Rather - and as a compromise - there will be a reminder (in text) at the top right corder of the Status bar
- Progress bar when programs are loading
General
- In the shell, configure default number of insteon command retries
- Automatic increase in insteon command retries for long running commands (eg. restore devices)
- Automatically reorganize links for KeypadLinc LED backlight (no need to add them to scenes in specific order)
INSTEON
- Added support for Companion 2 Wire devices (2474S/D)
- Added support for KPL Countdown Timers (2484DWH8)
- Added support for KPL (v2) sub-buttons controlling the on-level/ramp rate for the local load
- Added support for IRLinc
- Added programming features for thermostats
- Add New INSTEON device now supports providing the type of device to be added
SHN
- Added support for EZSwitch30 (minimal testing)
- Added support for EZIO4O (minimal testing)
- Added support for EZIO6I (minimal testing)
- Added support for EZSnSRF
- Added support for EZX10RF (untested)
  • 3 weeks later...
Hi Mark,
A couple of more days ... this is going to be a very large release with many added features (mobile support).
//clap...rubbing hands together//
Now that list is getting good...I am excited for 2.7 to come. :wink:
That's ok; I screwed up my PC anyways. :roll:
It had some .net issue on my machine and Microsoft's forum said to remove then reinstall. I did the remove and now can't reinstall it no matter what I try (reg edits, safe mode attempts, system restores, etc), its starting to look like reinstalling the OS is the fix, so I have gotten myself a project. With java using .net I can't get into my ISY anyways. :cry:
Mark,
This is not good! Good luck ...
Hi Michel or Chris,
Will this next drop have an 'x' or some other indication in the program tree when a program is disabled. Didn't see it in the enhancement list, but I can still hope!
I guess it's too soon for that Program Summary Filter. :lol:
jgraziano,
Unfortunately I don't think we'll have enough time to do both. We shall see ...
Hi Michel or Chris,
