Back to one
So after some time using and getting used to my ISY/Insteon setup, I've decided that I would like to rebuild from the ground up.
As I've been using it, I've found better ways to do things both through experimentation and constant perusal of this forum.
As my system is still relatively simple, my question is this:
What would be the best method for resetting everything to 'factory default' to enable rebuilding from scratch?
In my particular scenario, this would be much faster and tidier than rewriting all of the existing code.
Thanks in advance,
Steigs
If you're rebuilding from the ground up you most likely will not need to reset your individual devices manually unless you run in to a problem.
When you re-add the devices to the ISY, select the option that removes existing links. Chances are unless you were doing something really out of the ordinary before, this will be all you need as far as individual devices go. Of course, be sure to check the ramp rates, on levels, etc when you re-add the devices to make sure they match how you now intend for them to behave.
