Java2 vs. current Java
I was wondering if you need to have Java2 for admin console to work or can you use the most current, seems like admin hangs up on load up screen saying Java 2+ required, I just updated to version 27 both 32 and 64 bit and cant log on to update. I'm using beta 3.1.6. been doing some computer clean up.
robandcathy,
Please upgrade to 3.1.9 as soon as you can. 3.1.6 had some bugs including a corrupted backup ... so, if you have a backup from 3.1.6, it's corrupted.
The reason you see those errors is because Java has not been configured for your browser. You may want to use the application:
http://www.universal-devices.com/99i/admin.jnlp
