What's wrong with this program
What is wrong with this program? The Rear BR can light comes on if the conditions are affirmed. However, it does not turn off.
Time is Sunset - 15 minutes
And (
Status 'Fam Rm Key - Ceiling' is Off
And Status 'Fam Rm Table' is Off
And Status 'Kitchen Ceiling Keypad - A' is Off
And Status 'Rear Br Can' < 34%
Set 'Rear Br Can' 70%
Wait 1 hour and 40 minutes
Set 'Rear Br Can' Off
The first "then" statement changes the Rear BR Can lights to 70%, which triggers an evaluation of the "if" condition, which is now false. This happens before the program "then" statement is completed, which means that the Rear BR Can lights are never turned off.
When you use the wait command then the next time the program runs it re-evaluates the if statement and it is false so it doesn't do the next part.
Instead of doing a wait you should call a different program and not have anything in the if and in the then column put your wait and the the light action.
