Mail Server Fail
Yesterday I was ableto send txt messages and Email for notifications. I tried to test the notifications tonight and got a mailer server failure - password not accepted.
I have the SMTP setting at Use Default.
Any suggestions?
Hi Michel
Now I'm getting "Mail server DNS error"
Help?
Hey Michel
No I'm not using default,SMTP is icloud and I am connected to the internet.
Thanks Tim
You might have to use your ISP's smtp server. Im on cox and that is who i use. Couldn't get gmail to work properly.
Hi Michel
I finally got the test to work.For some reason when I put a name in the "FROM" field it would not go through.However I still cannot
get it to notify me on the trigger of the program.It worked fine before on the default.
The test is working fine.?????
Thanks Tim
Hi Michel
Thanks for the update,it works on default any idea why it will not work with my server?
Thanks Tim
Hi Michel
my server is smtp.me.com It comes through when I test it but not when I run the "then" in the program.I took out the password port works on 25 or 587.???
Sorry for being a pain
Thanks Tim
  • 7 months later...
I can confirm that these settings do indeed work with iCloud and Verizon text messaging:
SMTP Server: smtp.mail.me.com
SMTP Port: 587
User ID: your-user-id@me.com
Password: (leave this blank)
Timeout: 1000
Use TLC: Unchecked
