Using ISY via network switch - shared with Sonos device
Hi,
Just wanted to confirm that it is ok to use the ISY (99ir) unit connected via a network switch.
I just installed a gigabit network switch. So, instead of plugging the network connection fromt the wall directly into the ISY unit I first plugged the connection into a 10/100/1000 switch and then from there connected it to the ISY device.
In addition, I plugged a Sonos ZP100 device to another port on the switch.
Just want to make sure everything is kosher with this kind of setup (from the perspective of the ISY unit).
Many thanks.
blartyo,
Yes, this configuration should work fine.
Hi,
Many thanks.
