dwiree Posted December 17, 2011 Posted December 17, 2011 Unable to link TriggerLinc 2421. Have ISY-99i w/PLM, Lamplink Dimmer Dual Band. Lamplink works fine. When adding Triggerlink manually, end up with error: Failed writing device link. FDoor-Opened [-200000/-51] Node not added - failed reading links (82 83 84 1) [-200000/-87] The triggerlink is about 5 ft away from the dualband device. Any ideas? Is there a list of error codes? Thanks
Michel Kohanim Posted December 18, 2011 Posted December 18, 2011 Hello dwiree, My recommendations are: 1. Please change the battery ... this is usually the one and only cause for not being able to add TLs 2. Make sure that your TL is in programming mode With kind regards, Michel
