Import existing SSL certificate
I have a web site, NAS, etc. I run from home, all using the same private key and SSL cert which I have. Is there a way to import an exsiting SSL cert and private key into the ISY-99i? I don't want to have to buy another cert for the same domain name, when I already have one...
Thanks Michael. I'm currently on the official 2.8 whatever it is.. but did download that newest beta, thinking about installing. I assume this would be the next best step?
without going into detail, what is\are the biggest changes between current official and that beta? I went over the release notes, but didn't see anything HUGE except for the interface changes\additions
or do you mean 2.8.16 and above? I have 2.8.16, and when I choose that option it says:
could not retrieve the private key. please redo CSR.
But I don't want to generate a private key, I want to use the one I already have with the cert that was generated for it.
I've upgraded to newest beta, still can't import my existing cert.
I've tried joining and creating a cert on that site, but it seems hodge podged together, and sits there spinning when I try to login, and the cert login page goes to a 'page cannot be found'....
I just want to use the cert I currently have. How can I do this? How can I import the private key and cert? Web? Java? Telnet? something?? I can't be the only one that has an existing cert they want to use.
Also, I cannot generate a self signed cert or request for a CA, as the cursor just sits there spinning, and it never goes anywhere...
well, no.. that's why I need a way to be able to import the private key as well. Is there a way to do this? backdoor even? seems silly if you couldn't..
  • 5 months later...
I need this ability as well. I have a wildcard cert for my domain and I'd like to import it. My Synology NAS allows this, you just specify the certificate and the private key and it's done. Is this possible for the ISY? If not, can this be implemented? I don't want to generate a new CSR when I have a perfectly fine wildcard cert that works....
