SPU Shell Command default setting
Could someone please advise the default setting for the 'SPU - Set Portal' command in the ISY Shell?
I have changed the URL for testing and would like to return to the default URL.
Can't seem to find any documentation regarding the default SPU setting. Thanks.
edit: Found 'DPU' will reset Portal URL to default setting.
Thanks, Michel.
I was indeed testing the Mobilinc portal and have returned SPU back to the default setting.
