Release 3.1.17 (RC) Is Now Available
I would define a new Program under 3.1.17 with the same statements. Sounds like that Program has lost the Sunday indication along the way.
Hi tunaman,
What's the schedule grace period? When you use precise times and, let's say ISY was busy at that moment (+grace period) and missed the schedule then the program will not run. So, the first thing I would suggest is to use From/To (increasing the grace period is global; using From/To is local to your program).
And, finally, is it possible that this program is inside a folder with condition?
Hey Michel
Grace period was set to 3 minutes -- I would think that would be enough time to clear any run stacks.
I have changed it if to use from/to logic, it now will from sunset -10 to sunset - 8 minutes.
It did run tonight. It has only failed to run on Sundays, so I guess we'll have to wait until Sunday to see if this works.
my log file is full of this please advise
thank you
Robert
Fri 2012/02/17 07:05:33 AM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 07:05:33 AM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 07:38:18 AM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 07:38:18 AM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 08:24:17 AM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 08:24:17 AM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 08:48:34 AM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 08:48:34 AM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 08:57:35 AM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 08:57:35 AM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 09:06:06 AM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 09:06:06 AM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 09:18:25 AM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 09:18:25 AM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 10:34:14 AM System -140000 datafeed.weatherbug.com
Fri 2012/02/17 03:09:15 PM System -140000 datafeed.weatherbug.com
Fri 2012/02/17 03:42:01 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 03:42:01 PM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 04:09:43 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 04:09:43 PM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 05:16:34 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 05:16:34 PM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 05:16:55 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 05:16:55 PM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 05:59:24 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 05:59:24 PM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 06:04:09 PM System -140005 CLI-WBug
Fri 2012/02/17 06:04:35 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 06:04:35 PM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 06:13:11 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 06:13:11 PM System -110012 /CONF/NET/0.RCT
Fri 2012/02/17 06:14:06 PM System -140000 datafeed.weatherbug.com
Fri 2012/02/17 06:19:18 PM System -110022 /CONF/NET/0.RCT
Fri 2012/02/17 06:19:18 PM System -110012 /CONF/NET/0.RCT
Hi there and thnak you but I am sorry to say there is no 0 id in network resources
Regards
Robert
Lee, Michel -- Just an update.
The program that was failing to run on Sunday's over the last 2 weeks did run tonight.
Just to recap --
I changed the program by checking all days individually.
I also changed the logic so that it runs in a 10 minute window rather than at a specific time.
Michel -- certainly not an imposition, glad to do it.
I'm assuming that you want to see if the global grace period is big enough to account for any processes trying to run -- so, should I leave the trigger in the if condition at 10 minutes, or, should I change that to be a specific time. I'm not sure I understand the relationship between the global grace period and the if condition.
If I set the global grace period to 10 minutes, and I set the program trigger time to "from sunset to sunset + 10 minutes", does that mean that the program could trigger any time between sunset to sunset + 20 minutes?
Hi tunaman!
Thanks so very much!
Specific time please.
Yes.
I'll change global grace period to 10 minutes, and set a specific time in the If statement.
Michel -- With the global grace period set to 10 minutes, and the if time set to a specific time, the program ran fine yesterday night (previously, it wasn't triggering on Sunday nights, even though the on days All was selected).
Will do.
Sent from my SAMSUNG-SGH-I727 using Tapatalk
