Active X
Out of the blue decide to check in and see what the latest beta is then tried to sign in to ISY gave credintals, then recieved message active x has been blocked by IE and would not let me install, ok being half the dummy I am I lowered all my security settings. Now I get option to install but when I click it nothing happens, now mind you I have had the ISY for 3 years and updated it often and played around in there quite a bit but never have I been locked out. Any suggestions? I assume its a update that was pushed to IE9 that caused this not sure how to get around it but just had a thought Ill try firefox :lol: yeah have same problem with firefox hangs up on page that says "PLEASE KEEP THIS WINDOW OPEN"
Edit: For some reason using IE9 64 bit worked fine, even though I have both versions of JAVA installed, also strange I have build 7 update 1 when on web site they are offering build 6 update 30, did they revert back to the older version because of problems?
