X-10 Motion Sensors Watchdog
These programs monitor EagleEye MS14A motion sensors and scream if any of the batteries go dead. It is assumed that at the time 'Setup' is run, nearby lights are off (which is assured in an 'All off' program triggered by Last Run Time for 'Setup').
'Notify' rings an X-10 buzzer and supposedly sends email. Unfortunately, I've never been able to get the email "notify" function to work...
I originally ran these programs at night within a 10 second timeframe, forcing lights on/off and monitoring the "darkness" signal from the motion sensors. But I later decided that if the light bulbs were dead, the motion sensors would be blamed for it, so I let Mama Nature handle the lighting instead.
If it were known from below, that the motion sensors were all functional, one could unleash a watchdog on the light bulbs...
Program Content for 'Setup'
Time is Sunrise - 1 hour
Run program '*Driveway sensor okay?' (Else Path)
Run program '*Sidewalk sensor okay?' (Else Path)
Run program '*Patio sensor okay?' (Else Path)
Run program '*Stairwell sensor okay?' (Else Path)
Run program '*LivingRoom sensor okay?' (Else Path)
Run program '*Door sensor okay?' //not installed yet so true
Assume the motion sensors don't work - if they are working, they will complain later...
Program Content for '*Stairwell sensor okay?'
X10 'C6/Off (11)' is Received //this is the "not dark" signal from C5
Stairwell motion sensor is working
Program Content for 'Check batteries!'
Time is Last Run Time for 'Setup' + 3 hours
And (
Program '*Driveway sensor okay?' is False
Or Program '*Sidewalk sensor okay?' is False
Or Program '*Patio sensor okay?' is False
Or Program '*Stairwell sensor okay?' is False
Or Program '*Door sensor okay?' is False
Or Program '*LivingRoom sensor okay?' is False
Run program 'Notify'
If any of the motion sensors are not working, raise a stink.
Program Content for 'Notify'
Send Notification to All
Send X10 'B6/On (3)' // ring the buzzer
