Bug Fixes and Enhancements in 3.2.6 (Official)
Release Date
- 2012.05.04
Known Issues
--None
Bug Fixes
-- ELK on UDAJAX
-- Open ADR 2.0: Randomization and Implicit Cancellations update (2)
Enhancements
-- HTTPS Performance improvements
Developers
-- VC# issue not populating type and other elements
UD AJAX
-- ELK not working properly for units with no ELK module installed
WSDK
-- None
Links
- URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.2.6
- Documentation:
-- WSDK Framework Development Guide
-- ELK Integration: WSDK Development Guide
-- Portal Integration Development Guide
-- Smart Grid/SEP Development Guide-- 994 Only
-- Zigbee Brultech Deveopment Guide -- 994Z Only
- UD AJAX (Open Source):
-- UD Ajax 3.2.6
Bug Fixes and Enhancements in 3.2.4
Release Date
- Tentative: 2012.04.10
Known Issues
--None
Bug Fixes
-- I2 commands not consistently used across devices
Enhancements
-- Dashbaord: Full support for Open ADR 2.0(a)
-- Dashboard: Event Viewer
Developers
-- None
UD AJAX
--Improved FanLinc Support
--Removed needless temperature controls on thermostat sub nodes
WSDK
-- None
Links
- URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.2.4
- Documentation:
-- UD Ajax 3.2.4
Bug Fixes and Enhancements in 3.2.3
Release Date
- Tentative: 2012.04.05
Known Issues
--None
Bug Fixes
-- Restoring ISY with different network configuration replaces current http/https ports with those of the backup
-- Irrigation: Cycle complete/reset vars now causes re-evaluation instead of waiting for the next polling time
-- MorningLinc not being able to be added to scenes
-- SwitchLinc timer not working properly
-- EZxx not being linked properly
Enhancements
-- Dashboard support for Open ADR
Developers
-- None
UD AJAX
-- None
WSDK
-- None
Links
- URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.2.3
- Documentation:
-- UD Ajax 3.2.3
Bug Fixes and Enhancements in 3.2.2
Release Date
- Tentative: 2012.03.30
Known Issues
--None
Bug Fixes
-- Fixed migration to I2CS
-- Fixed .REC errors at startup
-- Added Query Insteon Engine
-- TempLinc scene settings for mode
-- Thermosat Dongle v95 uses I2CS
-- Fix for a possible hang issue
Developers
-- REST: Formatted value for iMeter changed to locked/unlocked
-- All SEP Events now have datetime represented in both NTP as well as readable string
-- Portal integration document updated to reflect URLBase usage in /desc
UD AJAX
-- Support for SmartGrid meters
WSDK
Links
- URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.2.2
- Documentation:
-- UD Ajax 3.2.2
Bug Fixes and Enhancements in 3.2.1
Release Date
- 2012.3.20
Known Issues
--None
Bug Fixes
-- Fixed programs not loading
-- Fixed On Level/Ramp Rate issue for FanLinc
Enhancements
-- Added Random for Variables (See this post)
-- Support for 2477S SwitchLinc Relay
-- Support for 2474DWH SwitchLinc 2-Wire Dimmer
-- Support for specific device variables in customized notification:
  ${sys.node.1 45 61 1.name}   -- Name of node 1.45.61.1
  ${sys.node.1 45 61 1.ST}      -- Formatted status of node 1.45.61.1 (e.g. degrees for thermostat node)
  ${sys.node.1 45 61 1.CLIMD}  -- Formatted thermostat mode node 1.45.61.1
Developers
- Updated 1_fam.xml to include the newly supported devices
WSDK
Links
- URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.2.1
- Documentation:
-- UD Ajax 3.2.0
Bug Fixes and Enhancements in 3.2.0
Release Date
- 2012.3.16
Known Issues
In some cases, programs are not loaded. Currently investigating. You must use the following URLs to access ISY (this will be fixed in the next release):
http://www.universal-devices.com/99i/3.2.0/admin.jnlp OR
Bug Fixes
--Fixed log entries for energy information
--Fixed UDI EM3 option dialog's calling multiple services
--Network Resources Test button is disabled if the entries are sorted
--IMeter values up to 3000W
--Total Power not in the chart
--Dusk/Dawn replaced with Dusk.Dawn
--Replace menu not showing up for Motion Sensors and TriggerLincs
--Email From using FName LName:email address worked only once. Subsequent emails failed
--File system errors when file system heavily used by more than one task
-994 Series
--Brultech/Channels>2 were missing total energy conditions in programs
-MAC
--Variable names have the bottom of the text cut off when trying to edit
--Adjust Scene Level window has the up/down scrollers cuts off
Enhancements
-- Added mms.att.net for grouping text messages
-- Support for I2CS Devices
-- Support for FanLinc and TempLinc
-- Device Comm. Errors as conditions in programs
-- Icons for nodes in Device Links dialogs
-- Checkbox in Event Viewer to turn auto scrolling on/off
-- Better error detection for MorningLinc
-UD AJAX
-- Layout width improvements for phones and small devices
-- INSTEON temperature sensor using degree instead of F
-- Feedback when loading config/errors
-- main_panel=false hides the logo and top menu
-- Changed encoding to UTF-8
-- Combined Help|About menu with a drop down
-- Renamed Max Width Settings to make more sense
Developers
- Added Err Control ... for device comm errors
WSDK
Links
- URL for Web Services: http://www.universal-devices.com/developers/wsdk/3.2.0
- Documentation:
-- NEW: Portal Integration Development Guide
-- UD Ajax 3.2.0
How do I apply for access to the beta ?
Thanks.
-Xath
Xathros
As with all Betas the announcement post that it is actually available (the above post says tentative 3/16/2012) will have a link to download the beta image.
Thanks LeeG.
It's been a while since I've done ISY betas but last time around, I remember having to specificly request access to the beta as they were not posted to the forum.
-Xath
No you don't have to request betas anymore. There will be an announcement post with links and instructions.
I have a few I2CS modules from the developers group offer and will give it a try when avilable.
I installed 3.2.0 and experienced no problems. My existing shortcuts to the ISY continued to work. I did not have to use the posted link to find my ISY.
I installed two fanlincs. Both appear to be working fine. I am in the process of creating scenes. So far...so good. I added them manually, choosing fanlinc from the menu. I have not tried an automatic or auto discover linking proces. I have one more fanlinc to install (both physically and into the ISY). Perhaps I will try an automatic installation here, just for fun.
Thanks, again, for the fine support. I would not want to rely on manual linking for fan modules, given the difficulty of access. I believe this represents another strong example of the ISY-99 saving insteon.
I installed a FanLinc, but it isn't working (no light, no fan). Using firmware 3.2.0. The device seemed to get added properly. I tried various troubleshooting checks including resetting FanLinc to factory defaults. The factory reset process didn't complete as outlined in the guide. Do you think the FanLinc is defective?
“Do you think the FanLinc is defective?:
No. How long have you had the FanLinc?
The Factory Reset would normally wipe out the links the device add created. Suggest deleting the FanLinc and add it back.
Two things to check first though. Click on Help | About and make sure the Firmware line and the UI line both say 3.2.0. I not then clear the Java cache and use the URL for accessing the 3.2.0 Admin Console.
Second, run Tools | Diagnostics | Event Viewer with Level 3-Device communications events selected. Now perform the new device add and post the event log. .
Sat 03/17/2012 10:06:45 PM : [iNST-SRX ] 02 50 14.06.6F 00.00.02 C7 13 00 LTOFFRR(00)
Sat 03/17/2012 10:06:45 PM : [standard-Group][14.06.6F-->Group=2] Max Hops=3, Hops Left=1
Sat 03/17/2012 10:06:45 PM : [ 14 6 6F 3] DOF 0
Sat 03/17/2012 10:06:45 PM : [ 14 6 6F 3] ST 0
Sat 03/17/2012 10:06:45 PM : [ 14 6 6F 1] CLIHCS 0
Sat 03/17/2012 10:07:02 PM : ---- Initializing the linked devices ----
Sat 03/17/2012 10:07:02 PM : ---- All Linked Devices are now initialized ----
Sat 03/17/2012 10:07:02 PM : ---- Add remaining devices ----
Sat 03/17/2012 10:07:02 PM : [FileOpen ] Open failed for [/CONF/149F6B.REC] ®
Sat 03/17/2012 10:07:02 PM : DB: Cannot init 149F6B.REC
Sat 03/17/2012 10:07:02 PM : [iNST-TX-I1 ] 02 62 14 9F 6B 0F 0D 00
Sat 03/17/2012 10:07:02 PM : [iNST-ACK ] 02 62 14.9F.6B 0F 0D 00 06 (00)
Sat 03/17/2012 10:07:02 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 0D 01 (01)
Sat 03/17/2012 10:07:02 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:02 PM : [14 9F 6B 0 ] Calibrating engine version ensuring support for i2
Sat 03/17/2012 10:07:02 PM : [iNST-TX-I2 ] 02 62 14 9F 6B 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2
Sat 03/17/2012 10:07:02 PM : [iNST-ACK ] 02 62 14.9F.6B 1F 2F 00 00 00 0F FF 01 00 00 00 00 00 00 00 00 C2 06 (00)
Sat 03/17/2012 10:07:03 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 2F 00 (00)
Sat 03/17/2012 10:07:03 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:03 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 23 2F 00 (00)
Sat 03/17/2012 10:07:03 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sat 03/17/2012 10:07:03 PM : [iNST-ERX ] 02 51 14 9F 6B 11 CB 26 11 2F 00 00 01 0F FF 00 A2 00 11 CB 26 FF 1F 01 00
Sat 03/17/2012 10:07:03 PM : [Extended-Direct][14.9F.6B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sat 03/17/2012 10:07:04 PM : [ 14 9F 6B 1] Adding device to ISY t=01.2E.0000
Sat 03/17/2012 10:07:04 PM : [14 9F 6B 1 ] Start : Adding device to ISY
Sat 03/17/2012 10:07:04 PM : [14 9F 6B 1 ] Finish : Adding device to ISY was Successful
Sat 03/17/2012 10:07:04 PM : [14 9F 6B 1 ] Link 0 : 0FF8 [A20011CB26FF1F01] Saving [A20011CB26FF1F01]
Sat 03/17/2012 10:07:04 PM : [iNST-TX-I1 ] 02 62 14 9F 6B 0F 19 00
Sat 03/17/2012 10:07:04 PM : [iNST-ACK ] 02 62 14.9F.6B 0F 19 00 06 LTSREQ (LIGHT)
Sat 03/17/2012 10:07:04 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 05 FF (FF)
Sat 03/17/2012 10:07:04 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:04 PM : [14 9F 6B 2 ] Start : Adding device to ISY
Sat 03/17/2012 10:07:04 PM : [14 9F 6B 2 ] Finish : Adding device to ISY was Successful
Sat 03/17/2012 10:07:04 PM : [14 9F 6B 2 ] Link 1 : 0FF0 [A20011CB26FF1F02] Saving [A20011CB26FF1F02]
Sat 03/17/2012 10:07:04 PM : [ 14 9F 6B 1] ST 255
Sat 03/17/2012 10:07:05 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 05 FF (FF)
Sat 03/17/2012 10:07:05 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:05 PM : [iNST-TX-I1 ] 02 62 14 9F 6B 0F 19 01
Sat 03/17/2012 10:07:05 PM : [iNST-ACK ] 02 62 14.9F.6B 0F 19 01 06 LTSREQ (01)
Sat 03/17/2012 10:07:05 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 05 01 (01)
Sat 03/17/2012 10:07:05 PM : [ 14 9F 6B 2] ST 1
Sat 03/17/2012 10:07:06 PM : [iNST-SRX ] 02 50 14.06.6F 11.CB.26 07 6E 44 (44)
Sat 03/17/2012 10:07:06 PM : [standard-Direct][14.06.6F-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
Sat 03/17/2012 10:07:06 PM : [ 14 6 6F 1] ST 136
Sat 03/17/2012 10:07:07 PM : [14 9F 6B 1 ] Device added to ISY
Sat 03/17/2012 10:07:07 PM : ---- All Remaining Device Added ----
Sat 03/17/2012 10:07:07 PM : [iNST-TX-I1 ] 02 62 14 9F 6B 0F 19 00
Sat 03/17/2012 10:07:07 PM : [iNST-ACK ] 02 62 14.9F.6B 0F 19 00 06 LTSREQ (LIGHT)
Sat 03/17/2012 10:07:08 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 05 FF (FF)
Sat 03/17/2012 10:07:08 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:08 PM : [iNST-TX-I1 ] 02 62 14 9F 6B 0F 19 01
Sat 03/17/2012 10:07:08 PM : [ 14 9F 6B 1] ST 255
Sat 03/17/2012 10:07:08 PM : [iNST-ACK ] 02 62 14.9F.6B 0F 19 01 06 LTSREQ (01)
Sat 03/17/2012 10:07:08 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 05 01 (01)
Sat 03/17/2012 10:07:08 PM : [All ] Writing 16 bytes to devices
Sat 03/17/2012 10:07:08 PM : [14 9F 6B 1 ] Link 0 : 0FF8 [A20011CB26FF1F01] Writing [A20011CB26FF1F01]
Sat 03/17/2012 10:07:08 PM : [iNST-TX-I2 ] 02 62 14 9F 6B 1F 2F 00 00 02 0F FF 08 A2 00 11 CB 26 FF 1F 01 F6
Sat 03/17/2012 10:07:08 PM : [iNST-ACK ] 02 62 14.9F.6B 1F 2F 00 00 02 0F FF 08 A2 00 11 CB 26 FF 1F 01 F6 06 (00)
Sat 03/17/2012 10:07:09 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 2F 00 (00)
Sat 03/17/2012 10:07:09 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:09 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 14 9F 6B 01 2E 00 15
Sat 03/17/2012 10:07:09 PM : [PLM ] Group 0 : Writing Controller Link matching [14 9F 6B 1 ] Link 0 : 0FF8 [A20011CB26FF1F01]
Sat 03/17/2012 10:07:09 PM : [14 9F 6B 1 ] Link 1 : 0FF0 [A20011CB26FF1F02] Writing [A20011CB26FF1F02]
Sat 03/17/2012 10:07:09 PM : [iNST-TX-I2 ] 02 62 14 9F 6B 1F 2F 00 00 02 0F F7 08 A2 00 11 CB 26 FF 1F 02 FD
Sat 03/17/2012 10:07:10 PM : [iNST-ACK ] 02 62 14.9F.6B 1F 2F 00 00 02 0F F7 08 A2 00 11 CB 26 FF 1F 02 FD 06 (00)
Sat 03/17/2012 10:07:10 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 2F 00 (00)
Sat 03/17/2012 10:07:10 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:10 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 14 9F 6B 01 2E 00 15
Sat 03/17/2012 10:07:10 PM : [PLM ] Group 0 : Writing Controller Link matching [14 9F 6B 1 ] Link 1 : 0FF0 [A20011CB26FF1F02]
Sat 03/17/2012 10:07:10 PM : [14 9F 6B 1 ] Link 2 : 0FE8 [0000000000000000] Writing [00..............]
Sat 03/17/2012 10:07:10 PM : [iNST-TX-I2 ] 02 62 14 9F 6B 1F 2F 00 00 02 0F EF 08 00 00 00 00 00 00 00 00 C9
Sat 03/17/2012 10:07:11 PM : [iNST-ACK ] 02 62 14.9F.6B 1F 2F 00 00 02 0F EF 08 00 00 00 00 00 00 00 00 C9 06 (00)
Sat 03/17/2012 10:07:11 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 2F 00 (00)
Sat 03/17/2012 10:07:11 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:11 PM : [14 9F 6B 1 ] Link 3 : 0FE0 : Writing High Water Byte
Sat 03/17/2012 10:07:11 PM : [iNST-TX-I2 ] 02 62 14 9F 6B 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA
Sat 03/17/2012 10:07:11 PM : [iNST-ACK ] 02 62 14.9F.6B 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA 06 (00)
Sat 03/17/2012 10:07:12 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 2F 00 (00)
Sat 03/17/2012 10:07:12 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:12 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 23 2F 00 (00)
Sat 03/17/2012 10:07:12 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sat 03/17/2012 10:07:12 PM : [iNST-ERX ] 02 51 14 9F 6B 11 CB 26 11 2F 00 00 01 0F E7 00 00 00 00 00 00 00 00 00 00
Sat 03/17/2012 10:07:12 PM : [Extended-Direct][14.9F.6B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sat 03/17/2012 10:07:12 PM : [iNST-TX-I2 ] 02 62 14 9F 6B 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA
Sat 03/17/2012 10:07:12 PM : [iNST-ACK ] 02 62 14.9F.6B 1F 2F 00 00 00 0F E7 01 00 00 00 00 00 00 00 00 DA 06 (00)
Sat 03/17/2012 10:07:13 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 2F 00 (00)
Sat 03/17/2012 10:07:13 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
Sat 03/17/2012 10:07:13 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 23 2F 00 (00)
Sat 03/17/2012 10:07:13 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=0
Sat 03/17/2012 10:07:13 PM : [iNST-ERX ] 02 51 14 9F 6B 11 CB 26 11 2F 00 00 01 0F E7 00 00 00 00 00 00 00 00 00 00
Sat 03/17/2012 10:07:13 PM : [Extended-Direct][14.9F.6B-->ISY/PLM Group=0] Max Hops=1, Hops Left=0
Sat 03/17/2012 10:07:13 PM : [iNST-TX-I2 ] 02 62 14 9F 6B 1F 2F 00 00 02 0F E7 08 00 00 00 00 00 00 00 00 D1
Sat 03/17/2012 10:07:13 PM : [iNST-ACK ] 02 62 14.9F.6B 1F 2F 00 00 02 0F E7 08 00 00 00 00 00 00 00 00 D1 06 (00)
Sat 03/17/2012 10:07:14 PM : [iNST-SRX ] 02 50 14.9F.6B 11.CB.26 2B 2F 00 (00)
Sat 03/17/2012 10:07:14 PM : [standard-Direct Ack][14.9F.6B-->ISY/PLM Group=0] Max Hops=3, Hops Left=2
nedsmith
The Event trace of the FanLinc device add does not show any errors.
Do you see two nodes listed for the FanLinc after the device add?
If so what happens when the Light node is select and the On button at the bottom of the screen is pressed? Does the FanLinc Light status LED turn Green? If not what is the On Level (applied locally) slider position? If in the left position 0% move the slider to the 100% position and try the On button again.
nedsmith
In addition to the On Level (Applied Locally) slider to 100%, move the Ramp Rate (Applied Locally) slider to 0.1 seconds.
Also from the event trace it looks like the Device Type field specified FanLinc. Nothing wrong with that selection, I have installed one of the original FanLincs with that option and it works fine once the On Level (Applied Locally) slider is moved to 100%. However, the FanLinc Firmware level will indicate v.00 when Auto Discover is not used. Before getting too far along I suggest deleting the FanLinc and adding it back using Auto Discover so the FanLinc firmware level will be displayed.
EDIT: the Ramp Rate (Applied Locally) can remain at 9 minutes. The FanLinc is one of those devices that treat a 9 minute ramp rate as 0.2 seconds.
Why isn't failure to initialize 14.9F.6B considered an error?
That is (would be) a file on the SD card. Nothing to do with the FanLinc itself.
EDIT: when are you seeing that message. I saw it during device add but that was at the beginning of the process before the device was added. If this is happening during a restart it would explain why the On Level (Applied Locally) value is not being restored.
I've just tried out the 3.2.0. I've installed numerous fanlincs in a new house and am looking forward to getting them working with various controllers.
Are you going to have a mechanism to connect a scene with each fan speed? According to the manual, there is a way to do it manually, but I haven't tried it.
Are you going to add control over the fanlinc LEDs so I can shut them off?
Dan S
Regarding the Fan speed, the Responder On Level of the Fan indicates speed. Move the Scene On Level slider to the Fan speed (Off, Low Med High) desired for the Scene..
      377k
