if and or question
does this make sense?
            Control 'Other / Krista's Keypad - G' is switched On
         Or Control 'Other / Mike's Keypad - G' is switched On
   And From    Sunset  +  1 minute
       To      10:30:00PM (same day)
       Run Program 'G - All Off Night' (Then Path)
       Run Program 'G - All Off Day' (Then Path)
The Else will run at 10 PM and when either of the two KPL buttons are pressed On and not within the time range. If that is not the desired result put the Else Action statement in another Program that triggers specifically at 10 PM.
what i want to accomplish is if mike or kristas keypad g is pressed between sunset and 10:30pm i want the all off night program to run. if mike or kristas keypad g is pressed any other time i want the all off day program to run.
"what i want to accomplish is if mike or kristas keypad g is pressed between sunset and 10:30pm i want the all off night program to run. if mike or kristas keypad g is pressed any other time i want the all off day program to run."
That is what I would expect to happen. Is that not what is happening?
it seems to run the else at sunset and 10:30. let me verify tonight that nothing else could be triggering it and i will update tomorrow.
That is correct. A Schedule From/To causes the Program to trigger at the From time and the To time. The clause that runs is determined by the True/False of the If conditions.
If that is not what is needed put the Else logic in another Program in the Then clause with positive (True) is conditioning.
Try these two programs
       - -blank
   And From    10:30:01PM
       To        Sunset  +  59 seconds (next day)
       Run Program 'G - All Off Day(Then Path)
       - -blank
I think I, too, would break this into two programs:
       Run Program 'time' (if Path)
time program
       Time is from    Sunset
The time program must be disabled.
