Hi Bob,
This is so very odd and I think you may be developing a file system issue.
Yes, you can use a program with one Action:
Irrigation - Reset Variables
This should reset the values in the file. If this does not work, please do let me know and we'll take even more drastic measures.
Custom notifications don't seem to be working yet. Test button works - actual custom content notifications containing variables don't.
Test 1: From Field Blank, Content default - Works (tested twice)
Test 2: From Field blank - Custom content static text in subject and body - works
Test 3: From Field filled Fname Lname:emali@address - Content Default - Works and the From is displayed in message correctly. (tested twice)
Test 4: From Field filled Fname Lname:email@address - Custom content static text in subject and body - Works (tested twice) (This is what I'm using for now till below is fixed.)
Test 5: From field filled Fname Lname:email@address - Custom content with static subject and 1 variable in body - Does not work - Variable used: ${alert.time}
All tests using my own smtp. A10/X10 module installed.
Any word on this ? I'd like to be able to add some non-static information to my notifications. As it is right now, I had to add a bunch (10 ish) of extra notify programs to get the minimum detail I needed without using vars and that still doesn't give me everything I'd like. All of this used to be just 2 programs using vars.
Thanks.
This thread inspired me to figure out how to use variables along with the release notes for 3.2.1 showing thermostat variables.
I have a couple of custom notifications that use ${alert.time12} ${alert.date} ${sys.node.xx xx xx 1.STA} etc and they all seem to be working fine.
Just received a notification this morning that reads:
"The house appeared to be idle on 2012/03/29 @ 7:26:27 AM.
Power has been shutdown and thermostat adjusted to save power."
Thanks andyf0. I'll have to try again. I did some fairly thorough testing when 3.2.1 first released but have not tried again since.
-X
Hi Bob,
The "reset variables" worked and it is now reporting valid looking numbers.
Thanks Michel
I'm still having problems getting the notifications to send is any of them contain a variable. I was able to get a few to work with just date and time info but once I started adding mvars to them eveything stops sending.
Anyone else ?
-X
Upgraded from 3.1.17
No problems
Hello Xathros,
Can you please check your Error Log and let me know if you have any -5000xx errors? if so, can you copy paste here?
Hi Michel-
The following is all of today's error log. I have been doing alot of testing on this today and haven't yet been able to pin down when it works vs when it doesn't beyond it never works with more than date / time vars. Sometimes it fails with no variables at all. Very inconsistant and unpredictable.
Fri 2012/03/30 10:04:34	System	-5012	35
Fri 2012/03/30 10:16:09	System	-5012	38
Fri 2012/03/30 10:17:54	System	-5006	uuid:38
Fri 2012/03/30 11:34:47	System	-5012	42
Is there a listing of what all the error codes mean in the user guide somewhere ?
For what its worth, my feeling is that when its not working, its not even attempting to send. I can see the system state flash "Busy" briefly when it does send and nothing at all when it doesnt.
Thanks for any help you can offer with this.
Hello Xathros,
Here's a list of SMTP errors:
http://www.universal-devices.com/mwiki/ ... MTP_Errors
I think I agree with you that it's not even trying to send the only reasons for which are:
1. Could not get the customization file in which case you should see -1100xx errors for that file
2. The subject/body evaluated to null for some reason
Hello Xathros,
Michel-
Thanks for the info. I tried changing the SMTP from my Webhost to Gmail and it appears to be working at the moment. Both Subject and body contain static text along with variabls so a null value is not the issue. No -1100xx errors as you saw from the log I posted.
Since it's working with Gmail, I'll have to assume my webhost is dumping the messages rather than delivering them.
Thanks for your help and thanks for all the great improvments you and your team have made to the ISY!.
-Xathros.
Hello Xathros,
Thanks so very much for the update. Please do be kind enough to keep and eye and let us know if you see any more anomalies.
Updated from 3.2.1 - no issues.
I know it is not fully supported but..
The Orchestrator Dashboard is much more stable, able to work repeatedly now.
Opening it still says "not found" then click OK, it finds my ISY and loads successfully.
