Scenes not working
I am trying my first Scene (actually been trying for 4 or 5 days) :(
I have a scene that contains one button from a Keypadlinc Relay and 2 ceiling lights switched with Switchlinc Relays. See picture below. If I select the scene in the left column, I can use the on and off buttons in the right section to turn on or off the two lights. But, I cannot turn the lights on or off using the "A" button on the Keypadlinc. I tried doing the same setup with a RemoteLinc, and got the same results.
I know this can't be that hard, but it sure has me confused...
Jeff
Hi Jeff,
Please click on 0B.4C.89.A within the All Indoor Lights scene and then check the on level/ramp rate for the other two devices.
Please do keep us posted. If you're still having problems (and 4/5 days must be quite frustrating) please do not hesitate to contact our tech support team (contact info below) and we'll walk you through it.
