Help With KPL Non-Toggle Mode
I am having a terrible time trying to get My KPL (v1.6) buttons to configure as "ON" non-toggle buttons. When using my ISY-99 to modify, I set the LED on, and then choose Toggle-Off. The button state changes, but always ends up in the "OFF" state, where the off command is always sent.
Please help me figure out how to configure Non-Toggle buttons that send ON commands.
Richard
Select a button that is marked Toggle and select Toggle On/Off. Follow the dialog to change the state to Non-Toggle.
I see there is still a cosmetic glitch in the Toggle display window but the function works properly. I suggest you change one button at a time.
Rand
Richard,
In addition to what Rand suggested (thanks Rand!), you may want to try our 2.6.1 Beta release which has more support for KPL 1.5/6.
My other question is: do you have the same issue with other KPLs (say, 1.4 or 1.65)?
Richard
Michel, I am running 2.6.1, and all I have is v 1.6 KPLs (I am a somewhat new adopter).
Perhaps someone else can confirm that v 1.6 works?
Many thanks.
Richard
Rand, I have tried exactly what you suggest, still with same results. It seems to make no difference whether the LED are on or off, I always end up with the button in Non-Toggle "OFF" mode.
Richard
Hello Richard,
Thank you for finding this. We just verified that with 1.6 and above this function makes all buttons non-toggle off. The next step is to see if this is KPL related or ISY related. I shall keep you posted with the outcome.
Many thanks.
Richard
Hello Richard,
in the next drop, there will be a workaround for non-toggle mode for versions 1.6 and above with the following caveat:
Not all KPLs versions 1.6 and above behave the same!
Looking forward to it, many thanks!
Curious, are the differences in KPL 1.6 behaviour variations in the 1.6 codebase, quality control issues, or diferences in hardware?
Appreciate the fast response and assitance!
Hello Richard,
My pleasure!
I really do not know the answer to your question. From our perspective, we have been given a memory map and that's what we base our design on.
[quote name="morgan4x4
Looking forward to it' date=' many thanks!
Appreciate the fast response and assitance![/quote]
