Power Outage lead to communication error
So I had a power outage last week and lost the ability to use mobilinc over cellular data. I went into the ISY-99 through universal-devices/99i and I tried to change the port number to 443. One of the ports was set to 80 and the other 443. I couldn't remember the steps to fix the issue so I tried to change the 80 port to 443. Obviously this was the wrong thing to do because now when I try to log into the ISY I get the following error:
XML Parse error http: 192.168.1.1:443/desc
Please help. This stuff drives me nuts.
Hello osurh18,
Do you have a good backup? If so, factory reset your ISY (press and hold the reset button for about 30 seconds) and then restore your ISY from your backup. Once Admin Console tries to restore your network configuration, it checks to see whether or not the current configuration is the same as the one you are trying to restore. It's up to you to decide which you want to keep.
