ArcFlash Breakers
Hi...
So I tried to install a 2473SWH receptacle in our master bedroom, and I tried and tried (and fussed and farted and swapped) and finally realized these receptacle(s) go thru an arc-flash type breaker (Cutler Hammer model something or other) and this was probably the reason it was not able to communicate (this receptacle worked elswhere). After reading a bit on forum I see at least 1 solution would be to purchase another wireless access point and plug it in to that circuit.
As an altenative does anyone know of any other models of Arcflash breakers that may be a little more compatible with Insteon communications ? A new breaker (or 2) may be a less expensive alternative to what I think is my problem.
Cheers
M
:roll:
