Logging Thermostat Temperature
I wanted to log the temperature readings from my Insteon thermostats so I made this program (Windows .NET). It logs the temperature every 1 minute for all thermostats to a csv file for easy graphing. Can't say for sure if it will work with all the Venstar models.
http://www.sendspace.com/file/v4w4c0
I mostly graph them in a spreadsheet program. I didn't look into what the differences in the type value are for the different models so it only matches on 5.3.145.0 right now.
Hi az1324,
Can this work only locally? I tried to use this on my office computer, and entered in the IP address box the dynamic DNS URL I use to connect remotely & it doesn't work.
  • 1 month later...
The link in the original post from az1324 is invalid 40 days later.
Does anyone have the original text for the program mentioned?
MSD
I would love to use this application as well. If the OP could repost a valid link to the application it would be greatly appreciated.
Teken . . .
I don't have thermostats to test but you could try this program, which logs ISY data to CSV as well.
viewtopic.php?f=79&t=7763
io_guy,
Thank you so much for sharing. :mrgreen:
Teken . . .
