New port forwarding number?
bitboy53
My 99i comes with the ports 80/443 already set. However, I already have a camera system on 80/9000. Can I change the 80 to another port. I tried 50/443 and it wouldnt work. Any ideas on what port I should pick so both the camera and the 99i can work on the same network?
Thanks in advance for your help
You can change it to whatever port number you want but you will need to add the port number after the ip address if not using the 80/443 default. For example if you change it to port #999 you would do like this to log in:
Your_IP_address:999
Sent from my SPH-D710 using Tapatalk 2
Ports 80 and 443 are the defaults for web server devices. Port 80 for http and 443 for secure https. If you change the 80/443 to 50/443, you could still access the ISY using https without needing to also specify a port # since the secure port is still using the default of 443.
Example:
http://192.168.1.101:50
https://192.168.1.101
In either case, replace the IP address with that of your ISY.
      37.8k
      377.9k
