Widget Error
I set up a program widget on my Droid. I tap the widget and run the if command to turn a light on and lower a stat setpoint. I then run the if command to turn the light off and return the setpoint to what it was before.
The problem is it only works about half the time. When it doesn't work I get, "Unable to connect to lighting controller. Please verify lighting controller settings"
Anyone know what this means and how to fix it?
Thanks! :mrgreen:
Is your ISY and Mobilinc set up to work from outside of your home network (3G/4G) ? If not, then it's likely failing when you have dropped your local WiFi connection and working when your connection is up. Most smartphones will drop WiFi when not in use to save battery.
-Xathros
Yes, my Mobilinc can work outside my wifi. I have an http and an https address in the Mobilinc settings. ie. I can access my devices at work, 20 miles from home using Mobilinc without problems.
Hi jmed999,
This is Wes from MobiLinc.
Can you try something to see how it behaves? This is likely a cell data network issue where the phone doesn't have a good data signal (waking from sleep, etc) from the tower when the command is issued through the Widget.
Try this, before you issue your widget command, open the web browser and go to Google.com or similar site to verify/establish network connectivity then issue the Widget command. Does your success rate improve?
Wes
I have tried going to a website first then touching the widget and it seems to act the same way. Sometimes it works and sometimes it doesn't. I don't think it helps at all to go to a website first.
jmed999,
If there is a Widget problem we need to be able to reproduce it in our lab so that we can fix the issue. Are there reproducible steps we can take to illustrate the problem consistently?
The error message you are receiving is consistent with the Widget not being able to "see" the internet at the time of issuing the command. The most common reason is that the phone simply hasn't established a data connection yet to the internet service provider. By going to a website first you know that the phone can reach out to the internet so you can eliminate that as a potential source of the problem.
Wes
This is my program.
       $i.Kristen.Watch.TV is 0
       Set 'Upstairs - Main' 76° (Cool Setpoint)
       Set 'Upstairs CFL Lamp' On
       $i.Kristen.Watch.TV  = 1
       Set 'Upstairs - Main' 90° (Cool Setpoint)
       Set 'Upstairs CFL Lamp' Off
       $i.Kristen.Watch.TV  = 0
What else do you need to reproduce the issue?
I actually don't need the program. Based on your description, the error message is telling you that the Widget couldn't reach your ISY to issue the command. So, the problem is related to the phone's ability to get a data signal at the time the widget was activated.
I don't believe there is anything we can do in the widget to fix a phone data problem, but wanted to know if there were reproducible steps that we can try in our lab to rule the widget out. For example,
- Phone is asleep.
- Wake phone up.
- Immediately find widget and attempt to activate program.
- Receive error message.
- Repeat command again.
- Command is successful.
Something like that flow is what we'd need to attempt to reproduce the error you are seeing.
Wes
- Phone is asleep.
- Wake phone up
- Notice 4 out of 5 wifi bars
- Immediately find widget and attempt to activate program "Run If" command
- Go to browser and let webpage fully load
- Then go to a link on that webpage to bring up a website that I've never been to before.
- Let the new website fully load
- Go to ISY on laptop and activate "run if" in same program
- Verify program "run if" command works when activated from ISY
- Immediately find widget and attempt to activate program "Run If" command (note: phone did not go to sleep between last try)
- sync mobilinc with ISY
- attempt to activate program "Run If" command
Tomorrow when I come home from work I'll see if I can get it to work without syncing with ISY.
jmed999,
Quick suggestion. It sounds like the commands are working in MobiLinc. Please delete the widget and recreate your program widget and try again.
It sounds like perhaps the program's ID in the ISY changed from what it was when the widget was initially created. This can happen if the program is modified and saved in the Admin Console.
Wes
I just deleted and recreated on both my phone and my wife's phone. I'll let you know if I have anymore trouble. Thanks!
