2420M Motion / Light Setup with override
Hey everyone,
I am really sorry if this is already posted somewhere but I am looking for some help.
I have a motion sensor controlling a pair of 3 way switches.
IF
Control MS1-Sensor is switched On
And Status 'Laundry (1)' is Off
Set Scene 'Laundry 3-Way' On
No Action
That works great. The Scene turns the lights on to 70%.
Then I have the following to turn off the lights:
IF
Control MS1-Sensor is switched Off
And Status 'Laundry (1)' is 70%
Set Scene 'Laundry 3-Way' Off
No Action
So that works expect for that if the lights were set to 100% they would still turn off.
I am looking to have it only turn the lights off if they are at 70% after the motion sensor triggers off.
Lastly I would like to add in a delay from when the motion sensor triggers off if possible to leave the lights on for an additional 60 seconds.
Can anyone help me?
Hello jay5,
Is the motion sensor directly linked to any of the switches in the three-way scene or is the motion just linked to the plm/ISY? In order for the turn off program to work, the motion cannot be directly linked to 'Laundry (1) switch.
When you turn the three-way scene on locally does the ISY admin console correctly indicate the status level of "'Laundry (1)"?
So I figured it out. I had a test program that was triggering, my logic was working on what I posted.
The only thing left is how to introduce a wait between the motion sensor stopping and the light turning off.
Isn't there a "wait" command that can be added to the "Then" section, such as "WAIT 4 MINS", followed by another line under THEN telling the scene to turn off?
My fear is that if I do that and it starts waiting, and then motion happens before the wait is over it will still turn them off when in fact it should be cancelled and started over when the motion sensor control fires off again.
