ISY and Denon CI Receiver
Hello, Looking for a little help setting up a command to turn on my Denon audio receiver via the ISY. It is the CI version and can take IP codes via rule. What I would like to know is can I set a KPL to turn on the receiver and change the input to itunes to play music in the house. I tried to copy the irule codes to the network mod and tried every which way to get it to work. Now I am stuck asking anyone if they have any suggestions. Thank you for your time in advance.
Thanks for your info. I went to your topic and found that the link in that topic no longer worked. Can you point me in another direction? Thanks?
Corey
Corey-
What I would do is use WireShark on a MAC or PC to sniff the traffic coming from rule to the receiver. As long as the connection from rule to the receiver is not encrypted (https), you can examine the content of that conversation and build your network resource from that.
-Xathros
  • 3 weeks later...
boatfevor/xathros/Michel - There is indeed a documented official control protocol for the Denon AVRs. I have documented how to use it to control Denon receivers with the ISY994i in this topic. I think you'll find it easier, more general, and more reliable than reverse engineering the HTTP POSTs using wireshark.
