ISY99i/IR all of a sudden going off into space.
zeenon
I consider my home install pretty lucky because I really have not had any issues. I buy a new switch, start up the admin console add it and move on.
I recently tackled a 4 way switch install which went well (1 Keylinc and 2 Switchlincs) Button A is controlled by either a remote linc button or the Keylinc A. Now because I have the keylinc I wanted to program the other buttons B, C, D along with the remotelinc buttons. So to make a long story short I'm really stuck. I deleted the switchlinc and no matter what I do, I can not add it back. If I try to backup the ISY, I get an error CONF/XXXXXX.REC where XXXXXX is the address of the switch.
Any help would greatly be appreciated.
I just want a scene like I currently have with Keylinc button A, in which a remotelinc or keylinc turns on a switch linc. A works, B failed miserably.
Z
Hello zeenon,
I am so very sorry to hear.
Please do the following:
1. Telnet to ISY (http://www.universal-devices.com/mwiki/ ... o_Your_ISY)
2. Login using your credentials
3. At the prompt, type: RF /CONF/XXXXX.REC where XXXXX is the file that ISY is complaining about
4. Do the above for all files for which you have problems
All this said, I am a little worried that may have a corrupted file system and/or SD Card. So, before you reboot, take a good backup and make sure you keep it somewhere safe.
