ISY Gets Power From PLM
When the ISY gets it's power from the insteon PLM.....just what kind
of power is the PLM supplying? Is the supplied power adherent to the
802.3af standard? Is the insteon wart supplying 5VDC, same as the
wart supplies?
It looks like the ISY box runs from 5Volts when using the wart.
Here's my vote to have the next hardware revision use POE according to the
803.2af standard...48VDC, up to 15 watts. Or 803.2at (POE+) if necessary.
And through the Ethernet port too....not the other serial port that connects to the PLM.
