Hi Teken,
I think we are talking passed each other. Let me try again:
1. The problem is the Admin Console/Java using SSLv2. This has NOTHING to do with your browser and its configuration
2. The link I sent in my email (http://www.universal-devices.com/99i/3.3.2/admin.jnlp) is the one that you said you had no problem using. Is this still the case? If so, I am not sure I understand why you keep using the link from TouchSwitch (which may be pointing to a different UI)
  Michel Kohanim said:
Hi Teken,
Perhaps we are not on the same page. I had no problem using the link you provided on the LAN, but how does that help me accessing the Admin Console remotely using HTTPS ?
If the Touchswitch is pointing to a different UI how is this corrected?
Teken . . .
I installed 3.3.2 on 9/20 and over the next few days I noticed my irrigation is running less frequently. I found that the evapotranspiration is accruing much more slowly than in my previous (3.1.17) version. I didn't see mention of a change to that algorithm in this forum or in the release documentation.
Prior to installing 3.3.2 the Water Deficit Yesterday value would accumulate between .4 and .45 inches with 85-95 degrees, 20-25% humidity and 0-5 mph wind.
With 3.3.2 the largest value I've seen for Water Deficit Yesterday has been .12 inches with approximately the same weather conditions.
Actually I believe 3.3.2 is providing a more realistic evapotranspiration figure than 3.1.17 did. Before I adjust my irrigation program parameters to account for the difference in calculation I would like to be sure I am looking at things correctly.
mike
MIchel,
How do I determine what version of the irrigation module I am running? I bought it originally in January at the same time I updated from ISY 2.8.16 to 3.1.13.
mike
Hi Mike,
If you have not explicitly requested to be part of the V2 release, then you have the original one.
There was a bug in V1 in which case we didn't use Julian days. That might explain the fact that the readings are lower now.
Hi Mike,
If you depend on your Irrigation module, I do not recommend it since it's in alpha and being tested by a couple of our customers who agreed to use their system for real-life testing. Furthermore, with V2, you are going to have even less Irrigation Requirement.
I used to see all the current values returned from Weather Bug now the Status box is empty. Am I no longer receiving weatherbug information?
Thanks Michel, I"ll hold off.
On a slightly different note, are there any plans to accommodate multiple zones with different irrigation requirements in the near future?
mike
  JMC said:
Great news Michel,
I would like to participate in testing, Alpha or Beta.
mike
Hello JMC,
Here is Michel's announcement from another thread:
Hello all,
We need a few volunteers to test the enhancements (for accuracy) as proposed by IndyMike. Please note that this will be a separate branch outside the current beta so as to not disturb existing installations. I suspect we would need about a month of testing to ensure calculations are accurate.
If you are interested, please send an email to support@universal-devices.com with subject "New ET Firmware".
Thanks in advance and with kind regards,
_________________
Michel Kohanim
Universal Devices, Inc.
ISY-99i/ISY-26 INSTEON Wiki
Submit a ticket
The original thread fount here. viewtopic.php?f=25&t=8771&start=0
If a program is disabled and resides within a folder would it be possible to show a disabled icon on the folder itself to indicate that one or more programs within the folder are disabled?
