Not sure how to write this one
In my ISY, how would I write a program that the condition was
If no light switch has been touched for four hours (let's say)
then turn on some indoor and outdoor lights (because I'm obviously not home and want lights on when I arrive).
Drew
Drew,
Try this:
x is off
And y is off
And z is off
wait 4 hours
turn w on
turn u on
Drew
You also might want to create a seperate program and call it nighttime and add it to the if statement of this program Michel gave to make it only do it at night.
Drew
Andrew, what happens when you are asleep and no switches are touched for four hours?
Good one, Joe.
Maybe I can have it run only between the hours of (?) and (?)
or have it run only if it's also before a certain hour of the night (say 11:00pm?)
Drew
Yes, I think you would want to add a qualifier, such as the ones you have listed.
An alternative would be to have a Home/Away KPL button that you push when you leave, and push again when you return. Upon leaving, it could do things like turn all lights off, or perhaps start an 'Away' schedule to give your house an occupied look for security. Or, if you have a security panel, you could tie it in so that arming/disarming would serve that same function.
As you can probably tell, I'm at the start of using my ISY.
I've had the insteon stuff for a while and tried Houselinc but was left a little frustrated.
I need to learn more about IF and THEN and Qualifiers.
I've been to the WIKI site and it's okay but not really informative.
Is there a site or a particular forum that's got a good education on starting to program the ISY?
Drew
Hi Drew,
Have you checked out the following?
ISY Programming forum: http://forum.universal-devices.com/viewforum.php?f=13
ISY Example Programs forum: http://forum.universal-devices.com/viewforum.php?f=14
Drew
  • 2 months later...
I know this is an old thread but I've just gotten around to this idea again.
What I want is this.
If we're not home then this program will run.
I'm assuming that if the Big Room, or the Hall, or the Kitchen is off then we're not home as these lights are in all scenes.
Here's my program
Time is Sunset + 30 minutes
And Status 'Hall KPL A Hall Light' is Off
And Status 'Big Room' is Off
And Status 'Kitchen' is Off
Set Scene 'All Dim' On
Set 'Deck KPL A Decklight' 65%
Send Notification to All
Set 'Barn' 70%
Does anyone see a problem here?
Is there an easier way to do this?
And what is the ELSE section for?
Now that the forum has been reorganized, I can't follow those links found above anymore.
Drew
Drew,
A couple of potential problems with the below -
1) I don't see where you are turning your lights off (another program possibly).
2) In your "THEN" statement - you are activating the "ALL DIM" scene. If this changes the status of the devices in your "IF" statement (HALL KPL, Big Room, or Kitchen), your conditional will retrigger and revert to a "false". The statements following your "ALL DIM" scene may not be executed.
Rather than "inferring" that you're not at home from the status of your lights, would it be easier to dedicate a KPL button to "AWAY MODE"?
Time is Sunset + 30 Minutes
And Status "Away Mode" is ON
IM
Here's my program
Set 'Barn' 70%
Drew
Anybody know what this is for and how to use it? I've noticed that none of the programs that people post here use this section of the If THEN ELSE program.
Maybe it's something I should stay away from until i know better.
Drew
Drew,
The else loop is executed when your "IF" condition evaluates to a false.
In the example below, if both the Time and the Away conditions are true the "then" loop is executed (executing the away scene).
If either of the conditions are false, the "else" loop is executed (turning the scene off).
Time is from Sunset + 30 Minutes
to Sunrise (next day)
Set 'Barn' 70%
Set Scene 'All Dim' off
Set 'Deck KPL A Decklight' off
Set 'Barn' off
IM
