December 2, 201212 yr The 3.3.4 release does not have support for the Dual Band KPL Relay device type.
December 2, 201212 yr LeeG, Thanks for the info - I found this thread, looks like it's not an isolated issue: http://forum.universal-devices.com/viewtopic.php?f=27&t=6922&start=15 The 3.3.4 release does not have support for the Dual Band KPL Relay device type.
December 2, 201212 yr Thanks for the info - I found this thread, looks like it's not an isolated issue: http://forum.universal-devices.com/viewtopic.php?f=27&t=6922&start=15 The 3.3.4 release does not have support for the Dual Band KPL Relay device type. Yes there are several of us with the same issue. I think LeeG's comment would have been better worded "The 3.3.4 release has broken support for ..." since it did work in 3.2.6 and at least one user has reported that it starts working again when he downgraded his ISY back to 3.2.6.
December 2, 201212 yr Author Vyrolan, No, not true. LeeG's comment is 100% true: viewtopic.php?f=28&t=10009&p=75777#p75777 For non-I2CS devices, we used to allow devices to be added by forcing their type. Releases 3.3.x do not allow you to add device X as device Y. We can debate whether or not this should be the case, but we did have multiple support issues + I2CS things that propelled us to take this direction. With kind regards, Michel
December 2, 201212 yr No, not true. LeeG's comment is 100% true: viewtopic.php?f=28&t=10009&p=75777#p75777 For non-I2CS devices, we used to allow devices to be added by forcing their type. Releases 3.3.x do not allow you to add device X as device Y. We can debate whether or not this should be the case, but we did have multiple support issues + I2CS things that propelled us to take this direction. Aha...so I guess it working before or for those who have downgraded is just a very lucky coincidence. =) It definitely makes sense not to munge the device types since I'm sure it can cause all sorts of fun problems when you send or receive commands you don't expect. =p
December 3, 201212 yr Hello All, Update went fine on windows,I cannot get the admin console short cut on my mac.I cleared my cache,I am running Lion 10.7.5, java 1.7.I removed certificate.Any suggestions? Thanks Tim
December 3, 201212 yr Author Hello remedy1234, Unfortunately a know issue with Java 1.7 and MAC. I am so very sorry. With kind regards, Michel
December 15, 201212 yr All -- I started to notice problems connecting to my ISY via the MobilLinc iPhone App last Wednesday (Dec 12th) but I figured it just needed a re-boot so I pulled the plug and plugged it back in after about 20 seconds or so. That seemed to fix the problem then the next two days I have not been able to connect to the ISY via a browser or the MobiLinc App. After examining the error log I noticed that something has been happening since December 3, 2012. The only way I can access the ISY Admin screen is to unplug the ISY and then I can log in. Upon logging in the ISY starts to scan all of the linked devices after which I get the following message box: and then I get this message box: Any thoughts?? Here is a screen shot of my About Page: Java Runtime Version - 1.7.0_4 Here is a printout of the error log: Mon 2012/12/03 02:04:49 System -140000 datafeed.weatherbug.com Mon 2012/12/03 02:05:49 System -140000 datafeed.weatherbug.com Mon 2012/12/03 08:21:43 System -5012 162 Tue 2012/12/04 00:39:07 System -60006 n/a Tue 2012/12/04 00:39:22 System -60006 n/a Tue 2012/12/04 00:39:37 System -60006 n/a Tue 2012/12/04 02:00:46 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:01:46 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:02:46 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:03:45 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:04:45 System -140000 datafeed.weatherbug.com Tue 2012/12/04 02:05:45 System -140000 datafeed.weatherbug.com Tue 2012/12/04 12:40:08 System -60006 n/a Tue 2012/12/04 12:40:08 System -60006 Stopping retries/next cycle Wed 2012/12/05 00:40:40 System -60006 n/a Wed 2012/12/05 00:40:55 System -60006 n/a Wed 2012/12/05 00:41:10 System -60006 n/a Wed 2012/12/05 02:00:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:01:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:02:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:03:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:04:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 02:05:40 System -140000 datafeed.weatherbug.com Wed 2012/12/05 12:41:39 System -60006 n/a Wed 2012/12/05 12:41:54 System -60006 n/a Wed 2012/12/05 12:41:54 System -60006 Stopping retries/next cycle Thu 2012/12/06 00:42:27 System -60006 n/a Thu 2012/12/06 02:00:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:01:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:07:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:08:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:09:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:10:37 System -170001 [Network] Failed DNS 11 Thu 2012/12/06 02:10:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:11:37 System -170001 [Network] Failed DNS 12 Thu 2012/12/06 02:11:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:12:36 System -170001 [Network] Failed DNS 13 Thu 2012/12/06 02:12:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:13:36 System -170001 [Network] Failed DNS 14 Thu 2012/12/06 02:13:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:14:36 System -170001 [Network] Failed DNS 15 Thu 2012/12/06 02:14:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:15:36 System -170001 [Network] Failed DNS 16 Thu 2012/12/06 02:15:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:16:36 System -170001 [Network] Failed DNS 17 Thu 2012/12/06 02:16:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:17:36 System -170001 [Network] Failed DNS 18 Thu 2012/12/06 02:17:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:18:36 System -170001 [Network] Failed DNS 19 Thu 2012/12/06 02:18:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:19:36 System -170001 [Network] Failed DNS 20 Thu 2012/12/06 02:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:20:36 System -170001 [Network] Failed DNS 21 Thu 2012/12/06 02:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:21:36 System -170001 [Network] Failed DNS 22 Thu 2012/12/06 02:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:22:36 System -170001 [Network] Failed DNS 23 Thu 2012/12/06 02:22:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:23:36 System -170001 [Network] Failed DNS 24 Thu 2012/12/06 02:23:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:24:35 System -170001 [Network] Failed DNS 25 Thu 2012/12/06 02:24:35 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:25:35 System -170001 [Network] Failed DNS 26 Thu 2012/12/06 02:25:35 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:26:35 System -170001 [Network] Failed DNS 27 Thu 2012/12/06 02:26:35 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:27:36 System -170001 [Network] Failed DNS 28 Thu 2012/12/06 02:27:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:28:36 System -170001 [Network] Failed DNS 29 Thu 2012/12/06 02:28:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:29:36 System -170001 [Network] Failed DNS 30 Thu 2012/12/06 02:29:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:30:36 System -170001 [Network] Failed DNS 31 Thu 2012/12/06 02:30:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:31:36 System -170001 [Network] Failed DNS 32 Thu 2012/12/06 02:31:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:32:36 System -170001 [Network] Failed DNS 33 Thu 2012/12/06 02:32:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:33:36 System -170001 [Network] Failed DNS 34 Thu 2012/12/06 02:33:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:34:36 System -170001 [Network] Failed DNS 35 Thu 2012/12/06 02:34:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:35:36 System -170001 [Network] Failed DNS 36 Thu 2012/12/06 02:35:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:36:36 System -170001 [Network] Failed DNS 37 Thu 2012/12/06 02:36:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:37:36 System -170001 [Network] Failed DNS 38 Thu 2012/12/06 02:37:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:38:36 System -170001 [Network] Failed DNS 39 Thu 2012/12/06 02:38:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:39:36 System -170001 [Network] Failed DNS 40 Thu 2012/12/06 02:39:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:40:36 System -170001 [Network] Failed DNS 41 Thu 2012/12/06 02:40:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:41:36 System -170001 [Network] Failed DNS 42 Thu 2012/12/06 02:41:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:42:36 System -170001 [Network] Failed DNS 43 Thu 2012/12/06 02:42:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:43:36 System -170001 [Network] Failed DNS 44 Thu 2012/12/06 02:43:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:44:36 System -170001 [Network] Failed DNS 45 Thu 2012/12/06 02:44:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:45:36 System -170001 [Network] Failed DNS 46 Thu 2012/12/06 02:45:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:46:36 System -170001 [Network] Failed DNS 47 Thu 2012/12/06 02:46:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:47:36 System -170001 [Network] Failed DNS 48 Thu 2012/12/06 02:47:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:48:36 System -170001 [Network] Failed DNS 49 Thu 2012/12/06 02:48:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:49:36 System -170001 [Network] Failed DNS 50 Thu 2012/12/06 02:49:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:50:36 System -170001 [Network] Failed DNS 51 Thu 2012/12/06 02:50:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:51:36 System -170001 [Network] Failed DNS 52 Thu 2012/12/06 02:51:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:52:37 System -170001 [Network] Failed DNS 53 Thu 2012/12/06 02:52:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:53:37 System -170001 [Network] Failed DNS 54 Thu 2012/12/06 02:53:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:54:37 System -170001 [Network] Failed DNS 55 Thu 2012/12/06 02:54:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:55:37 System -170001 [Network] Failed DNS 56 Thu 2012/12/06 02:55:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:56:37 System -170001 [Network] Failed DNS 57 Thu 2012/12/06 02:56:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:57:37 System -170001 [Network] Failed DNS 58 Thu 2012/12/06 02:57:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:58:37 System -170001 [Network] Failed DNS 59 Thu 2012/12/06 02:58:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 02:59:37 System -170001 [Network] Failed DNS 60 Thu 2012/12/06 02:59:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:00:37 System -170001 [Network] Failed DNS 61 Thu 2012/12/06 03:00:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:01:37 System -170001 [Network] Failed DNS 62 Thu 2012/12/06 03:01:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:02:36 System -170001 [Network] Failed DNS 63 Thu 2012/12/06 03:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:03:36 System -170001 [Network] Failed DNS 64 Thu 2012/12/06 03:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:04:36 System -170001 [Network] Failed DNS 65 Thu 2012/12/06 03:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:05:36 System -170001 [Network] Failed DNS 66 Thu 2012/12/06 03:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:06:36 System -170001 [Network] Failed DNS 67 Thu 2012/12/06 03:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:07:36 System -170001 [Network] Failed DNS 68 Thu 2012/12/06 03:07:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:08:36 System -170001 [Network] Failed DNS 69 Thu 2012/12/06 03:08:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:09:36 System -170001 [Network] Failed DNS 70 Thu 2012/12/06 03:09:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:10:36 System -170001 [Network] Failed DNS 71 Thu 2012/12/06 03:10:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:11:36 System -170001 [Network] Failed DNS 72 Thu 2012/12/06 03:11:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:12:36 System -170001 [Network] Failed DNS 73 Thu 2012/12/06 03:12:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:13:36 System -170001 [Network] Failed DNS 74 Thu 2012/12/06 03:13:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:14:36 System -170001 [Network] Failed DNS 75 Thu 2012/12/06 03:14:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:15:36 System -170001 [Network] Failed DNS 76 Thu 2012/12/06 03:15:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:16:36 System -170001 [Network] Failed DNS 77 Thu 2012/12/06 03:16:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:17:36 System -170001 [Network] Failed DNS 78 Thu 2012/12/06 03:17:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:18:36 System -170001 [Network] Failed DNS 79 Thu 2012/12/06 03:18:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:19:36 System -170001 [Network] Failed DNS 80 Thu 2012/12/06 03:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:20:36 System -170001 [Network] Failed DNS 81 Thu 2012/12/06 03:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:21:36 System -170001 [Network] Failed DNS 82 Thu 2012/12/06 03:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:22:36 System -170001 [Network] Failed DNS 83 Thu 2012/12/06 03:22:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:23:36 System -170001 [Network] Failed DNS 84 Thu 2012/12/06 03:23:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:24:36 System -170001 [Network] Failed DNS 85 Thu 2012/12/06 03:24:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:25:36 System -170001 [Network] Failed DNS 86 Thu 2012/12/06 03:25:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:26:36 System -170001 [Network] Failed DNS 87 Thu 2012/12/06 03:26:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:27:37 System -170001 [Network] Failed DNS 88 Thu 2012/12/06 03:27:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:28:37 System -170001 [Network] Failed DNS 89 Thu 2012/12/06 03:28:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:29:37 System -170001 [Network] Failed DNS 90 Thu 2012/12/06 03:29:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:30:37 System -170001 [Network] Failed DNS 91 Thu 2012/12/06 03:30:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:31:37 System -170001 [Network] Failed DNS 92 Thu 2012/12/06 03:31:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:32:37 System -170001 [Network] Failed DNS 93 Thu 2012/12/06 03:32:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:33:37 System -170001 [Network] Failed DNS 94 Thu 2012/12/06 03:33:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:34:37 System -170001 [Network] Failed DNS 95 Thu 2012/12/06 03:34:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:35:37 System -170001 [Network] Failed DNS 96 Thu 2012/12/06 03:35:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:36:37 System -170001 [Network] Failed DNS 97 Thu 2012/12/06 03:36:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:37:37 System -170001 [Network] Failed DNS 98 Thu 2012/12/06 03:37:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:38:37 System -170001 [Network] Failed DNS 99 Thu 2012/12/06 03:38:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:39:37 System -170001 [Network] Failed DNS 100 Thu 2012/12/06 03:39:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:40:37 System -170001 [Network] Failed DNS 101 Thu 2012/12/06 03:40:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:41:37 System -170001 [Network] Failed DNS 102 Thu 2012/12/06 03:41:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:42:36 System -170001 [Network] Failed DNS 103 Thu 2012/12/06 03:42:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:43:36 System -170001 [Network] Failed DNS 104 Thu 2012/12/06 03:43:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:44:36 System -170001 [Network] Failed DNS 105 Thu 2012/12/06 03:44:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:45:36 System -170001 [Network] Failed DNS 106 Thu 2012/12/06 03:45:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:46:36 System -170001 [Network] Failed DNS 107 Thu 2012/12/06 03:46:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:47:36 System -170001 [Network] Failed DNS 108 Thu 2012/12/06 03:47:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:48:36 System -170001 [Network] Failed DNS 109 Thu 2012/12/06 03:48:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:49:36 System -170001 [Network] Failed DNS 110 Thu 2012/12/06 03:49:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:50:36 System -170001 [Network] Failed DNS 111 Thu 2012/12/06 03:50:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:51:36 System -170001 [Network] Failed DNS 112 Thu 2012/12/06 03:51:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:52:36 System -170001 [Network] Failed DNS 113 Thu 2012/12/06 03:52:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:53:36 System -170001 [Network] Failed DNS 114 Thu 2012/12/06 03:53:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:54:36 System -170001 [Network] Failed DNS 115 Thu 2012/12/06 03:54:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:55:36 System -170001 [Network] Failed DNS 116 Thu 2012/12/06 03:55:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:56:36 System -170001 [Network] Failed DNS 117 Thu 2012/12/06 03:56:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:57:36 System -170001 [Network] Failed DNS 118 Thu 2012/12/06 03:57:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:58:36 System -170001 [Network] Failed DNS 119 Thu 2012/12/06 03:58:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 03:59:36 System -170001 [Network] Failed DNS 120 Thu 2012/12/06 03:59:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:00:36 System -170001 [Network] Failed DNS 121 Thu 2012/12/06 04:00:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:01:36 System -170001 [Network] Failed DNS 122 Thu 2012/12/06 04:01:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:02:36 System -170001 [Network] Failed DNS 123 Thu 2012/12/06 04:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:03:36 System -170001 [Network] Failed DNS 124 Thu 2012/12/06 04:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:04:36 System -170001 [Network] Failed DNS 125 Thu 2012/12/06 04:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:05:36 System -170001 [Network] Failed DNS 126 Thu 2012/12/06 04:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:06:36 System -170001 [Network] Failed DNS 127 Thu 2012/12/06 04:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:07:37 System -170001 [Network] Failed DNS 128 Thu 2012/12/06 04:07:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:08:37 System -170001 [Network] Failed DNS 129 Thu 2012/12/06 04:08:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:09:37 System -170001 [Network] Failed DNS 130 Thu 2012/12/06 04:09:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:10:37 System -170001 [Network] Failed DNS 131 Thu 2012/12/06 04:10:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:11:37 System -170001 [Network] Failed DNS 132 Thu 2012/12/06 04:11:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:12:37 System -170001 [Network] Failed DNS 133 Thu 2012/12/06 04:12:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:13:37 System -170001 [Network] Failed DNS 134 Thu 2012/12/06 04:13:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:14:37 System -170001 [Network] Failed DNS 135 Thu 2012/12/06 04:14:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:15:37 System -170001 [Network] Failed DNS 136 Thu 2012/12/06 04:15:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:16:37 System -170001 [Network] Failed DNS 137 Thu 2012/12/06 04:16:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:17:37 System -170001 [Network] Failed DNS 138 Thu 2012/12/06 04:17:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:18:37 System -170001 [Network] Failed DNS 139 Thu 2012/12/06 04:18:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:19:36 System -170001 [Network] Failed DNS 140 Thu 2012/12/06 04:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:20:36 System -170001 [Network] Failed DNS 141 Thu 2012/12/06 04:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:21:36 System -170001 [Network] Failed DNS 142 Thu 2012/12/06 04:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:22:36 System -170001 [Network] Failed DNS 143 Thu 2012/12/06 04:22:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:23:36 System -170001 [Network] Failed DNS 144 Thu 2012/12/06 04:23:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:24:36 System -170001 [Network] Failed DNS 145 Thu 2012/12/06 04:24:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:25:36 System -170001 [Network] Failed DNS 146 Thu 2012/12/06 04:25:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:26:36 System -170001 [Network] Failed DNS 147 Thu 2012/12/06 04:26:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:27:37 System -170001 [Network] Failed DNS 148 Thu 2012/12/06 04:27:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:28:37 System -170001 [Network] Failed DNS 149 Thu 2012/12/06 04:28:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:29:37 System -170001 [Network] Failed DNS 150 Thu 2012/12/06 04:29:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:30:37 System -170001 [Network] Failed DNS 151 Thu 2012/12/06 04:30:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:31:37 System -170001 [Network] Failed DNS 152 Thu 2012/12/06 04:31:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:32:37 System -170001 [Network] Failed DNS 153 Thu 2012/12/06 04:32:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:33:37 System -170001 [Network] Failed DNS 154 Thu 2012/12/06 04:33:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:34:37 System -170001 [Network] Failed DNS 155 Thu 2012/12/06 04:34:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:35:37 System -170001 [Network] Failed DNS 156 Thu 2012/12/06 04:35:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:36:37 System -170001 [Network] Failed DNS 157 Thu 2012/12/06 04:36:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:37:36 System -170001 [Network] Failed DNS 158 Thu 2012/12/06 04:37:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:38:36 System -170001 [Network] Failed DNS 159 Thu 2012/12/06 04:38:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:39:36 System -170001 [Network] Failed DNS 160 Thu 2012/12/06 04:39:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:40:36 System -170001 [Network] Failed DNS 161 Thu 2012/12/06 04:40:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:41:36 System -170001 [Network] Failed DNS 162 Thu 2012/12/06 04:41:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:42:36 System -170001 [Network] Failed DNS 163 Thu 2012/12/06 04:42:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:43:36 System -170001 [Network] Failed DNS 164 Thu 2012/12/06 04:43:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:44:36 System -170001 [Network] Failed DNS 165 Thu 2012/12/06 04:44:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:45:36 System -170001 [Network] Failed DNS 166 Thu 2012/12/06 04:45:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:46:36 System -170001 [Network] Failed DNS 167 Thu 2012/12/06 04:46:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:47:37 System -170001 [Network] Failed DNS 168 Thu 2012/12/06 04:47:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:48:37 System -170001 [Network] Failed DNS 169 Thu 2012/12/06 04:48:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:49:37 System -170001 [Network] Failed DNS 170 Thu 2012/12/06 04:49:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:50:37 System -170001 [Network] Failed DNS 171 Thu 2012/12/06 04:50:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:51:37 System -170001 [Network] Failed DNS 172 Thu 2012/12/06 04:51:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:52:37 System -170001 [Network] Failed DNS 173 Thu 2012/12/06 04:52:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:53:37 System -170001 [Network] Failed DNS 174 Thu 2012/12/06 04:53:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:54:37 System -170001 [Network] Failed DNS 175 Thu 2012/12/06 04:54:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:55:37 System -170001 [Network] Failed DNS 176 Thu 2012/12/06 04:55:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:56:37 System -170001 [Network] Failed DNS 177 Thu 2012/12/06 04:56:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:57:37 System -170001 [Network] Failed DNS 178 Thu 2012/12/06 04:57:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:58:37 System -170001 [Network] Failed DNS 179 Thu 2012/12/06 04:58:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 04:59:36 System -170001 [Network] Failed DNS 180 Thu 2012/12/06 04:59:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:00:36 System -170001 [Network] Failed DNS 181 Thu 2012/12/06 05:00:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:01:36 System -170001 [Network] Failed DNS 182 Thu 2012/12/06 05:01:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:02:36 System -170001 [Network] Failed DNS 183 Thu 2012/12/06 05:02:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:03:36 System -170001 [Network] Failed DNS 184 Thu 2012/12/06 05:03:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:04:36 System -170001 [Network] Failed DNS 185 Thu 2012/12/06 05:04:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:05:36 System -170001 [Network] Failed DNS 186 Thu 2012/12/06 05:05:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:06:36 System -170001 [Network] Failed DNS 187 Thu 2012/12/06 05:06:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:07:37 System -170001 [Network] Failed DNS 188 Thu 2012/12/06 05:07:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:08:37 System -170001 [Network] Failed DNS 189 Thu 2012/12/06 05:08:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:09:37 System -170001 [Network] Failed DNS 190 Thu 2012/12/06 05:09:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:10:37 System -170001 [Network] Failed DNS 191 Thu 2012/12/06 05:10:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:11:37 System -170001 [Network] Failed DNS 192 Thu 2012/12/06 05:11:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:12:37 System -170001 [Network] Failed DNS 193 Thu 2012/12/06 05:12:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:13:37 System -170001 [Network] Failed DNS 194 Thu 2012/12/06 05:13:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:14:37 System -170001 [Network] Failed DNS 195 Thu 2012/12/06 05:14:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:15:37 System -170001 [Network] Failed DNS 196 Thu 2012/12/06 05:15:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:16:37 System -170001 [Network] Failed DNS 197 Thu 2012/12/06 05:16:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:17:36 System -170001 [Network] Failed DNS 198 Thu 2012/12/06 05:17:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:18:36 System -170001 [Network] Failed DNS 199 Thu 2012/12/06 05:18:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:19:36 System -170001 [Network] Failed DNS 200 Thu 2012/12/06 05:19:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:20:36 System -170001 [Network] Failed DNS 201 Thu 2012/12/06 05:20:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:21:36 System -170001 [Network] Failed DNS 202 Thu 2012/12/06 05:21:36 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:22:37 System -170001 [Network] Failed DNS 203 Thu 2012/12/06 05:22:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 05:23:37 System -170001 [Network] Failed DNS 204 Thu 2012/12/06 05:23:37 System -140000 datafeed.weatherbug.com Thu 2012/12/06 12:42:54 System -60006 n/a Thu 2012/12/06 12:43:10 System -60006 n/a Thu 2012/12/06 12:43:25 System -60006 n/a Thu 2012/12/06 12:43:40 System -60006 n/a Thu 2012/12/06 12:43:40 System -60006 Stopping retries/next cycle Thu 2012/12/06 14:10:18 System -10 n/a Thu 2012/12/06 18:25:44 System -140005 CLI-WBug Fri 2012/12/07 00:44:10 System -60006 n/a Fri 2012/12/07 00:44:25 System -60006 n/a Fri 2012/12/07 00:44:40 System -60006 n/a Fri 2012/12/07 00:44:55 System -60006 n/a Fri 2012/12/07 02:00:34 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:01:34 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:02:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:03:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:04:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:05:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 02:06:33 System -140000 datafeed.weatherbug.com Fri 2012/12/07 12:45:24 System -60006 n/a Fri 2012/12/07 12:45:24 System -60006 Stopping retries/next cycle Sat 2012/12/08 00:45:58 System -60006 n/a Sat 2012/12/08 00:46:13 System -60006 n/a Sat 2012/12/08 00:46:28 System -60006 n/a Sat 2012/12/08 00:46:43 System -60006 n/a Sat 2012/12/08 00:46:58 System -60006 n/a Sat 2012/12/08 00:47:13 System -60006 n/a Sat 2012/12/08 00:47:13 System -60006 Stopping retries/next cycle Sat 2012/12/08 02:00:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:01:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:02:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:03:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:04:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:05:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 02:06:38 System -140000 datafeed.weatherbug.com Sat 2012/12/08 12:47:43 System -60006 n/a Sat 2012/12/08 12:47:58 System -60006 n/a Sat 2012/12/08 12:48:13 System -60006 n/a Sat 2012/12/08 12:48:28 System -60006 n/a Sat 2012/12/08 12:48:43 System -60006 n/a Sat 2012/12/08 12:48:58 System -60006 n/a Sat 2012/12/08 12:48:58 System -60006 Stopping retries/next cycle Sun 2012/12/09 02:00:25 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:01:25 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:02:25 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:03:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:04:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:05:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 02:06:24 System -140000 datafeed.weatherbug.com Sun 2012/12/09 12:49:39 System -60006 n/a Sun 2012/12/09 12:49:55 System -60006 n/a Sun 2012/12/09 12:50:10 System -60006 n/a Sun 2012/12/09 12:50:25 System -60006 n/a Sun 2012/12/09 12:50:40 System -60006 n/a Sun 2012/12/09 12:50:40 System -60006 Stopping retries/next cycle Sun 2012/12/09 23:38:30 System -170001 [uDSockets] HTTP:24 error:6 Sun 2012/12/09 23:38:35 System -170001 [uDSockets] HTTP:24 error:6 Sun 2012/12/09 23:38:40 System -170001 [uDSockets] HTTP:24 error:6 Sun 2012/12/09 23:38:45 System -170001 [uDSockets] HTTP:24 error:6 Mon 2012/12/10 00:51:11 System -60006 n/a Mon 2012/12/10 00:51:26 System -60006 n/a Mon 2012/12/10 00:51:41 System -60006 n/a Mon 2012/12/10 00:51:56 System -60006 n/a Mon 2012/12/10 00:52:11 System -60006 n/a Mon 2012/12/10 00:52:07 System -60006 Stopping retries/next cycle Mon 2012/12/10 02:00:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:01:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:02:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:03:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:04:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:05:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 02:06:21 System -140000 datafeed.weatherbug.com Mon 2012/12/10 12:52:39 System -60006 n/a Mon 2012/12/10 12:52:54 System -60006 n/a Mon 2012/12/10 12:53:09 System -60006 n/a Tue 2012/12/11 02:00:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:01:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:02:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:03:17 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:04:16 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:05:16 System -140000 datafeed.weatherbug.com Tue 2012/12/11 02:06:16 System -140000 datafeed.weatherbug.com Tue 2012/12/11 08:25:21 System -140005 CLI-WBug Tue 2012/12/11 08:29:18 System -140005 CLI-WBug Tue 2012/12/11 08:37:20 System -140005 CLI-WBug Tue 2012/12/11 08:39:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug Tue 2012/12/11 08:41:18 System -140005 CLI-WBug Tue 2012/12/11 08:54:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug Tue 2012/12/11 08:55:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug Tue 2012/12/11 12:53:57 System -60006 n/a Tue 2012/12/11 12:53:57 System -60006 Stopping retries/next cycle Tue 2012/12/11 22:36:20 System -140000 datafeed.weatherbug.com Wed 2012/12/12 00:54:32 System -60006 n/a Wed 2012/12/12 00:54:47 System -60006 n/a Wed 2012/12/12 02:00:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:01:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:02:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:03:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:04:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:05:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 02:06:12 System -140000 datafeed.weatherbug.com Wed 2012/12/12 11:35:14 System -140005 CLI-WBug Wed 2012/12/12 12:55:17 System -60006 n/a Wed 2012/12/12 12:55:32 System -60006 n/a Wed 2012/12/12 12:55:47 System -60006 n/a Wed 2012/12/12 12:55:47 System -60006 Stopping retries/next cycle Thu 2012/12/13 00:56:19 System -60006 n/a Thu 2012/12/13 00:56:34 System -60006 n/a Thu 2012/12/13 00:56:49 System -60006 n/a Thu 2012/12/13 00:57:04 System -60006 n/a Thu 2012/12/13 00:57:19 System -60006 n/a Thu 2012/12/13 00:57:34 System -60006 n/a Thu 2012/12/13 00:57:34 System -60006 Stopping retries/next cycle Thu 2012/12/13 02:00:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:01:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:02:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:03:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:04:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:05:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 02:06:16 System -140000 datafeed.weatherbug.com Thu 2012/12/13 12:58:06 System -60006 n/a Thu 2012/12/13 12:58:21 System -60006 n/a Thu 2012/12/13 12:58:36 System -60006 n/a Thu 2012/12/13 12:58:51 System -60006 n/a Thu 2012/12/13 12:59:06 System -60006 n/a Thu 2012/12/13 12:59:21 System -60006 n/a Thu 2012/12/13 23:16:04 System -5 Start Thu 2012/12/13 23:16:08 System -170001 [Network] Established Thu 2012/12/13 23:16:18 System -60006 n/a Thu 2012/12/13 23:16:24 System -140000 datafeed.weatherbug.com Fri 2012/12/14 16:28:46 System -5 Start Fri 2012/12/14 16:28:50 System -170001 [Network] Established Fri 2012/12/14 16:29:00 System -60006 n/a Fri 2012/12/14 16:29:19 System -10011 n/a Fri 2012/12/14 16:43:58 System -5 Start
December 16, 201212 yr Author Hi Mark, There are two problems: 1. There are major network issues especially those involving DNS resolution 2. I think your file system is getting corrupted Above two have nothing to do with one another. My recommendation: 1. If your ISY is setup with a static IP address, I strongly recommend going back to DHCP 2. Take a good backup and then upgrade to 3.3.6 With kind regards, Michel
December 16, 201212 yr Michel, Thanks for your suggestions. I did switch back to DHCP but now I am receiving the following Errors when I try to log into my ISY: http://forum.universal-devices.com/download/file.php?mode=view&id=767 I can no longer access the ISY via a browser but I am able to access the ISY Shell via Telnet. Would I be better off doing a Factory Reset, I do have a good backup available. Any thoughts??
December 16, 201212 yr Author Hi Mark, the problem is that the UI files were not installed properly. I do think that your SD Card is dying. In the meantime, please try using the following URL: http://www.universal-devices.com/99i/3.3.6/admin.jnlp With kind regards, Michel
December 16, 201212 yr Michel, Ok, thanks so if I replace the SD card how do I go about adding the necessary software? Also, is the SD Card a standard card?
December 16, 201212 yr Author Hi Mark, The first question is whether or not the link I sent works. Here's the link: http://wiki.universal-devices.com/index ... an_SD_Card With kind regards, Michel
December 16, 201212 yr Michel, The link did NOT work but I'm still able to Telnet into the ISY. I pulled out the SD Card and ran a scan on it and here are the results:
December 16, 201212 yr . . . Here's the link: http://wiki.universal-devices.com/index ... an_SD_Card . . . I issued "FS" via ISY Shell but I didn't receive the GoodBye response. I am assuming that it shouldn't take more than a few minutes to format a 512mb SD Card, correct?
December 16, 201212 yr Author Hi Mark, What type of error do you get when you use that link? With kind regards, Michel
December 16, 201212 yr Hi Mark, What type of error do you get when you use that link? With kind regards, Michel I get an Error message box and then the Insteon Finder form opens. I added the ip Address of my ISY and then I get the following errors again:
December 16, 201212 yr Author If you can still telnet to ISY (i.e. you know ISY's IP address), then click the Add button in ISY Finder, and then enter the full URL for your ISY (including http). With kind regards, Michel
December 16, 201212 yr After a full 8 hours of working on this today, I was finally able to get my ISY back up and running. Thanks for your help!
December 17, 201212 yr Author Hi Mark, when you get a chance, can you tell me what you did to recover that took 8 hours? Just trying to figure out how we can optimize recovery. With kind regards, Michel
