Release 3.3.4 (RC1) Is Now Available
The 3.3.4 release does not have support for the Dual Band KPL Relay device type.
Thanks for the info - I found this thread, looks like it's not an isolated issue:
http://forum.universal-devices.com/viewtopic.php?f=27&t=6922&start=15
Yes there are several of us with the same issue. I think LeeG's comment would have been better worded "The 3.3.4 release has broken support for ..." since it did work in 3.2.6 and at least one user has reported that it starts working again when he downgraded his ISY back to 3.2.6.
Vyrolan,
No, not true. LeeG's comment is 100% true:
viewtopic.php?f=28&t=10009&p=75777#p75777
For non-I2CS devices, we used to allow devices to be added by forcing their type. Releases 3.3.x do not allow you to add device X as device Y. We can debate whether or not this should be the case, but we did have multiple support issues + I2CS things that propelled us to take this direction.
Aha...so I guess it working before or for those who have downgraded is just a very lucky coincidence. =) It definitely makes sense not to munge the device types since I'm sure it can cause all sorts of fun problems when you send or receive commands you don't expect. =p
Hello All,
Update went fine on windows,I cannot get the admin console short cut on my mac.I cleared my cache,I am running Lion 10.7.5, java 1.7.I removed certificate.Any suggestions? :(
Thanks Tim
All --
I started to notice problems connecting to my ISY via the MobilLinc iPhone App last Wednesday (Dec 12th) but I figured it just needed a re-boot so I pulled the plug and plugged it back in after about 20 seconds or so. That seemed to fix the problem then the next two days I have not been able to connect to the ISY via a browser or the MobiLinc App. After examining the error log I noticed that something has been happening since December 3, 2012.
The only way I can access the ISY Admin screen is to unplug the ISY and then I can log in. Upon logging in the ISY starts to scan all of the linked devices after which I get the following message box:
file.php?mode=view&id=762&sid=61e0062bc77a5b2ae8868fab433d08ef
and then I get this message box:
file.php?mode=view&id=764&sid=61e0062bc77a5b2ae8868fab433d08ef
Any thoughts??
Here is a screen shot of my About Page:
file.php?mode=view&id=763&sid=61e0062bc77a5b2ae8868fab433d08ef
Java Runtime Version - 1.7.0_4
Here is a printout of the error log:
Mon 2012/12/03 02:04:49 System -140000 datafeed.weatherbug.com
Mon 2012/12/03 02:05:49 System -140000 datafeed.weatherbug.com
Mon 2012/12/03 08:21:43 System -5012 162
Tue 2012/12/04 00:39:07 System -60006 n/a
Tue 2012/12/04 00:39:22 System -60006 n/a
Tue 2012/12/04 00:39:37 System -60006 n/a
Tue 2012/12/04 02:00:46 System -140000 datafeed.weatherbug.com
Tue 2012/12/04 02:01:46 System -140000 datafeed.weatherbug.com
Tue 2012/12/04 02:02:46 System -140000 datafeed.weatherbug.com
Tue 2012/12/04 02:03:45 System -140000 datafeed.weatherbug.com
Tue 2012/12/04 02:04:45 System -140000 datafeed.weatherbug.com
Tue 2012/12/04 02:05:45 System -140000 datafeed.weatherbug.com
Tue 2012/12/04 12:40:08 System -60006 n/a
Tue 2012/12/04 12:40:08 System -60006 Stopping retries/next cycle
Wed 2012/12/05 00:40:40 System -60006 n/a
Wed 2012/12/05 00:40:55 System -60006 n/a
Wed 2012/12/05 00:41:10 System -60006 n/a
Wed 2012/12/05 02:00:40 System -140000 datafeed.weatherbug.com
Wed 2012/12/05 02:01:40 System -140000 datafeed.weatherbug.com
Wed 2012/12/05 02:02:40 System -140000 datafeed.weatherbug.com
Wed 2012/12/05 02:03:40 System -140000 datafeed.weatherbug.com
Wed 2012/12/05 02:04:40 System -140000 datafeed.weatherbug.com
Wed 2012/12/05 02:05:40 System -140000 datafeed.weatherbug.com
Wed 2012/12/05 12:41:39 System -60006 n/a
Wed 2012/12/05 12:41:54 System -60006 n/a
Wed 2012/12/05 12:41:54 System -60006 Stopping retries/next cycle
Thu 2012/12/06 00:42:27 System -60006 n/a
Thu 2012/12/06 02:00:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:01:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:02:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:03:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:04:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:05:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:06:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:07:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:08:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:09:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:10:37 System -170001 [Network] Failed DNS 11
Thu 2012/12/06 02:10:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:11:37 System -170001 [Network] Failed DNS 12
Thu 2012/12/06 02:11:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:12:36 System -170001 [Network] Failed DNS 13
Thu 2012/12/06 02:12:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:13:36 System -170001 [Network] Failed DNS 14
Thu 2012/12/06 02:13:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:14:36 System -170001 [Network] Failed DNS 15
Thu 2012/12/06 02:14:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:15:36 System -170001 [Network] Failed DNS 16
Thu 2012/12/06 02:15:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:16:36 System -170001 [Network] Failed DNS 17
Thu 2012/12/06 02:16:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:17:36 System -170001 [Network] Failed DNS 18
Thu 2012/12/06 02:17:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:18:36 System -170001 [Network] Failed DNS 19
Thu 2012/12/06 02:18:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:19:36 System -170001 [Network] Failed DNS 20
Thu 2012/12/06 02:19:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:20:36 System -170001 [Network] Failed DNS 21
Thu 2012/12/06 02:20:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:21:36 System -170001 [Network] Failed DNS 22
Thu 2012/12/06 02:21:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:22:36 System -170001 [Network] Failed DNS 23
Thu 2012/12/06 02:22:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:23:36 System -170001 [Network] Failed DNS 24
Thu 2012/12/06 02:23:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:24:35 System -170001 [Network] Failed DNS 25
Thu 2012/12/06 02:24:35 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:25:35 System -170001 [Network] Failed DNS 26
Thu 2012/12/06 02:25:35 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:26:35 System -170001 [Network] Failed DNS 27
Thu 2012/12/06 02:26:35 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:27:36 System -170001 [Network] Failed DNS 28
Thu 2012/12/06 02:27:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:28:36 System -170001 [Network] Failed DNS 29
Thu 2012/12/06 02:28:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:29:36 System -170001 [Network] Failed DNS 30
Thu 2012/12/06 02:29:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:30:36 System -170001 [Network] Failed DNS 31
Thu 2012/12/06 02:30:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:31:36 System -170001 [Network] Failed DNS 32
Thu 2012/12/06 02:31:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:32:36 System -170001 [Network] Failed DNS 33
Thu 2012/12/06 02:32:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:33:36 System -170001 [Network] Failed DNS 34
Thu 2012/12/06 02:33:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:34:36 System -170001 [Network] Failed DNS 35
Thu 2012/12/06 02:34:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:35:36 System -170001 [Network] Failed DNS 36
Thu 2012/12/06 02:35:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:36:36 System -170001 [Network] Failed DNS 37
Thu 2012/12/06 02:36:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:37:36 System -170001 [Network] Failed DNS 38
Thu 2012/12/06 02:37:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:38:36 System -170001 [Network] Failed DNS 39
Thu 2012/12/06 02:38:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:39:36 System -170001 [Network] Failed DNS 40
Thu 2012/12/06 02:39:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:40:36 System -170001 [Network] Failed DNS 41
Thu 2012/12/06 02:40:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:41:36 System -170001 [Network] Failed DNS 42
Thu 2012/12/06 02:41:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:42:36 System -170001 [Network] Failed DNS 43
Thu 2012/12/06 02:42:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:43:36 System -170001 [Network] Failed DNS 44
Thu 2012/12/06 02:43:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:44:36 System -170001 [Network] Failed DNS 45
Thu 2012/12/06 02:44:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:45:36 System -170001 [Network] Failed DNS 46
Thu 2012/12/06 02:45:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:46:36 System -170001 [Network] Failed DNS 47
Thu 2012/12/06 02:46:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:47:36 System -170001 [Network] Failed DNS 48
Thu 2012/12/06 02:47:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:48:36 System -170001 [Network] Failed DNS 49
Thu 2012/12/06 02:48:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:49:36 System -170001 [Network] Failed DNS 50
Thu 2012/12/06 02:49:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:50:36 System -170001 [Network] Failed DNS 51
Thu 2012/12/06 02:50:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:51:36 System -170001 [Network] Failed DNS 52
Thu 2012/12/06 02:51:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:52:37 System -170001 [Network] Failed DNS 53
Thu 2012/12/06 02:52:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:53:37 System -170001 [Network] Failed DNS 54
Thu 2012/12/06 02:53:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:54:37 System -170001 [Network] Failed DNS 55
Thu 2012/12/06 02:54:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:55:37 System -170001 [Network] Failed DNS 56
Thu 2012/12/06 02:55:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:56:37 System -170001 [Network] Failed DNS 57
Thu 2012/12/06 02:56:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:57:37 System -170001 [Network] Failed DNS 58
Thu 2012/12/06 02:57:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:58:37 System -170001 [Network] Failed DNS 59
Thu 2012/12/06 02:58:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 02:59:37 System -170001 [Network] Failed DNS 60
Thu 2012/12/06 02:59:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:00:37 System -170001 [Network] Failed DNS 61
Thu 2012/12/06 03:00:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:01:37 System -170001 [Network] Failed DNS 62
Thu 2012/12/06 03:01:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:02:36 System -170001 [Network] Failed DNS 63
Thu 2012/12/06 03:02:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:03:36 System -170001 [Network] Failed DNS 64
Thu 2012/12/06 03:03:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:04:36 System -170001 [Network] Failed DNS 65
Thu 2012/12/06 03:04:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:05:36 System -170001 [Network] Failed DNS 66
Thu 2012/12/06 03:05:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:06:36 System -170001 [Network] Failed DNS 67
Thu 2012/12/06 03:06:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:07:36 System -170001 [Network] Failed DNS 68
Thu 2012/12/06 03:07:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:08:36 System -170001 [Network] Failed DNS 69
Thu 2012/12/06 03:08:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:09:36 System -170001 [Network] Failed DNS 70
Thu 2012/12/06 03:09:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:10:36 System -170001 [Network] Failed DNS 71
Thu 2012/12/06 03:10:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:11:36 System -170001 [Network] Failed DNS 72
Thu 2012/12/06 03:11:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:12:36 System -170001 [Network] Failed DNS 73
Thu 2012/12/06 03:12:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:13:36 System -170001 [Network] Failed DNS 74
Thu 2012/12/06 03:13:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:14:36 System -170001 [Network] Failed DNS 75
Thu 2012/12/06 03:14:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:15:36 System -170001 [Network] Failed DNS 76
Thu 2012/12/06 03:15:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:16:36 System -170001 [Network] Failed DNS 77
Thu 2012/12/06 03:16:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:17:36 System -170001 [Network] Failed DNS 78
Thu 2012/12/06 03:17:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:18:36 System -170001 [Network] Failed DNS 79
Thu 2012/12/06 03:18:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:19:36 System -170001 [Network] Failed DNS 80
Thu 2012/12/06 03:19:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:20:36 System -170001 [Network] Failed DNS 81
Thu 2012/12/06 03:20:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:21:36 System -170001 [Network] Failed DNS 82
Thu 2012/12/06 03:21:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:22:36 System -170001 [Network] Failed DNS 83
Thu 2012/12/06 03:22:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:23:36 System -170001 [Network] Failed DNS 84
Thu 2012/12/06 03:23:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:24:36 System -170001 [Network] Failed DNS 85
Thu 2012/12/06 03:24:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:25:36 System -170001 [Network] Failed DNS 86
Thu 2012/12/06 03:25:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:26:36 System -170001 [Network] Failed DNS 87
Thu 2012/12/06 03:26:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:27:37 System -170001 [Network] Failed DNS 88
Thu 2012/12/06 03:27:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:28:37 System -170001 [Network] Failed DNS 89
Thu 2012/12/06 03:28:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:29:37 System -170001 [Network] Failed DNS 90
Thu 2012/12/06 03:29:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:30:37 System -170001 [Network] Failed DNS 91
Thu 2012/12/06 03:30:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:31:37 System -170001 [Network] Failed DNS 92
Thu 2012/12/06 03:31:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:32:37 System -170001 [Network] Failed DNS 93
Thu 2012/12/06 03:32:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:33:37 System -170001 [Network] Failed DNS 94
Thu 2012/12/06 03:33:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:34:37 System -170001 [Network] Failed DNS 95
Thu 2012/12/06 03:34:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:35:37 System -170001 [Network] Failed DNS 96
Thu 2012/12/06 03:35:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:36:37 System -170001 [Network] Failed DNS 97
Thu 2012/12/06 03:36:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:37:37 System -170001 [Network] Failed DNS 98
Thu 2012/12/06 03:37:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:38:37 System -170001 [Network] Failed DNS 99
Thu 2012/12/06 03:38:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:39:37 System -170001 [Network] Failed DNS 100
Thu 2012/12/06 03:39:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:40:37 System -170001 [Network] Failed DNS 101
Thu 2012/12/06 03:40:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:41:37 System -170001 [Network] Failed DNS 102
Thu 2012/12/06 03:41:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:42:36 System -170001 [Network] Failed DNS 103
Thu 2012/12/06 03:42:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:43:36 System -170001 [Network] Failed DNS 104
Thu 2012/12/06 03:43:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:44:36 System -170001 [Network] Failed DNS 105
Thu 2012/12/06 03:44:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:45:36 System -170001 [Network] Failed DNS 106
Thu 2012/12/06 03:45:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:46:36 System -170001 [Network] Failed DNS 107
Thu 2012/12/06 03:46:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:47:36 System -170001 [Network] Failed DNS 108
Thu 2012/12/06 03:47:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:48:36 System -170001 [Network] Failed DNS 109
Thu 2012/12/06 03:48:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:49:36 System -170001 [Network] Failed DNS 110
Thu 2012/12/06 03:49:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:50:36 System -170001 [Network] Failed DNS 111
Thu 2012/12/06 03:50:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:51:36 System -170001 [Network] Failed DNS 112
Thu 2012/12/06 03:51:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:52:36 System -170001 [Network] Failed DNS 113
Thu 2012/12/06 03:52:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:53:36 System -170001 [Network] Failed DNS 114
Thu 2012/12/06 03:53:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:54:36 System -170001 [Network] Failed DNS 115
Thu 2012/12/06 03:54:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:55:36 System -170001 [Network] Failed DNS 116
Thu 2012/12/06 03:55:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:56:36 System -170001 [Network] Failed DNS 117
Thu 2012/12/06 03:56:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:57:36 System -170001 [Network] Failed DNS 118
Thu 2012/12/06 03:57:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:58:36 System -170001 [Network] Failed DNS 119
Thu 2012/12/06 03:58:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 03:59:36 System -170001 [Network] Failed DNS 120
Thu 2012/12/06 03:59:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:00:36 System -170001 [Network] Failed DNS 121
Thu 2012/12/06 04:00:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:01:36 System -170001 [Network] Failed DNS 122
Thu 2012/12/06 04:01:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:02:36 System -170001 [Network] Failed DNS 123
Thu 2012/12/06 04:02:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:03:36 System -170001 [Network] Failed DNS 124
Thu 2012/12/06 04:03:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:04:36 System -170001 [Network] Failed DNS 125
Thu 2012/12/06 04:04:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:05:36 System -170001 [Network] Failed DNS 126
Thu 2012/12/06 04:05:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:06:36 System -170001 [Network] Failed DNS 127
Thu 2012/12/06 04:06:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:07:37 System -170001 [Network] Failed DNS 128
Thu 2012/12/06 04:07:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:08:37 System -170001 [Network] Failed DNS 129
Thu 2012/12/06 04:08:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:09:37 System -170001 [Network] Failed DNS 130
Thu 2012/12/06 04:09:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:10:37 System -170001 [Network] Failed DNS 131
Thu 2012/12/06 04:10:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:11:37 System -170001 [Network] Failed DNS 132
Thu 2012/12/06 04:11:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:12:37 System -170001 [Network] Failed DNS 133
Thu 2012/12/06 04:12:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:13:37 System -170001 [Network] Failed DNS 134
Thu 2012/12/06 04:13:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:14:37 System -170001 [Network] Failed DNS 135
Thu 2012/12/06 04:14:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:15:37 System -170001 [Network] Failed DNS 136
Thu 2012/12/06 04:15:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:16:37 System -170001 [Network] Failed DNS 137
Thu 2012/12/06 04:16:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:17:37 System -170001 [Network] Failed DNS 138
Thu 2012/12/06 04:17:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:18:37 System -170001 [Network] Failed DNS 139
Thu 2012/12/06 04:18:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:19:36 System -170001 [Network] Failed DNS 140
Thu 2012/12/06 04:19:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:20:36 System -170001 [Network] Failed DNS 141
Thu 2012/12/06 04:20:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:21:36 System -170001 [Network] Failed DNS 142
Thu 2012/12/06 04:21:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:22:36 System -170001 [Network] Failed DNS 143
Thu 2012/12/06 04:22:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:23:36 System -170001 [Network] Failed DNS 144
Thu 2012/12/06 04:23:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:24:36 System -170001 [Network] Failed DNS 145
Thu 2012/12/06 04:24:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:25:36 System -170001 [Network] Failed DNS 146
Thu 2012/12/06 04:25:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:26:36 System -170001 [Network] Failed DNS 147
Thu 2012/12/06 04:26:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:27:37 System -170001 [Network] Failed DNS 148
Thu 2012/12/06 04:27:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:28:37 System -170001 [Network] Failed DNS 149
Thu 2012/12/06 04:28:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:29:37 System -170001 [Network] Failed DNS 150
Thu 2012/12/06 04:29:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:30:37 System -170001 [Network] Failed DNS 151
Thu 2012/12/06 04:30:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:31:37 System -170001 [Network] Failed DNS 152
Thu 2012/12/06 04:31:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:32:37 System -170001 [Network] Failed DNS 153
Thu 2012/12/06 04:32:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:33:37 System -170001 [Network] Failed DNS 154
Thu 2012/12/06 04:33:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:34:37 System -170001 [Network] Failed DNS 155
Thu 2012/12/06 04:34:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:35:37 System -170001 [Network] Failed DNS 156
Thu 2012/12/06 04:35:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:36:37 System -170001 [Network] Failed DNS 157
Thu 2012/12/06 04:36:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:37:36 System -170001 [Network] Failed DNS 158
Thu 2012/12/06 04:37:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:38:36 System -170001 [Network] Failed DNS 159
Thu 2012/12/06 04:38:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:39:36 System -170001 [Network] Failed DNS 160
Thu 2012/12/06 04:39:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:40:36 System -170001 [Network] Failed DNS 161
Thu 2012/12/06 04:40:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:41:36 System -170001 [Network] Failed DNS 162
Thu 2012/12/06 04:41:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:42:36 System -170001 [Network] Failed DNS 163
Thu 2012/12/06 04:42:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:43:36 System -170001 [Network] Failed DNS 164
Thu 2012/12/06 04:43:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:44:36 System -170001 [Network] Failed DNS 165
Thu 2012/12/06 04:44:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:45:36 System -170001 [Network] Failed DNS 166
Thu 2012/12/06 04:45:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:46:36 System -170001 [Network] Failed DNS 167
Thu 2012/12/06 04:46:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:47:37 System -170001 [Network] Failed DNS 168
Thu 2012/12/06 04:47:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:48:37 System -170001 [Network] Failed DNS 169
Thu 2012/12/06 04:48:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:49:37 System -170001 [Network] Failed DNS 170
Thu 2012/12/06 04:49:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:50:37 System -170001 [Network] Failed DNS 171
Thu 2012/12/06 04:50:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:51:37 System -170001 [Network] Failed DNS 172
Thu 2012/12/06 04:51:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:52:37 System -170001 [Network] Failed DNS 173
Thu 2012/12/06 04:52:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:53:37 System -170001 [Network] Failed DNS 174
Thu 2012/12/06 04:53:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:54:37 System -170001 [Network] Failed DNS 175
Thu 2012/12/06 04:54:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:55:37 System -170001 [Network] Failed DNS 176
Thu 2012/12/06 04:55:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:56:37 System -170001 [Network] Failed DNS 177
Thu 2012/12/06 04:56:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:57:37 System -170001 [Network] Failed DNS 178
Thu 2012/12/06 04:57:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:58:37 System -170001 [Network] Failed DNS 179
Thu 2012/12/06 04:58:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 04:59:36 System -170001 [Network] Failed DNS 180
Thu 2012/12/06 04:59:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:00:36 System -170001 [Network] Failed DNS 181
Thu 2012/12/06 05:00:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:01:36 System -170001 [Network] Failed DNS 182
Thu 2012/12/06 05:01:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:02:36 System -170001 [Network] Failed DNS 183
Thu 2012/12/06 05:02:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:03:36 System -170001 [Network] Failed DNS 184
Thu 2012/12/06 05:03:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:04:36 System -170001 [Network] Failed DNS 185
Thu 2012/12/06 05:04:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:05:36 System -170001 [Network] Failed DNS 186
Thu 2012/12/06 05:05:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:06:36 System -170001 [Network] Failed DNS 187
Thu 2012/12/06 05:06:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:07:37 System -170001 [Network] Failed DNS 188
Thu 2012/12/06 05:07:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:08:37 System -170001 [Network] Failed DNS 189
Thu 2012/12/06 05:08:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:09:37 System -170001 [Network] Failed DNS 190
Thu 2012/12/06 05:09:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:10:37 System -170001 [Network] Failed DNS 191
Thu 2012/12/06 05:10:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:11:37 System -170001 [Network] Failed DNS 192
Thu 2012/12/06 05:11:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:12:37 System -170001 [Network] Failed DNS 193
Thu 2012/12/06 05:12:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:13:37 System -170001 [Network] Failed DNS 194
Thu 2012/12/06 05:13:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:14:37 System -170001 [Network] Failed DNS 195
Thu 2012/12/06 05:14:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:15:37 System -170001 [Network] Failed DNS 196
Thu 2012/12/06 05:15:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:16:37 System -170001 [Network] Failed DNS 197
Thu 2012/12/06 05:16:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:17:36 System -170001 [Network] Failed DNS 198
Thu 2012/12/06 05:17:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:18:36 System -170001 [Network] Failed DNS 199
Thu 2012/12/06 05:18:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:19:36 System -170001 [Network] Failed DNS 200
Thu 2012/12/06 05:19:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:20:36 System -170001 [Network] Failed DNS 201
Thu 2012/12/06 05:20:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:21:36 System -170001 [Network] Failed DNS 202
Thu 2012/12/06 05:21:36 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:22:37 System -170001 [Network] Failed DNS 203
Thu 2012/12/06 05:22:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 05:23:37 System -170001 [Network] Failed DNS 204
Thu 2012/12/06 05:23:37 System -140000 datafeed.weatherbug.com
Thu 2012/12/06 12:42:54 System -60006 n/a
Thu 2012/12/06 12:43:10 System -60006 n/a
Thu 2012/12/06 12:43:25 System -60006 n/a
Thu 2012/12/06 12:43:40 System -60006 n/a
Thu 2012/12/06 12:43:40 System -60006 Stopping retries/next cycle
Thu 2012/12/06 14:10:18 System -10 n/a
Thu 2012/12/06 18:25:44 System -140005 CLI-WBug
Fri 2012/12/07 00:44:10 System -60006 n/a
Fri 2012/12/07 00:44:25 System -60006 n/a
Fri 2012/12/07 00:44:40 System -60006 n/a
Fri 2012/12/07 00:44:55 System -60006 n/a
Fri 2012/12/07 02:00:34 System -140000 datafeed.weatherbug.com
Fri 2012/12/07 02:01:34 System -140000 datafeed.weatherbug.com
Fri 2012/12/07 02:02:33 System -140000 datafeed.weatherbug.com
Fri 2012/12/07 02:03:33 System -140000 datafeed.weatherbug.com
Fri 2012/12/07 02:04:33 System -140000 datafeed.weatherbug.com
Fri 2012/12/07 02:05:33 System -140000 datafeed.weatherbug.com
Fri 2012/12/07 02:06:33 System -140000 datafeed.weatherbug.com
Fri 2012/12/07 12:45:24 System -60006 n/a
Fri 2012/12/07 12:45:24 System -60006 Stopping retries/next cycle
Sat 2012/12/08 00:45:58 System -60006 n/a
Sat 2012/12/08 00:46:13 System -60006 n/a
Sat 2012/12/08 00:46:28 System -60006 n/a
Sat 2012/12/08 00:46:43 System -60006 n/a
Sat 2012/12/08 00:46:58 System -60006 n/a
Sat 2012/12/08 00:47:13 System -60006 n/a
Sat 2012/12/08 00:47:13 System -60006 Stopping retries/next cycle
Sat 2012/12/08 02:00:38 System -140000 datafeed.weatherbug.com
Sat 2012/12/08 02:01:38 System -140000 datafeed.weatherbug.com
Sat 2012/12/08 02:02:38 System -140000 datafeed.weatherbug.com
Sat 2012/12/08 02:03:38 System -140000 datafeed.weatherbug.com
Sat 2012/12/08 02:04:38 System -140000 datafeed.weatherbug.com
Sat 2012/12/08 02:05:38 System -140000 datafeed.weatherbug.com
Sat 2012/12/08 02:06:38 System -140000 datafeed.weatherbug.com
Sat 2012/12/08 12:47:43 System -60006 n/a
Sat 2012/12/08 12:47:58 System -60006 n/a
Sat 2012/12/08 12:48:13 System -60006 n/a
Sat 2012/12/08 12:48:28 System -60006 n/a
Sat 2012/12/08 12:48:43 System -60006 n/a
Sat 2012/12/08 12:48:58 System -60006 n/a
Sat 2012/12/08 12:48:58 System -60006 Stopping retries/next cycle
Sun 2012/12/09 02:00:25 System -140000 datafeed.weatherbug.com
Sun 2012/12/09 02:01:25 System -140000 datafeed.weatherbug.com
Sun 2012/12/09 02:02:25 System -140000 datafeed.weatherbug.com
Sun 2012/12/09 02:03:24 System -140000 datafeed.weatherbug.com
Sun 2012/12/09 02:04:24 System -140000 datafeed.weatherbug.com
Sun 2012/12/09 02:05:24 System -140000 datafeed.weatherbug.com
Sun 2012/12/09 02:06:24 System -140000 datafeed.weatherbug.com
Sun 2012/12/09 12:49:39 System -60006 n/a
Sun 2012/12/09 12:49:55 System -60006 n/a
Sun 2012/12/09 12:50:10 System -60006 n/a
Sun 2012/12/09 12:50:25 System -60006 n/a
Sun 2012/12/09 12:50:40 System -60006 n/a
Sun 2012/12/09 12:50:40 System -60006 Stopping retries/next cycle
Sun 2012/12/09 23:38:30 System -170001 [uDSockets] HTTP:24 error:6
Sun 2012/12/09 23:38:35 System -170001 [uDSockets] HTTP:24 error:6
Sun 2012/12/09 23:38:40 System -170001 [uDSockets] HTTP:24 error:6
Sun 2012/12/09 23:38:45 System -170001 [uDSockets] HTTP:24 error:6
Mon 2012/12/10 00:51:11 System -60006 n/a
Mon 2012/12/10 00:51:26 System -60006 n/a
Mon 2012/12/10 00:51:41 System -60006 n/a
Mon 2012/12/10 00:51:56 System -60006 n/a
Mon 2012/12/10 00:52:11 System -60006 n/a
Mon 2012/12/10 00:52:07 System -60006 Stopping retries/next cycle
Mon 2012/12/10 02:00:21 System -140000 datafeed.weatherbug.com
Mon 2012/12/10 02:01:21 System -140000 datafeed.weatherbug.com
Mon 2012/12/10 02:02:21 System -140000 datafeed.weatherbug.com
Mon 2012/12/10 02:03:21 System -140000 datafeed.weatherbug.com
Mon 2012/12/10 02:04:21 System -140000 datafeed.weatherbug.com
Mon 2012/12/10 02:05:21 System -140000 datafeed.weatherbug.com
Mon 2012/12/10 02:06:21 System -140000 datafeed.weatherbug.com
Mon 2012/12/10 12:52:39 System -60006 n/a
Mon 2012/12/10 12:52:54 System -60006 n/a
Mon 2012/12/10 12:53:09 System -60006 n/a
Tue 2012/12/11 02:00:17 System -140000 datafeed.weatherbug.com
Tue 2012/12/11 02:01:17 System -140000 datafeed.weatherbug.com
Tue 2012/12/11 02:02:17 System -140000 datafeed.weatherbug.com
Tue 2012/12/11 02:03:17 System -140000 datafeed.weatherbug.com
Tue 2012/12/11 02:04:16 System -140000 datafeed.weatherbug.com
Tue 2012/12/11 02:05:16 System -140000 datafeed.weatherbug.com
Tue 2012/12/11 02:06:16 System -140000 datafeed.weatherbug.com
Tue 2012/12/11 08:25:21 System -140005 CLI-WBug
Tue 2012/12/11 08:29:18 System -140005 CLI-WBug
Tue 2012/12/11 08:37:20 System -140005 CLI-WBug
Tue 2012/12/11 08:39:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug
Tue 2012/12/11 08:41:18 System -140005 CLI-WBug
Tue 2012/12/11 08:54:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug
Tue 2012/12/11 08:55:17 System -170001 [TCP-Conn] -1/-140002, CLI-WBug
Tue 2012/12/11 12:53:57 System -60006 n/a
Tue 2012/12/11 12:53:57 System -60006 Stopping retries/next cycle
Tue 2012/12/11 22:36:20 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 00:54:32 System -60006 n/a
Wed 2012/12/12 00:54:47 System -60006 n/a
Wed 2012/12/12 02:00:12 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 02:01:12 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 02:02:12 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 02:03:12 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 02:04:12 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 02:05:12 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 02:06:12 System -140000 datafeed.weatherbug.com
Wed 2012/12/12 11:35:14 System -140005 CLI-WBug
Wed 2012/12/12 12:55:17 System -60006 n/a
Wed 2012/12/12 12:55:32 System -60006 n/a
Wed 2012/12/12 12:55:47 System -60006 n/a
Wed 2012/12/12 12:55:47 System -60006 Stopping retries/next cycle
Thu 2012/12/13 00:56:19 System -60006 n/a
Thu 2012/12/13 00:56:34 System -60006 n/a
Thu 2012/12/13 00:56:49 System -60006 n/a
Thu 2012/12/13 00:57:04 System -60006 n/a
Thu 2012/12/13 00:57:19 System -60006 n/a
Thu 2012/12/13 00:57:34 System -60006 n/a
Thu 2012/12/13 00:57:34 System -60006 Stopping retries/next cycle
Thu 2012/12/13 02:00:16 System -140000 datafeed.weatherbug.com
Thu 2012/12/13 02:01:16 System -140000 datafeed.weatherbug.com
Thu 2012/12/13 02:02:16 System -140000 datafeed.weatherbug.com
Thu 2012/12/13 02:03:16 System -140000 datafeed.weatherbug.com
Thu 2012/12/13 02:04:16 System -140000 datafeed.weatherbug.com
Thu 2012/12/13 02:05:16 System -140000 datafeed.weatherbug.com
Thu 2012/12/13 02:06:16 System -140000 datafeed.weatherbug.com
Thu 2012/12/13 12:58:06 System -60006 n/a
Thu 2012/12/13 12:58:21 System -60006 n/a
Thu 2012/12/13 12:58:36 System -60006 n/a
Thu 2012/12/13 12:58:51 System -60006 n/a
Thu 2012/12/13 12:59:06 System -60006 n/a
Thu 2012/12/13 12:59:21 System -60006 n/a
Thu 2012/12/13 23:16:04 System -5 Start
Thu 2012/12/13 23:16:08 System -170001 [Network] Established
Thu 2012/12/13 23:16:18 System -60006 n/a
Thu 2012/12/13 23:16:24 System -140000 datafeed.weatherbug.com
Fri 2012/12/14 16:28:46 System -5 Start
Fri 2012/12/14 16:28:50 System -170001 [Network] Established
Fri 2012/12/14 16:29:00 System -60006 n/a
Fri 2012/12/14 16:29:19 System -10011 n/a
Fri 2012/12/14 16:43:58 System -5 Start
Hi Mark,
There are two problems:
1. There are major network issues especially those involving DNS resolution
2. I think your file system is getting corrupted
Above two have nothing to do with one another.
My recommendation:
1. If your ISY is setup with a static IP address, I strongly recommend going back to DHCP
2. Take a good backup and then upgrade to 3.3.6
Michel,
Thanks for your suggestions. I did switch back to DHCP but now I am receiving the following Errors when I try to log into my ISY:
http://forum.universal-devices.com/download/file.php?mode=view&id=767
I can no longer access the ISY via a browser but I am able to access the ISY Shell via Telnet. Would I be better off doing a Factory Reset, I do have a good backup available. Any thoughts??
Michel,
Ok, thanks so if I replace the SD card how do I go about adding the necessary software? Also, is the SD Card a standard card?
Michel,
The link did NOT work but I'm still able to Telnet into the ISY. I pulled out the SD Card and ran a scan on it and here are the results:
file.php?mode=view&id=770
Hi Mark,
What type of error do you get when you use that link?
I get an Error message box and then the Insteon Finder form opens.
file.php?mode=view&id=776&sid=d589db801ea791e2f67a7796c2ae2903
I added the ip Address of my ISY and then I get the following errors again:
file.php?mode=view&id=777&sid=d589db801ea791e2f67a7796c2ae2903
After a full 8 hours of working on this today, I was finally able to get my ISY back up and running.
Thanks for your help!
