Release 3.3.4 (RC1) Is Now Available
I get ""Error" "Not Found""
after I click OK the ISY Finder comes up regardless of what I manually add (my IP or my URL) I get the same message
Are you on a Public or Private network in the Network Manager? Have you tried turning off the Windows Firewall to test?
-Xathros
try:
open the java console, stay open and try the ISY finder again.
you should detect it, it would show up with the mac add.
@ Michel
Hello !
Loaded up 3.3.4 again !
procedure:
did a backup of ISY 3.2.6
scanned 3.3.4 zip update file.
disabled KIS to make sure it would not interfere.
updated ISY.
turned KIS enable
Noticed a few issues with scanning tables for PLM, one lamplinc
cleared PLM, lamplinc,restore PLM, device, rebooted ISY,PLM
For now it seems to be working correctly.
Did not see previous response issues.
:P
Have not tried dashboard yet.
I am not running the windows firewall
after enabling the java console here is the output after clicking
http://www.universal-devices.com/99i/3.3.4/admin.jnlp
put I still get the same error..
Java Web Start 10.9.2.05
Using JRE version 1.7.0_09-b05 Java HotSpot Client VM
User home directory = C:\Users\bryan
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
o: trigger logging
p: reload proxy configuration
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
0-5: set trace level to
Match: beginTraversal
Match: digest selected JREDesc: JREDesc[version 1.6+, heap=-1--1, args=null, href=http://java.sun.com/products/autodl/j2se, sel=false, null, null], JREInfo: JREInfo for index 0:
platform is: 1.7
product is: 1.7.0_09
location is: http://java.sun.com/products/autodl/j2se
path is: C:\Program Files (x86)\Java\jre7\bin\javaw.exe
args is: null
native platform is: Windows, x86 [ x86, 32bit ]
JavaFX runtime is: JavaFX 2.2.3 found at C:\Program Files (x86)\Java\jre7\
enabled is: true
registered is: true
system is: true
Match: ignoring maxHeap: -1
Match: ignoring InitHeap: -1
Match: digesting vmargs: null
Match: digested vmargs: [JVMParameters]
Match: JVM args after accumulation: [JVMParameters]
Match: digest LaunchDesc: http://www.universal-devices.com/99i/3.3.4/admin.jnlp
Match: digest properties: []
Match: JVM args: [JVMParameters]
Match: endTraversal ..
Match: JVM args final:
Match: Running JREInfo Version match: 1.7.0.09 == 1.7.0.09
Match: Running JVM args match: have:<> satisfy want:<>
Upgraded to 3.3.4 thinking that my ISY99 would now be able to support the new insteon leak sensor (2852-222). No problems with the upgrade process, and everything is working normally. However, I'm unable to add the leak sensor to the ISY. When I attempt to do so, the ISY states it "cannot determine the insteon device type" Is the leak sensor not fully supported yet? I have Rev1.05 of the leak sensor, if that makes a difference.
golfleep
Check Help | About, verify both Firmware and UI show 3.3.4.
The Leak Sensor is listed in the Device Type pulldown on 3.3.4. The UI (Admin Console) may not be at 3.3.4
Could also be out of RF range.
If Help | About shows 3.3.4 for UI, run Tools | Diagnostics | Event Viewer with Level 3 selected.
Use New INSTEON Device, enter Insteon Address, Name of choice and leave Device Type set to default Auto Discover. Be sure Leak Sensor is in linking mode (awake) before clicking OK. Post trace.
LeeG,
Thanks for the help, I'm definitely running 3.3.4 on both Firmware and UI. I'm using "new insteon device" menu to add item as you described, and still coming up with the same result, the output from the log is:
Fri 11/16/2012 06:11:50 PM : [21 4e f2 ] Added to list of devices to link to ISY
Fri 11/16/2012 06:12:14 PM : [21 4E F2 0 ] Cannot determine device type
Fri 11/16/2012 06:12:14 PM : [21 4E F2 0 ] Failed to add device
golfleep
Need to select Level 3 when running the Event Viewer. The default Level 1 does not show command execution or response.
Be sure Leak Sensor is near a dual band device and the LED on the Leak Sensor is blinking before clicking Ok on New INSTEON Device.
LeeG,
I managed to add the leak sensor after setting the device type to the leak sensor instead of leaving it on Auto Discover. Thanks again!
LeeG,
golfleep
I just installed to Switchlinc Dual Band Dimmers (2477D) and neither is discoverable by the ISY. The device versions are 6.6 and 6.7. No idea what firmware that is. I tried, Automatic, Device Reported, and I1 Only. The log is below, looks like there are ACKs, does that mean the devices are talking back?.
I have been having a LOT of trouble lately adding new devices. It seems like all of them are responding in the Event Viewer but the ISY is ignoring the responses. All my other devices I was finally able to add through multiple retries and rebooting the ISY. This time no luck...
Sat 11/17/2012 03:28:41 PM : [xx xx xx    ] Added to list of devices to link to ISY
Sat 11/17/2012 03:28:41 PM : [iNST-TX-I1  ] 02 62 xx xx xx 0F 0D 00
Sat 11/17/2012 03:28:41 PM : [iNST-ACK    ] 02 62 xx.xx.xx 0F 0D 00 06                 (00)
Sat 11/17/2012 03:28:50 PM : [iNST-TX-I1  ] 02 62 xx xx xx 0F 0D 00
Sat 11/17/2012 03:28:50 PM : [iNST-ACK    ] 02 62 xx.xx.xx 0F 0D 00 06                 (00)
Sat 11/17/2012 03:28:59 PM : [iNST-TX-I1  ] 02 62 xx xx xx 0F 0D 00
Sat 11/17/2012 03:28:59 PM : [iNST-ACK    ] 02 62 xx.xx.xx 0F 0D 00 06                 (00)
Sat 11/17/2012 03:29:03 PM : [xx xx xx 0  ] Failed to add device
wuench
Set the Advanced Options back to Automatic. These are I2CS devices which should be added using Automatic.
You are having Insteon mesh network problems as indicated by the comment that multiple attempts are needed to get devices added and the fact that these two Dual Band SwitchLincs are not responding at all to the commands sent. Double check the Insteon address being used. Use New INSTEON Device, enter Insteon Address, Name of choice, and leave Device Type set to Auto Discover.
The event trace shows no device response (no 02 50 or 02 51 messages) to the command that was tried three times. Since multiple devices (including the ones that have eventually added) have problems look for something common such as interference from other devices at the PLM plug point. Other electronic devices, UPS, etc (even possibly noisy CFLs) should be on a FilterLinc. The PLM should be plugged directly into an outlet, no surge/noise suppressor power strip.
Insure the Access Points (or whatever is being used for phase coupling) passes the 4 tap Set button test for being in RF range and on opposite 120v legs.
Yeah, thanks. Looks like noise issues, then. I unplugged my PLM and plugged it back in and was able to add one device. Unplugged a powerstrip in a nearby room and was able to add the other.
I gotta say, in my experience, dual band is a BS gimmick. I have almost completed my dual band conversion and should have complete coverage now. But my network is now less reliable, especially since switching to a dual band PLM. I thought adding more devices would give me better coverage, but things are getting worse. My old V1 single band network was way more reliable...
First time I had tried a Scene test on all my modules with 3.3.4 and also the first time I go a 100% failed response?
Tried three times with exact same results.
Previous version never did a 100% failed test.
Fri 11/23/2012 07:25:44 AM : [GRP-RX ] 02 61 16 13 00 06
Fri 11/23/2012 07:25:44 AM : [iNST-SRX ] 02 50 00.FB.B3 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:44 AM : [iNST-SRX ] 02 50 00.FB.BF 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:45 AM : [iNST-SRX ] 02 50 00.FB.C5 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:45 AM : [iNST-SRX ] 02 50 00.FB.F4 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:45 AM : [iNST-SRX ] 02 50 00.FC.1F 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:45 AM : [iNST-SRX ] 02 50 00.FC.2B 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:46 AM : [iNST-SRX ] 02 50 00.FC.35 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:46 AM : [iNST-SRX ] 02 50 15.F0.EC 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:46 AM : [iNST-SRX ] 02 50 04.2B.B4 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:46 AM : [iNST-SRX ] 02 50 04.2D.01 19.70.1A 61 13 16 LTOFFRR(16)
Fri 11/23/2012 07:25:47 AM : [CLEAN-UP-RPT] 02 58 06
Fri 11/23/2012 07:25:47 AM : [iNST-SRX ] 02 50 04.D5.68 19.70.1A 61 13 16 LTOFFRR(16)
----- All Modules Test Results -----
[Failed] Den Table (0 FC 1F 1)
[Failed] Living Room Window (0 FC 35 1)
[Failed] Bedroom Wall (0 FC 2B 1)
[Failed] Den Chair (4 D5 68 1)
[Failed] Kitchen Cabinet (15 F0 EC 1)
[Failed] Living Room Fireplace (0 FB F4 1)
[Failed] Moms Bedroom (0 FB C5 1)
[Failed] Outside Garage Lights (4 2B B4 1)
[Failed] Bedroom Overhead (4 2D 1 1)
[Failed] Den Floor Lamp (0 FB BF 1)
[Failed] Computer Room (0 FB B3 1)
Fri 11/23/2012 07:25:52 AM : [iNST-TX-I1 ] 02 62 00 00 16 CF 13 00
Fri 11/23/2012 07:25:52 AM : [iNST-ACK ] 02 62 00.00.16 CF 13 00 06 LTOFFRR(00)
More information.
Bed Room Overhead and Outside Garage Lights. 2476S SwitchLinc Relay HW 2.1, FW v.28, I1
Kitchen Cabinet 2456S3 ApplianceLinc HW 4.2, FW v.28, I2
Remaining devices 2456S3 ApplianceLinc HW 1.3, FW v.28, I1
Query of My Lighting shows Hops Left=2.
All my Scenes in the Scenes Test fail 100%.
re. Scene Test diagnostic
I noticed the same thing with 3.3.4. (But I haven't used the scene test in a long time so don't know if this began with 3.3.4) Every Scene Test I tried failed 100% yet everything in the house is working well. I think the scene test may have a problem?
Greg
Now that it was mentioned. I am not sure if I had used the Scene Tests in the last few releases.
I'm still having drag'n drop problems on my Mac with Java 1.7. It seems it's one line off.
If I create a new scene it goes to the bottom of the list. If I want to drag and drop it into a folder I have to drag and drop it one line above the folder. You can see if I try to drag it to the folder the green + sign doesn't appear when I hover over the folder name but the + appears when I go one line higher. Release and it drops into the folder below.
Michel,
Drag and drop into scenes also. Need to drop in the line above the scene name to add it.
In preparation for the new official release, I checked my Java and upgraded to V7. With 3.2.6 I am seeing a remarkable improvement in speed of loading and smoothness of the ISY interface. It's really noticeable, so I imagine with the new official release it will be even better. FYI
