System Busy after updating scene
I am a newer user to the ISY 994i firmware version 3.2.4 and UI version 3.2.6 and first post.
I just added a keypadlinc 6 button dimmer button to a scene. All looked good so I went to test the operation of a new program using that scene. When I got back to the computer I found the system busy dialog bar looping.
The prompt says "Please do not power off/unplug the system or make adjustments to linked/attached devices."
The progress bar will reach up to 99% complete before restarting again. This can last hours if not days. My system consists of the ISY, two keypadlincs, two Icon switch dimmers, one 2430 controLinc, a couple of lamplincs, and a few x10 devices. This is about the third time this has happened. I have about 20 programs
Is there anything one can do to regain the ISY's attention? What would happen if I were to try and reset it, that is power it down and restart. I would like to know why updating a small setup like mine takes so long?
First the system has a bad mismatch. The post says the ISY firmware is at 3.2.4 and the UI Admin Console is at 3.2.6. Don't know if that is the problem but the ISY and UI must always be the same. Suggest updating the ISY to 3.2.6. Clear the Jave cache and start the Admin Console.
Thank you for your response. I tried clearing the cache. I also have rebooted from the user interface and then when that didn't work also powered down and restarted after about 30 seconds. I still have system busy message. Makes it to 99% complete then starts over it has been like this for over an hour now. It won't let me update till the ISY frees up.
A portion of the error log reads,
Sat 2012/11/10 02:23:46 PM System -170001 UDQ:Queue Full: PWRIT
Sat 2012/11/10 02:23:56 PM System -170001 UDQ:Queue Full: PWRIT
Sat 2012/11/10 02:24:06 PM System -170001 UDQ:Queue Full: PWRIT
and so forth over and over about every ten seconds
Sat 2012/11/10 04:25:38 PM System -170001 UDQ:Queue Full: PWRIT
till the last entry, complete with out of place time stamp, which is,
Sat 2012/11/10 04:11:29 PM System -5 Start
In order to install the update I had to do a factory reset on the ISY, then restore the backup. I then made the addition to the scene and the update occured in good time and most importantly, finished. Again thanks, LeeG for your help.
Hello Flex,
PWRIT is the queue in charge of communications with PLM. The only way it would get full is if the PLM is not responding. I do not think factory reset ISY and upgrade actually fixed anything except that perhaps, for one reason or another, the PLM started communicating again (possible loose connection?).
So, please do keep an eye ... if you see the same message again in your error log, then it would be best to replace the PLM.
Michel,
I checked the error log again and I am not recieving that error, at least not for now. I will mention that even though the error was occuring the ISY was able to perform its tasks. That is, the programs ran according to schedule, at least some of them did. The ISY and the PLM are about six to eight months old now. I checked the history pior to clearing the log, I had saved it, and yesterday, as far as I could see, was the only occurance of the " UDQ:Queue Full: PWRIT" error.
That said, I will continue to watch to see if the error "UDQ:Queue Full: PWRIT" re-occurs. If there is a next time I'll know to look toward the PLM and its cable to the ISY.
And I thank you for your response and assistance regarding this issue.
This is the most recent error log now, for about the last 24 hours or so.
Time User Code Message
Sat 2012/11/10 06:31:45 PM System -5 Start
Sat 2012/11/10 06:31:46 PM System -110022 /CONF/INSTENG.OPT
Sat 2012/11/10 06:31:46 PM System -110012 /CONF/INSTENG.OPT
Sat 2012/11/10 06:31:47 PM System -170001 [Network] Established
Sat 2012/11/10 03:32:05 PM System -10011 n/a
Sat 2012/11/10 03:32:07 PM System -10011 n/a
Sat 2012/11/10 03:32:08 PM System -170001 [Auth] 192.168.1.20:2521->80, Num=3
Sat 2012/11/10 03:32:08 PM System -10011 n/a
Sat 2012/11/10 03:32:11 PM System -170001 [Auth] 192.168.1.20:2522->80, Num=4
Sat 2012/11/10 03:32:11 PM System -10011 n/a
Sat 2012/11/10 03:32:12 PM System -170001 [Auth] 192.168.1.20:2529->80, Num=5
Sat 2012/11/10 03:32:12 PM System -10011 n/a
Sat 2012/11/10 03:32:14 PM System -170001 [Auth] 192.168.1.20:2530->80, Num=6
Sat 2012/11/10 03:32:14 PM System -10108 Check log
Sat 2012/11/10 03:32:14 PM System -10011 n/a
Sat 2012/11/10 03:32:16 PM System -170001 [Auth] 192.168.1.20:2531->80, Num=7
Sat 2012/11/10 03:32:16 PM System -10108 Check log
Sat 2012/11/10 03:32:16 PM System -10011 n/a
Sat 2012/11/10 03:32:20 PM System -170001 [Auth] 192.168.1.20:2532->80, Num=8
Sat 2012/11/10 03:32:20 PM System -10108 Check log
Sat 2012/11/10 03:32:20 PM System -10011 n/a
Sat 2012/11/10 03:32:21 PM System -170001 [Auth] 192.168.1.20:2533->80, Num=9
Sat 2012/11/10 03:32:21 PM System -10108 Check log
Sat 2012/11/10 03:32:21 PM System -10011 n/a
Sat 2012/11/10 03:32:21 PM System -170001 [Auth] 192.168.1.20:2534->80, Num=10
Sat 2012/11/10 03:32:22 PM System -170001 [Auth] 192.168.1.20:2535->80, Num=11
Sat 2012/11/10 03:32:22 PM System -10108 Check log
Sat 2012/11/10 03:32:22 PM System -10011 n/a
Sat 2012/11/10 03:32:22 PM System -170001 [Auth] 192.168.1.20:2542->80, Num=12
Sat 2012/11/10 03:32:23 PM System -170001 [Auth] 192.168.1.20:2543->80, Num=13
Sat 2012/11/10 03:32:23 PM System -10108 Check log
Sat 2012/11/10 03:32:23 PM System -10011 n/a
Sat 2012/11/10 03:32:23 PM System -170001 [Auth] 192.168.1.20:2544->80, Num=14
Sat 2012/11/10 03:32:24 PM System -170001 [Auth] 192.168.1.20:2545->80, Num=15
Sat 2012/11/10 03:32:24 PM System -10108 Check log
Sat 2012/11/10 03:32:24 PM System -10011 n/a
Sat 2012/11/10 06:36:22 PM System -5 Start
Sat 2012/11/10 06:36:23 PM System -110022 /CONF/INSTENG.OPT
Sat 2012/11/10 06:36:23 PM System -110012 /CONF/INSTENG.OPT
Sat 2012/11/10 06:36:23 PM System -170001 [Network] Established
Sat 2012/11/10 06:38:44 PM System -5 Start
Sat 2012/11/10 06:38:46 PM System -170001 [Network] Established
Sat 2012/11/10 06:38:56 PM System -60006 n/a
Sat 2012/11/10 08:46:56 PM System -5012 26
Sun 2012/11/11 06:38:49 AM System -100 [DHCP] state=RENEW
