2Wire router and ports
I am trouble shooting a MobiLinc issue and part of that meant checking the port settings on my 2Wire (ATT) router. When I follow the directions in the Wiki it is recommended to check with an outside source for a guide to setting up the ports. However, it is recommended to open not only https port (443) but also port 80. Is it necessary to open both ports on the router to operate properly?
One of the problems I'm having is that when I try to access my ISY remotely from a PC I cannot use https I have to use http which can't be right.
I've checked the interface for the 2wire and the ISY is the only computer with port forwarding activated. Just for clarification, the type of traffic is TCP, is that correct?
