Invalid SSL Certificate Message in Config Utility
I'm trying to generate and install a new certificate. The domain I'm attempting to use is something like:
xxxxx.dyndns.org
When I my domain into the box, keep key strength at 512, check save, and click OK, I get an error stating:
"Invalid SSL Certificate Please reinstall the certifiate"
Click OK
"Upgrade Failed: java.lang.NullPointerException"
Why is this happening?
Certifiate is spelled incorrectly in the popup.
Thank you!
HokiePerogi,
First of all, thanks for finding the spelling mistake.
Questions:
1. Are you local to your ISY? (you have to be)
2. Do you get asked to authenticate in the Config Utility?
It seems that The Config utility cannot communicate with ISY; this has nothing to do with the domain name you choose.
Please do let me know.
xxxxx.dyndns.org
Click OK
Thank you!
HokiePerogi,
Questions:
1. No, I was doing this at work coming through my Fios Router (Fios UPNP config worked automatically - great work!)
2. Yes, I am asked for the admin password when hitting the Config Utility via http://xxxxx.dyndns.org.
I will retry generating the new CERT when I'm on the same LAN as the ISY tonight.
Thank you.
xxxxx.dyndns.org
Click OK
Thank you!
I am getting the exact same error messages and I am logged in locally. Any idea what this could be?
Redrox,
Do you have any firewall software?
xxxxx.dyndns.org
Click OK
Thank you!
Hello Michel,
thank you for your response. I turned off all my firewalls but I am still getting the same error. After updating to the 2.6.2 Version it also tells me to disable my internet access which is already disabled in the ISY software.
Redrox,
xxxxx.dyndns.org
Click OK
Thank you!
