edentel Posted January 6, 2013 Share Posted January 6, 2013 I'm trying to find a way to kick off a program based on a duress code entry. I've looked through both the ISY and Elk automation sections and it does not look like this is possible. Am I missing something or is there just no way to act based on a duress code? Thanks! -Ed Link to comment Share on other sites More sharing options...
apostolakisl Posted January 6, 2013 Share Posted January 6, 2013 You use the "last user" option in your Elk rules program. Since ISY doesn't have the "last user" as part of its integration, you'll need to write a rule that does something that ISY can see. Specifically, this would be to turn an output on. Then ISY can have a program that starts with "If Elk output x turns on". Elk rules would be something like Whenever system is disarmed and last user was (whatever name you gave your duress user) Then set output x on for 1 second You'll need to test this since I am not positive entering the duress user's code qualifies as a disarm. Of course, call central station first and let them know you are doing some testing. Link to comment Share on other sites More sharing options...
edentel Posted January 7, 2013 Author Share Posted January 7, 2013 Thanks for confirming I wasn't being crazy or daft! At least this is somethign workable! -Ed Link to comment Share on other sites More sharing options...
