Scene test failure
Using the scene test utility many of my scenes fail (example below) even though they seem to work fine. The only persistant system problem I have is that I seem to loose contact with devices when updating/programming them. Any thoughts? Thanks
Wed 01/09/2013 09:23:18 AM : [GRP-RX ] 02 61 1E 13 00 06
Wed 01/09/2013 09:23:18 AM : [iNST-SRX ] 02 50 19.32.EE 12.9D.CE 61 13 1E LTOFFRR(1E)
Wed 01/09/2013 09:23:18 AM : [std-Cleanup Ack] 19.32.EE-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 09:23:18 AM : [CLEAN-UP-RPT] 02 58 15
Wed 01/09/2013 09:23:19 AM : [iNST-SRX ] 02 50 14.AC.03 12.9D.CE 2B 13 00 LTOFFRR(00)
----- Upstairs Hall All Off Test Results -----
[Failed] Task Lighting (12 32 91 1)
[Failed] Overhead SW (12 CA 32 1)
[Failed] Upstairs Hall Keypad B West (12 B9 2C 4)
[Failed] Upstairs Hall Keypad A West (12 B9 2C 3)
[Failed] GR Chandelier (11 63 CA 1)
[Failed] Deck From 1st floor (11 64 4E 1)
[Failed] Light (12 30 35 1)
[Failed] KP East-B (12 C1 A9 4)
[Failed] KP East-A (12 C1 A9 3)
[Failed] KP E. Overheads (19 3C 2A 1)
[Failed] KP East-Main (TV 2 Spot) (12 C1 A9 1)
[Failed] Fireplace Spots Front (14 75 4 1)
[Failed] 2nd Floor Upper Lt (12 32 A8 1)
[Failed] Bar Front (14 74 E6 1)
[Failed] Dnstrs Bck Hall Art Closet (14 AB D1 1)
[Failed] TV 4 Set (14 73 50 1)
[Failed] Slave NE Accent (14 77 12 1)
[Failed] Bar Back (14 76 A3 1)
[Failed] Entry KP-Main (12 BC 12 1)
[Failed] Fan (14 AB AF 1)
[Failed] KP Entry (12 C8 3D 8)
[Failed] Den (12 32 5D 1)
[Failed] Sink Overheads (12 32 AF 1)
[Failed] Deck From Stairs (12 32 7B 1)
[Failed] Game Slave (14 74 BA 1)
[Failed] Hutch (E 7A A3 1)
[Failed] Game Spots (14 76 FB 1)
[Failed] Rear Sconces Kitchen (12 32 9A 1)
[Failed] KP West (12 BC 92 1)
[Failed] Stars Module (A A8 D6 1)
[Failed] Cabinets (12 31 AF 1)
[Failed] Pantry (14 AA B7 1)
[Failed] KP N. Dining (12 C2 C6 1)
[Failed] GR Sconces (12 C8 3D 1)
[Failed] Laundry Room From Hall (14 74 FC 1)
[succeeded] Upstairs Hall Keypad East.A (19 32 EE 3)
[Failed] 1st Floor Upper Lt (12 32 D7 1)
[succeeded] Upstairs Hall Keypad East.1 (19 32 EE 1)
[Failed] 1st Flr Lwr Lt (14 76 9A 1)
[Failed] Dnstrs Back Hall from Garage (12 CA 79 1)
[Failed] Outside Lts From Laundry (11 65 4A 1)
[Failed] TV Lamp Module (18 99 8B 1)
[Failed] Entry Chandelier (12 32 BF 1)
[Failed] West Spots (14 76 AB 1)
[Failed] Dnstrs Bck Hall Light (12 32 7F 1)
[Failed] Bsmnt Lwr Light (12 A0 7E 1)
[Failed] Overhead NW (12 CA 54 1)
[Failed] TV Slave South (14 75 29 1)
[Failed] Rear Posts Kitchen (11 62 5B 1)
[Failed] Fan (14 AC 3 1)
[Failed] Fireplace Spots Rear (14 76 63 1)
[Failed] Library (14 75 52 1)
[Failed] Dnstrs Bck Hall Broom Closet (14 AD 9B 1)
[Failed] Slave NE Dining (14 75 7B 1)
[Failed] East Spots (13 3A 45 1)
[Failed] Deck From Kitchen (12 31 A3 1)
[Failed] Blank Switch (13 39 DC 1)
[Failed] Laundry Rm (12 31 11 1)
[Failed] Entry Coat Closet (14 AA F7 1)
[Failed] Accent (14 75 C0 1)
[Failed] Table (12 32 60 1)
[Failed] Overheads (14 76 10 1)
[Failed] Deck From Hall (14 74 B3 1)
[Failed] Island (12 32 BC 1)
[Failed] KP East-C (12 C1 A9 5)
[Failed] Outside Lts From Great Room (14 73 63 1)
[Failed] KP East-D (12 C1 A9 6)
[Failed] Overhead East (12 CA 60 1)
[Failed] Disco Turkey Lamp (1A DA 6A 1)
[Failed] Back Coat Closet (14 AC 20 1)
[Failed] Dnstrs Bck Hall Kypd W. Main (12 C4 1F 1)
[Failed] Perimeter (14 76 A 1)
[Failed] Sconces (14 74 CA 1)
[Failed] KP S. Chandelier (12 C4 6 1)
What does Help | About show for Firmware and UI levels.
There was a problem with an earlier image marking devices as failed when they actually passed the test. That problem does not exist at 3.3.8 (RC5)
Just looked back over trace looking for false failed condition. There are link record problems as only two devices actually ACKed the Scene Test. That is why so many are marked failed. With so many devices failing I suspect the PLM has lost its link database. Do a Restore Modem (PLM)
I've seen a few other situations that can cause these erroneous results:
1) Programs can interfere with the scene test as they are activated through "status" triggers. Timed events or periodic queries can also wreak havoc.
Programs Enabled
Wed 01/09/2013 17:26:18 : [GRP-RX      ] 02 61 3D 13 00 06
Wed 01/09/2013 17:26:19 : [iNST-SRX    ] 02 50 0F.D2.68 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:26:19 : [std-Cleanup Ack] 0F.D2.68-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:26:19 : [iNST-SRX    ] 02 50 1A.4F.6B 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:26:19 : [std-Cleanup Ack] 1A.4F.6B-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:26:19 : [iNST-SRX    ] 02 50 03.D3.46 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:26:19 : [std-Cleanup Ack] 03.D3.46-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:26:19 : [iNST-SRX    ] 02 50 09.8C.CD 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:26:19 : [std-Cleanup Ack] 09.8C.CD-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:26:19 : [iNST-SRX    ] 02 50 0A.E5.EC 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:26:19 : [std-Cleanup Ack] 0A.E5.EC-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
----- SC 2nd Floor Test Results -----
[succeeded] David Switch (1A 4F 6B 1)
[Failed] MBath KPL B - Vanity (F BF A4 2)
[Failed] MBath KPL A - Vanity (F BF A4 1)
[succeeded] Mud KPL 4 - 2nd Floor (9 8C CD 4)
[Failed] Matt Inline (E E4 62 1)
[succeeded] Master KPL H - David Bed (A E5 EC
[succeeded] Master KPL F - Kath Bed (A E5 EC 6)
[succeeded] Master KPL C - 2nd Floor (A E5 EC 3)
[Failed] MBath KPL E - Closet (F BF A4 5)
[succeeded] Master KPL D - Matt Bed (A E5 EC 4)
[Failed] MBath KPL D - Toilet (F BF A4 4)
[succeeded] Master KPL A - Overhead (A E5 EC 1)
[succeeded] Master KPL B - Overhead (A E5 EC 2)
[Failed] Master Bath Tub (16 92 BD 1)
[succeeded] Kath Icon (3 D3 46 1)
[succeeded] Master Fan KPL A (F D2 68 1)
[Failed] Master Table KPL B - Light (19 46 CE 2)
[Failed] Master Bath Toilet (14 78 B2 1)
[Failed] Master Bath Shower (1B F4 54 1)
[Failed] Master Table KPL C - 2nd Floo (19 46 CE 3)
[Failed] Master Table KPL A - Light (19 46 CE 1)
[Failed] BSMT KPL Game - 2nd Floor (F FF F1 4)
[Failed] Master Table KPL D - Fan (19 46 CE 4)
[Failed] Master Bath Closet (14 6C F0 1)
[succeeded] Master Fan KPL B (F D2 68 2)
Wed 01/09/2013 17:26:26 : [iNST-ACK    ] 02 62 00.00.3D CF 13 00 06          LTOFFRR(00)
Programs Disabled
Wed 01/09/2013 17:27:51 : [iNST-SRX    ] 02 50 21.D5.C5 11.00.02 C7 06 00           (00)
Wed 01/09/2013 17:27:51 : [std-Group   ] 21.D5.C5-->11.00.02, Max Hops=3, Hops Left=1
Wed 01/09/2013 17:27:52 : [GRP-RX      ] 02 61 3D 13 00 06
Wed 01/09/2013 17:27:53 : [iNST-SRX    ] 02 50 0F.D2.68 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:53 : [std-Cleanup Ack] 0F.D2.68-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:53 : [iNST-SRX    ] 02 50 1A.4F.6B 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:53 : [std-Cleanup Ack] 1A.4F.6B-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:53 : [iNST-SRX    ] 02 50 03.D3.46 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:53 : [std-Cleanup Ack] 03.D3.46-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:53 : [iNST-SRX    ] 02 50 09.8C.CD 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:53 : [std-Cleanup Ack] 09.8C.CD-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:53 : [iNST-SRX    ] 02 50 0A.E5.EC 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:53 : [std-Cleanup Ack] 0A.E5.EC-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:53 : [iNST-SRX    ] 02 50 0E.E4.62 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:53 : [std-Cleanup Ack] 0E.E4.62-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:53 : [iNST-SRX    ] 02 50 0E.E4.62 0C.A8.B4 67 09 FD    LNK-ON (FD)
Wed 01/09/2013 17:27:53 : [std-Cleanup Ack] 0E.E4.62-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Wed 01/09/2013 17:27:54 : [iNST-SRX    ] 02 50 0F.FF.F1 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:54 : [std-Cleanup Ack] 0F.FF.F1-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:54 : [iNST-SRX    ] 02 50 19.46.CE 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:54 : [std-Cleanup Ack] 19.46.CE-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:54 : [iNST-SRX    ] 02 50 14.6C.F0 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:54 : [std-Cleanup Ack] 14.6C.F0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:54 : [iNST-SRX    ] 02 50 1B.F4.54 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:54 : [std-Cleanup Ack] 1B.F4.54-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:55 : [iNST-SRX    ] 02 50 14.78.B2 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:55 : [std-Cleanup Ack] 14.78.B2-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:55 : [iNST-SRX    ] 02 50 16.92.BD 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:55 : [std-Cleanup Ack] 16.92.BD-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:27:55 : [CLEAN-UP-RPT] 02 58 06
Wed 01/09/2013 17:27:55 : [iNST-SRX    ] 02 50 0F.BF.A4 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:27:55 : [std-Cleanup Ack] 0F.BF.A4-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
[succeeded] MBath KPL B - Vanity (F BF A4 2)
[succeeded] MBath KPL A - Vanity (F BF A4 1)
[succeeded] Matt Inline (E E4 62 1)
[succeeded] MBath KPL E - Closet (F BF A4 5)
[succeeded] MBath KPL D - Toilet (F BF A4 4)
[succeeded] Master Bath Tub (16 92 BD 1)
[succeeded] Master Table KPL B - Light (19 46 CE 2)
[succeeded] Master Bath Toilet (14 78 B2 1)
[succeeded] Master Bath Shower (1B F4 54 1)
[succeeded] Master Table KPL C - 2nd Floo (19 46 CE 3)
[succeeded] Master Table KPL A - Light (19 46 CE 1)
[succeeded] BSMT KPL Game - 2nd Floor (F FF F1 4)
[succeeded] Master Table KPL D - Fan (19 46 CE 4)
[succeeded] Master Bath Closet (14 6C F0 1)
Wed 01/09/2013 17:28:00 : [iNST-ACK    ] 02 62 00.00.3D CF 13 00 06          LTOFFRR(00)
2) Pending writes against a device will interrupt a scene test. To test the following I unplugged a lamplinc and then instructed the ISY to include it in a scene. That obviously failed since the device was unplugged (! mark next to the device). There are, however, writes pending against the device (ISY wants to complete the scene addition). Apparently, when the scene test is activated the write update to the devices also activates. This interrupts the scene test response as shown below. The device with pending writes can be anywhere in the system. It does not need to be a member of the scene being tested.
Wed 01/09/2013 17:45:45 : [GRP-RX      ] 02 61 3D 13 00 06
Wed 01/09/2013 17:45:46 : [iNST-SRX    ] 02 50 0F.D2.68 0C.A8.B4 61 13 3D    LTOFFRR(3D)
Wed 01/09/2013 17:45:46 : [std-Cleanup Ack] 0F.D2.68-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Wed 01/09/2013 17:45:46 : [CLEAN-UP-RPT] 02 58 15
[Failed] David Switch (1A 4F 6B 1)
[Failed] Mud KPL 4 - 2nd Floor (9 8C CD 4)
[Failed] Master KPL H - David Bed (A E5 EC
[Failed] Master KPL F - Kath Bed (A E5 EC 6)
[Failed] Master KPL C - 2nd Floor (A E5 EC 3)
[Failed] Master KPL D - Matt Bed (A E5 EC 4)
[Failed] Master KPL A - Overhead (A E5 EC 1)
[Failed] Master KPL B - Overhead (A E5 EC 2)
[Failed] Kath Icon (3 D3 46 1)
Wed 01/09/2013 17:45:53 : [iNST-TX-I1  ] 02 62 00 00 3D CF 13 00
Wed 01/09/2013 17:45:53 : [iNST-ACK    ] 02 62 00.00.3D CF 13 00 06          LTOFFRR(00)
3) Disabled devices. If a device has been disabled in the ADMIN tree it will show up as "failed" in the scene test. Probably not what you are experiencing, but something to keep in mind.
Tip on disabling programs. Tired of using the program summary tab to enable/disable programs? Use a variable in the main "My Programs" folder.
Folder Conditions for 'My Programs'
Add conditions to limit when programs in this folder are allowed to run.
       $Programs_Enable is 1
IM
Great suggestions , thanks. Away for a day but going to try on return. Still don't understand what the significance of the fail is if my scenes work in real life?
Controlling a Scene with a Program (or Admin Console) uses an Insteon command different from that used by Scene Test. Controlling a Scene from a Program (or Admin Console) uses a command that does not generate ACKs so the ISY/PLM does not know if any specific device actually received the Scene On/Off command.
The Scene Test uses a PLM Scene command that does require an ACK from each device. The PLM must have a link record for every device in the Scene for the ACK to be generated. Because a normal Scene On/Off is not ACKed the missing link records have no effect (if they are missing).
The failures that IndyMike discussed in his post result from Programs being triggered by Scene driven device state changes which then issue another Scene command or Insteon Direct command. Insteon will terminate a running Scene if another Scene or Insteon command is initiated. Does not bother Scene On/Off because ACKs are not part of a normal Scene On/Off. The lack of ACKs in a Scene Test because the Scene Test Scene has been cancelled by Program activity shows up as Scene Test device failures for the devices that had not yet received the Insteon message that generates the ACK.
