Isy Finder
New Install, When I start Admin Console, I get 'ISY FINDER'. I click add and enter ISY address and it creates an icon on the desktop. After I close ans start again, it comes back again....not sure why? How do I get it to stop?
Also, the icon it creates has a target a mile long with a reference to Java 6 and I have Java 7 installed....
Some things just don't look right.
John
Hi John,
I am not sure what you mean by getting it to stop. What are you trying to stop?
What happens if you go to http://www.universal-devices.com/99i/3.3.8 ... this uses the applet. I want to see whether or not the applet finds ISY.
And, finally, we used to require 1.6 (1.6+) but have moved to 1.7 in 3.3.8. If you wish, you can upgrade to 3.3.8.
Stop, meaning get the isy finder pop up box to stop opening every time I open the admin console.
I flashed to 3.3.8 then used the link listed under step d as recommended in the post. It creates an icon on the desktop and when used opens the isy finder popup box and admin console. Of interest it lists firmware as 3.3.8 and console as 3.2.6 under help | about.
Also, I tried creating a shortcut with "http://isy.universal-devices.com/99i/3.3.8/admin.jnlp" and when used it also gets the ISY finder pop up box, admin console and ALSO open Internet Explorer view and track your downloads box.
Right now I am using the automatically generated icon with properties "C:\Windows\SysWOW64\javaws.exe -localfile -J-Djnlp.application.href=http://192.168.3.66/admin.jnlp "C:\Users\John\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\60\2cee973c-4ec43382" and it seems to work. No pop up isy finder and firmware and console both say 3.3.8, BUT the icon regenerates and goes in the bottom left corner of screen every time I launch.
John
OK, it took a bit of research, But I got Java disabled in my browser, ended up having to edit the registry.
The second link in you other post needs a i after the 99 to work.
So do I just leave the ISY finder box open while I am in Admin? It has a line with my isy address in there already, so I assume I don't need to add. Should I just cancle it?
Now Firmware shows 3.3.8 and UI shows 3.3.9
Here is the link I show now for my desktop icon....
C:\Windows\SysWOW64\javaws.exe -localfile -J-Djnlp.application.href=http://isy.universal-devices.com/99i/3.3.9/admin.jnlp "C:\Users\John\AppData\LocalLow\Sun\Java\Deployment\cache\6.0\42\754abf6a-7da699e1"
John
