XML Parse Error
I am getting the following XML parse error when trying to access the admin console via my internal IP address:
http://0.0.0.0/desc
I can view the html pages just fine by going to http://192.168.1.10, but when I click on the Admin console, the java application gives me the parse error.
When I access the ISY via my public IP, it works fine.
How do I regain access to the admin panel using my internal IP?
Thank you.
HokiePerogi,
It seems that you have Java Cache issues. Please do:
Control Panel->Java->Settings (button)->Delete Files (button)
Let me know if this takes care of the problem.
http://0.0.0.0/desc
Thank you.
Thanks Michel. I was able to resolve the issue last night after posting my question by clearing out the Java Cache. I guess I access it from the same laptop on two different LAN's which could be causing the issue.
