99i Admin Console opens software update
I know it sounds crazy but it's true.
When I click my "99" icon it opens my software update on my Mac.
Hoe do I fix that?
Drew
When I go into the info.plist in the package contents it says this.
Last login: Sat Feb 9 17:41:31 on console
/Applications/99i\ Administrative\ Console.app/Contents/MacOS/99i\ Administrative\ Console ; exit;
Andrew-Brideaus-iMac-2:~ Andrew$ /Applications/99i\ Administrative\ Console.app/Contents/MacOS/99i\ Administrative\ Console ; exit;
[JavaAppLauncher] Requested [1.6+], launching in [1.6] instead.
No Java Web Components present, requesting install.
logout
[Process completed]
Clearly I need to update JAVA?
Tried surfing to the console using the browser and 192.168. etc...
I go the My Lighting page but it says inactive plugin where the JAVA app is.
Drew
Apple disabled older versions of Java because of security issues. Check the Apple support forum for info on updating to the fixed version.
Hi Michel;
It's 10.6.8
I find that when I type 192.168.0.104 I can access the ISY but when the GUI pops up it endlessly keeps "initializing System"
That's as far as I've gotten.
Drew
Got it but the ISY Finder can't find my ISY.
It asks for the URL.
Drew
Hi Drew,
Hopefully you have not upgraded your Airport utility to 6.2 since they removed DHCP client list. If you still can get your DHCP list, then please look for your ISY's IP address there.
If not, open a terminal window and then use:
arp -a
Look for a device the MAC address of which starts with 00:21:b9.
I am so very sorry for all the trouble. It seems as though Apple is deliberately trying to force everyone either into 10.7.x+ or Bonjour.
My Airport utility is still 5.6.1
But it just seems to look for wireless devices. (I've never used Airport Utility so I may be using it wrong)
Last login: Sun Feb 10 19:30:24 on console
Andrew-Brideaus-iMac-2:~ Andrew$ arp -a
? (10.37.129.2) at 0:1c:42:0:0:9 on vnic1 ifscope permanent [ethernet]
? (10.37.129.255) at ff:ff:ff:ff:ff:ff on vnic1 ifscope [ethernet]
? (10.211.55.2) at 0:1c:42:0:0:8 on vnic0 ifscope permanent [ethernet]
? (10.211.55.255) at ff:ff:ff:ff:ff:ff on vnic0 ifscope [ethernet]
? (192.168.0.1) at b8:a3:86:52:62:e8 on en1 ifscope [ethernet]
? (192.168.0.108) at f0:7b:cb:86:cf:6 on en1 ifscope [ethernet]
? (192.168.0.255) at ff:ff:ff:ff:ff:ff on en1 ifscope [ethernet]
That's what I got when I typed arp -a in Terminal.
I don't see 00:21:b9 here.
Let me know where to go from here.
Also, don't be sorry for what Apple does. A true Apple user likes their product, not their practices.
(I should print that on a t-shirt)
All this started off by me wanting to switch out one SWL for another.
Drew
Drew-
From that, it doesn't look like the ISY is connected to the network. Check the ethernet cable between the ISY and Airport/Switch. Are there any lights on the ISY's ethernet port when the cable is connected?
Michel-
See: https://discussions.apple.com/thread/4427603?start=0&tstart=0 Re: AirPort Utility on Lion/Mountain Lion
-Xathros
I just went into the furnace room where all the gear is (I should have gone there first clearly, sorry for wasting everyone's time, and yes, the next time the car
fails I'll check for gas first !@#$%^&*()
Anyhow, the two network cables were unplugged (I'll get to the bottom of that with the daughter tonight)
How do I hook it back up?
Port A on the ISY 99i goes to the PLM and the Network goes to my router?
That's how I plugged it in and I only see the power light. Still nothing on the ISY Finder.
I switched the network cable joining the ISY to the router and still nothing
Drew
Drew
Exactly!.
-Xathros
I'm using Snow Leopard and I don't have any airport stuff.
Just a D-link router
Drew
Now that the PLM and router are connected try power cycle of ISY. Not sure just plugging in the cables will get things initialized after the ISY would not have been able to communicate with the PLM or the router.
looks like I'm back in business.
As an aside, I unplugged the power to the ISY and it still had power until I unplugged it from the
PLM. The PLM powers the ISY?
Drew
So I started all this to try to replace one SWL with another.
Now that I'm back up and running I've discovered the new SWL, Replaced the SWl with the other as far as the ISY GUI is concerned,
but I cant get it to react to the scenes.
I can control it with the GUI
It also has a little green icon beside it in the GUI.
Drew
You must have the older 2412S PLM like me. Yes. It provides 12V to the ISY. The newer Dualband 2413S does not.
-Xathros
Drew
Right click it and select "Write Updates to Device"
Wait for the writes to take place then test again.
-Xathros
That seems to have fixed it.
Thank you everyone.
Drew
