February 17, 201313 yr I just installed ISY994i this weekend with v3.3.10. I purchased MobiLinc HD and am installing it. It says to go to ISY control pannel and pull down help/purchase modules and purchase Portal Integration - MobiLinc Connect. This is not listed on the page.
February 17, 201313 yr You are correct, it is not on the page. I think someone accidently took it off when they posted the alpha zwave module at close to $500.00 Alan
February 17, 201313 yr Sincere apologies ... it should be fixed now. $485.00 is to prevent folks from purchasing the module without contacting us (we are still in Alpha). With kind regards, Michel
March 15, 201313 yr I am able to see the Portal Integration - MobiLinc Connect module in the list of available modules. However, I do not see a link to click to purchase it. I need this so I can connect to mobilinc on my android device. Are there other apps that are as good/better than mobilinc?
March 16, 201313 yr I am able to see the Portal Integration - MobiLinc Connect module in the list of available modules. However, I do not see a link to click to purchase it. I need this so I can connect to mobilinc on my android device. Are there other apps that are as good/better than mobilinc? Whaf browser are you using?
March 16, 201313 yr I am running windows 8 and I am using IE 10. Based on your comment I am going to download firefox or chrome and see if that makes a difference. I will post the results later today. Thanks for the response.
March 16, 201313 yr That solved the problem. I was able to purchase the module using Firefox. Thanks for the suggestion.
