Eisy reboot
I followed the AI further which says that Bhyve/HA was using APIC virtualization which is causing the crash. I put hw.vmm.intel.apicv_active="0" hw.vmm.x2apic_wr_msr_exit="1" into /boot/loader.conf and restarted then verified it was disabled. Now I just have to wait and see if the random reboots are gone.
Eisy reboot
Good point I forgot to add I was seeing an average core temp of 50c which seemed OK but I put a computer fan on top of it that dropped the core Temps to about 41c
Eisy reboot
I have had Eisy rebooting about once a week sometimes twice in a row for a couple of months now. I have the added storage with HA running on Eisy and HA reboots so I know it is a complete system reboot. I finally tried to look into things but not getting far with my abilities. I have activated the core dump and on the last restart I got some information but not sure what it means. Dump header from device: /dev/gpt/swap0 Architecture: amd64 Architecture Version: 2 Dump Length: 1192792064 Blocksize: 512 Compression: none Dumptime: 2026-02-20 23:06:11 -0700 Hostname: eisy Magic: FreeBSD Kernel Dump Version String: FreeBSD 14.3-RELEASE-p5 #5 releng/14.3-n271450-382f54740ee4-dirty: Tue Oct 28 19:30:07 PDT 2025 root@bsdev143.isy.io:/usr/obj/usr/src/amd64.amd64/sys/eisy Panic String: ISR and isrvec_stk out of sync Dump Parity: 1684056904 Bounds: 0 Dump Status: good Last lines before reboot. panic: ISR and isrvec_stk out of sync cpuid = 2 time = 1771653971 KDB: stack backtrace: #0 0xffffffff80a1a3ed at kdb_backtrace+0x5d #1 0xffffffff809cbee1 at vpanic+0x161 #2 0xffffffff809cbd73 at panic+0x43 #3 0xffffffff82c114ac at vlapic_update_ppr+0xec #4 0xffffffff82c12769 at vlapic_pending_intr+0x19 #5 0xffffffff82c02f29 at vm_run+0xa99 #6 0xffffffff82c0657c at vmmdev_ioctl+0x95c #7 0xffffffff8085798b at devfs_ioctl+0xcb #8 0xffffffff80ac9ed8 at vn_ioctl+0xc8 #9 0xffffffff80857ffe at devfs_ioctl_f+0x1e #10 0xffffffff80a3b635 at kern_ioctl+0x255 #11 0xffffffff80a3b381 at sys_ioctl+0x101 #12 0xffffffff80e13847 at amd64_syscall+0x117 #13 0xffffffff80deb9ab at fast_syscall_common+0xf8 Timeout initializing vt_vga Uptime: 1h25m43s Dumping 1137 out of 7903 MB:..2%..12%..22%..31%..41%..51%..61%..71%..81%..91% This is the main thing that I found that shows an error with the ISR and isrvec_stk out of sync but when I try to go deeper with AI telling me what to look for it does not shed any light on the picture for me. [admin@eisy /var/crash]$ (cat /var/log/messages; bzcat /var/log/messages.*.bz2) | grep -i "panic" Feb 20 23:06:48 eisy kernel: panic: ISR and isrvec_stk out of sync Feb 20 23:06:48 eisy kernel: #1 0xffffffff809cbee1 at vpanic+0x161 Feb 20 23:06:48 eisy kernel: #2 0xffffffff809cbd73 at panic+0x43 Feb 20 23:06:48 eisy savecore[1638]: reboot after panic: ISR and isrvec_stk out of sync [admin@eisy /var/crash]$ dmesg | grep -i "panic" panic: ISR and isrvec_stk out of sync #1 0xffffffff809cbee1 at vpanic+0x161 #2 0xffffffff809cbd73 at panic+0x43 [admin@eisy /var/crash]$ dumpon -l gpt/swap0 So if anyone sees something that I can investigate further I would appreciate some guidance otherwise I will open a ticket to see what the UDI people think. Thanks for any help that can be offered! Tom
Feature request
Thank you @sjenkins for all you do for the community!
Feature request
@sjenkins thank you for considering this the more I think of it my needs are very basic that I just need to pass a variable number to a GV number where the designation of that number is not really important. Right now I'm using the temperature node and showing previous reading which is a GV value. To give you some context I will attach a picture of some of my mirror display which has information that is there so I don't have to open an app all the time and is also there for my household to see. If there are no other people with use for this I'm ok keeping the workaround in place that I found. I hope you had a good vacation and again thank you for the consideration!
Feature request
Well I guess this ended up not working so don't worry about it. One of the temperature nodes would work since it just displays as a number value in House Panel and I can add text before or after the values but unfortunately House Panel does not recognize the current "ST" value but it can see the "GV" values. So unless you would be able to have the current show up as one of the GV numbers with the temperature nodes that would work for me.
Feature request
@sjenkins I use House Panel to create a Magic Mirror type display and I would like to pull some values from Home Assistant to Eisy to put on my display. The values I'm looking for would be KWH and KW. I use the old list way of setting up the plugin and maybe with the JSON string this would already be possible I just don't know how to use it. So basically I'm looking for a temperature type node that I can pull the value from a variable and have it display as power KW or KWH. Thank you!
Trying this out, not getting module configuration
Well mine started working again on it's own but I don't want to restart it to see if everything is good. @Guy Lavoie you can try and see if it will retrieve your devices now.
It's not Emporia it is the people who backwards engineer the data retrieval process that released the code Bob used to make it available for us.
Switch triggering a state variable to activate alexa
The best I can recommend is to be sure Alexa is not showing more than 1 item with your variable. Then as said give it a day or 2 and if it still not working try to get help from UDI to see if everything looks good in the portal, then you will have to move on to Amazon to try and get it working.
Then it definitely seems to be a problem between the portal and Amazon servers. If you have other devices working then maybe post a screen shot of your portal setup of the variable. Are you using a state variable? I never used an integer and don't know if they work.
You need to monitor the "device" in Alexa to see if that is triggering. The most common problem is with Alexa because it will see the trigger but the routine does not run in which case sometimes it starts working on it's own in a couple of days or people have contacted Amazon to get it resolved.
I just performed a restart of Vue in PG3 and I'm getting the same error and it will not connect. Either Emporia is having problems or they changed something and it will require a code change to get things working again. My Eisy is on 6.0.3_3 so I guess we will have to wait for @bpwwer to take a look.
Sorry I'm not a programmer but it looks like something is wrong with your location settings with Emporia maybe try going through the Emporia app and check/chang your location to see if it helps.
@Guy Lavoie have you installed the Dev Package in the admin console? That use to be a reason for failure before and worth a try.
tazman
Joined
Last visited
