MMAltair
Everything posted by MMAltair
  1. I tried this fix and it seems to work. I don't know how many nodes I have but it is a large number. The Elk Plugin by itself populates hundreds of nodes since it exposes all of the zones, counters, outputs (256 of these), and other items related to the security system. The browser isn't involved in this particular issue so I didn't need to do anything related to it. In any case I think I'm back in business. Thanks much for you help! Mike+
  2. I have an EISY system running IoX FW/UI ver 6.0.4 where when I launch the Java admin console using the EISY Finder it loads the "Main" Screen tab properly but when I click on the "Programs" tab it hangs up to the point where I have to use Windows Task Manager to end the Java process. It always hangs at the point where it is creating the Scene Widgets. This has been working reliably for many years and just started not working today. I've tried clearing the Java cache, updating Java to the latest version (Version 8 Update 491), and rebooting EISY, all to no avail. I can launch the Web Browser admin console just fine but this doesn't have the required functionality. As a side note, I have a 2nd EISY system on the same network (different home on a different VLAN) and when I launch the Admin console on it everything works just fine using the same computer with the same .jnlp file. Has anyone else seen this behavior? Any additional debug steps I can take? Mike
  3. I ran into the same problem. Lost my favorites associated with the my Z-Wave door locks. In addition (as stated in other posts) the Z-Wave lock information no longer shows up in UD Mobile. I ended up creating some programs to monitor the conditions of the Z-Wave locks and translate this information into some state variables for use in UD Mobile Favorites. A bit ugly but this work arounds works. Mike
  4. The Mapped Status problem seems to be fixed in IoX ver. 6.0.3. Once I did this update and restarted the affected Plugins everything is back to normal. Mike
  5. Thanks Paul. I wasn't aware that a precision could be assigned to a variable and will follow your directions to fix my problem. This new knowledge opens up a bunch of possibilities including better handling of Yolink temperature values which currently are being rounded to the nearest integer. Thanks again! Mike
  6. I installed one of the Emporia Smart Plugs in order to monitor the on/off state of an HVAC ventilator unit. The thought was I could periodically check the power consumption through the Vue plugin and see how many watts were been drawn to determine the operating vs standby state of the unit (the ventilator is controlled by a complex algorithm in the HVAC control system which I can't access from EISY)). My plan is to monitor how the HVAC algorithm is actually controlling the unit since I suspect it is less than optimum. The problem I'm running into is the Current Power Consumption value in the node is in kilowatts but the ventilator only draws 170W while running and about 10W in standby. The node shows this as a decimal value (0.1763 KW operating or .0112KW standby) but this translates to value of 0 when I attempt to use the value in a program or to assign it to a variable (all variables are signed Integers in IoX). Is there anyway around this limitation? What would be really helpful is if there were another field in the Node that also displays the current power value in watts. Thanks Mike Operating Mode Power Standby Mode Power
  7. I ordered 1 of the Yolink smart plugs and 2 of the Emporia Vue smart plugs and will experiment with both of them. Thanks for all the replies. Mike
  8. I'm doing a bit more research now before going down the Yolink path for energy monitoring. I read some of the reviews on Amazon and people are complaining that the Yolink Smartplug (6602) only updates the energy usage once per hour. This is too long of interval for a device that turns on/off more frequently than this. Do you know if the Alarm Limits trigger an immediate update to the Yolink Polyglot Plugin when the limit is exceeded (in either direction)? Thanks Mike
  9. I'll give your technique a try. I haven't purchased the smart plug yet but can experiment with one of my Yolink temperature sensors as an alarm source while I wait for the smart plug to arrive. Should be an interesting project. Thanks for your comment. Mike
  10. I don't think I need any averages at this point. I'm trying to get a better idea how much my heat recovery ventilator is running. The ventilator is controlled by an algorithm in my HVAC system which factors in things like outside air temperature and indoor humidity along with a windows efficiency setting to prevent condensation on the windows (something that is a problem in Minnesota in the winter). As long as I can get a sense for when the ventilator is running, by measuring its power consumption, I should be good to go. As long as the current power consumption is reported I should be able poll the node at a regular interval and determine if it is on or off and then calculate a percentage of on time. Thanks for the quick response. Mike
  11. Does anyone know if the Yolink Energy Monitoring Smart Plug works with the Yolink Plugin? Does the real-time energy usage get reported or do energy usage limits get reported? I'm dipping my toes in some limited energy monitoring and need to decide what path I take. Yolink has become my go-to place for moisture, temperature, and humidity monitoring due to its wireless communication reliability. I have a specific need to monitor an HVAC HRV and thought the Yolink Energy Monitoring Smart Plug would be an easy way to integrate this with EISY. Thanks Mike
  12. Okay, that fixed it. Before 6.0 I didn't need to explicitly set the displayed text in Advanced Status. Thanks for the response! Mike
  13. I just updated to IoX 6.0 as well and ran into the same problem. I use the Alarm system status (Disarmed, Armed, etc.) in my Favorites to show the Armed status of the system and it use to show the status as Armed Away/Armed Stay/Disarmed/etc. Now it only displays a number. This problem would be solvable using Advanced Status except there is no way to do a comparison against the number value that is returned. Mike
  14. 2) Update. I tried the comparison approach you proposed and that works as described. Thanks! Mike
  15. 1) I thought the back arrow had worked at some point. I'll be patient. 2) I considered this approach but wasn't sure about the order of evaluation. The wiki entry explains this (I should have check the wiki first). I'll try this method and see if I can get it to work. Thanks
  16. First, I use UD Mobile and EISY extensively now days to manage most of my IOT devices and for the most part it is great. I have two questions/requests. 1) I use folders in the Favorite area to provide a top level view of things with the ability to drill down into subfolders when more detail is needed. For example I have two EISY systems (one in our main home and one in our cabin) so I have two folders at the top level in Favorites, one for each house. When the Folder is pressed for either system it opens a top level page that contains important details for each system along with more folders that can opened to drill down into the details. The goal is to keep the opening page for each system limited to one page so it can be viewed without scrolling. The opening page contains things like Alarm system status, buttons for kay lights, the state of various doors/windows, and folders to drill down into things like door locks, temperatures, more light controls, water sensors, etc. So far this all works well with one exception. When the back button is pressed in any sub-folder it always goes back to the Devices and Scenes area of UD Mobile instead of returning to the parent folder. Is this be design or am I doing something wrong? If it is by design is there a workaround could be implemented? It would be way more convenient and intuitive if the back button returned to the parent folder. 2) Expanding on the 1st topic I also use the Advanced Status Configuration settings to control the color/icons/Info displayed on many of the buttons and folders. For the most part this meets all of the needs for conveying information concisely for the buttons and folders. The one exception I have run into is that the Advanced Status Configuration is only able to use the Node defined in the Favorite, that it is associated with, for its comparison function. I have some situations where it would be real handy to be able to specify the node that the Advanced Configuration Status uses for the comparison. For example, I have temperature buttons for various temperature sensors where each of the buttons shows the actual temperature in its status field. I then use the Advanced Status Configuration for each button to changed the color of the Icon to show weather the temperature is out of range for that sensor. For some sensors this is 3 states, High, Low, and Normal. This can be calculated easily in a program and assigned to a variable but if this variable is used for the Favorite then the actual temperature can't be displayed. It would be real handy if the node used for the Favorite and for its associated Advanced settings could be selected independently. If there other ways to accomplish this I'm open to advice. Here are some screen shots of several page configurations I have set up - Top Level - The 2 houses 2nd Level - PF (Home) 3rd Level - Temperatures Folder
  17. Ross, I have an EISY system at IoX release 5.9.1. The release numbers I mentioned before (1.5.16 & 1.6.2) were for the Yolink plugin version. Mike
  18. I was on 1.5.16 when I first tried this and then upgraded to 1.6.2 to see if it helped, no joy. The fact that it works for you is interesting. Which version of IoX are you running?
  19. I went ahead and implemented the math to do the conversion in each of the programs that read Yolink temperature data and this worked just fine. Problem solved. Thanks again!
  20. Thanks for the feedback. It does appear to be related to the console since I can select Fahrenheit in the drop down box but it doesn't get applied when the Action is applied. As I mentioned in my first post I have an Ambient Weather system and have the plugin for this system installed. When I create a program using this plugin it allows me to select Fahrenheit or Celsius and the correct selection gets applied when the Action is added to the Then or Else clause. I think this means that it is possible for this to work but perhaps it means, as you said, all of the temperature values would need to be duplicated in the node. It would take looking into the Ambient Weather plugin to see how it is done there. I'm surprised no one else has run into this? My next step is to try and implement the math to do the conversion in the program. Thanks again!
  21. Update - After investigating some more I'm even more confused. When I look at the Yolink temperature sensor node in the administrative console it shows the correct value in Fahrenheit, which is what is selected in the Yolink plugin in PG3. What I have noticed is that when I select Fahrenheit in the Program settings dialog box it does not reflect this setting when added to the Then clause in the program. Ex - The Yolink Node is at version 1.6.2 and is installed in slot 9 in PG3. I have noticed recently that when I synchronize UD Mobile with EISY it is complaining about a Status Name being missing for Node server 9. I'm not sure what this is about.
  22. I think there is possibly a bug in selecting the Fahrenheit temperature reading for a Yolink temperature sensor in a program. I'm working on displaying various Yolink temperature sensors in UD mobile. I have a program that reads a temperature sensor and assigns the temperature to a variable. When I check the variable it always shows the Celsius temperature regardless of selecting Fahrenheit or Celsius in the drop down box. When I check the node in PG3 it shows the correct temperature in Fahrenheit. I also have an Ambient Weather station and if I select Fahrenheit for it's temperature sensor I gets the correct number. In the PG3 Yolink configuration I have TEMP_UNIT set to F Is this correct? How does this interact with the Program dropdown selection of Fahrenheit vs Celsius?
  23. To add a bit more detail. After the 3 hr long internet disruption last night I have now figured out that the ELK Plugin was no longer communicating with EISY even after the internet access was restored. After I restarted the ELK Plugin things are back to normal. I have noticed this happen in the past (the ELK Plugin not communicating with EISY) but did not connect it with a loss of Internet connectivity. When this happened in the past restarting the plugin always fixed it. Loss of internet connectivity isn't always noticed unless someone is impacted by it, for example, if it happens in the middle of the night or if the disruption only lasts a few seconds. The next time the ELK plugin hangs up I'll check my router logs to see if an internet connection disruption has been logged.
  24. Thanks, this helps my understanding of how UD Mobile works with in a local only environment. I checked the UD Mobile local IP settings and the IP address was incorrect, likely due to some changes I had made to my network in the past. I do have static IP addresses for EISY and ELK in my network so in the future I should be able to have UD Mobile local access when the internet is down. I think my other question is still unanswered. Should EISY and Polyglot plugins be able to continue operating (communicating) when the internet connection is down? The functionality that isn't working is all over the local network through static IP address. Also, everything is connected with ethernet cables, not WiFi. If the UD Mobile local access will work (now) I can try an experiment of disconnecting the internet from my router and see if EISY and the ELK plugin are communicating properly. If the answer to this question is already known that would also help.
  25. Not sure if this is the right place to post this but I think this might be related to Polyglot so here goes. Our internet access has had intermittent outages recently (Xfinity) likely related to work being done by T-Mobile to install fiber in the neighborhood (how ironic). Each time there is an outage I lose functionality in the EISY system which I wouldn't expect to happen. I have not tried to debug this by creating outages but that's the next step if needed. Here are the details - I have an EISY system running IoX 5.9.1. I also have an ELK security system and the Polyglot ELK plugin for communication between the ELK system and EISY. I use the condition of ELK motion and door sensors to control various functions (like turning Insteon lights on and off, and relaying status through UD mobile of status events like a garage door opening). I understand that any functionality related to UD Mobile will not work during an internet outage but I would expect that internal network functionality would continue to work during the outage. I have a Unifi DM Pro network and I know the network is working properly during the outage. I can access IP cameras on my network as well as access local computers on my network and other local IoT devices. Am I missing something on expected local functionality during an internet outage? One other thing I have noticed is I can't launch the IoX Launcher during an internet outage. It tries to launch but eventually the application shuts down. Is this expected behavior?
