Everything posted by sanders2222
Google home vs Alexa
I've had both for a couple years now (at different houses). I'm in the GH camp & considering abandoning Alex altogether. Alexa's sound seems muffled... did she say "53 degrees" or "63 degrees". On Alexa they sound EXACTLY the same. Yet GH is clear, sharp and easily understood. Sound quality is way better. Plus you have the ability to choose between a number of "Voices". As for searching outside HA, GH is also superior. Alexa's answers remind of the typical Siri response: "I found this on the web!" I also like the Routines in GH too. Admittedly you may not need as many with Alexa for HA, but they are easily set up on either device.
What do Blue LED's on ISY mean?
On a need to know basis, I have no idea what the blue LED indicators on the ISY are telling me. I'm trying to solve a new problem the past week where a program I've had since the beginning of time sometimes will not execute, even manually. I've rebooted my ISY and noticed as it boots up, the blue LED on the left comes ON and 2-3 other LEDs blink a bit. After it boots, the left LED is solid ON, & the right LED flashes occasionally. After a while (next day) only the left LED stays ON, there is no blinking from any other LED. Is this some indication of a problem with the ISY or normal operation?
Vista 20P, Envisalink 4 & ISY994 is a NO GO
I did get a response from EyezON customer support but it somehow was thrown out with the SPAM mail. Since that got sorted, they have been very responsive and after a couple iterations of measuring continuity and voltages then testing, I think the conclusion is I received a "bad" board. Hopefully, they'll send a replacement soon that will work.
I understood that. In following the steps outlined as http//www.eyezon.com/EZMAIN/evl4honeywell.php , I could not get past step 3 on the top of the page. 3. Confirm that the "LINK" LED is on solid on the EnvisaLink and wait 10 minutes and the "OPER" LED is flashing slowly None of the lights on the Envisalink would light up and it seemed the card was "shorting" out the functionality of the Vista 20P panel & keypad. So much for programming anything at this point. I also triple & quadruple checked my wire connections. Thankfully, after removing the connections, there doesn't appear to be any damage to the panel's functionality.
I have a home that came with a Honeywell Vista 20P wireless security system. I like the idea of integrating the monitoring/controlling with the ISY. So I purchased an Envisalink 4 to l connect the system to the LAN. That part seemed pretty straight forward but . . . Following the instructions, I drilled 3 holes for the standoff mounting clips, disconnected the power source, wired the Envisalink 4 onto the Vista 20P panel and reconnected the power & battery. The system did not appear to power up completely. Not only did the Envisalink card indicators show life but the entire panel acted weird. While the kepad was back lighted, pressing key would produce a beep but the system could not arm or do anything else. (sigh) Is the Envisalink 4 defective & DOA? Or is is possible I need a bigger power supply transformer? Or something else? I disconnect the power, then removed the Envisalink wires and fortunately the system came back up & functions properly again. I submitted a ticket with EyezON but after waiting a week, nothing! NO RESPONSE. Nada. I sent a reply to the acknowledgment email guaranteeing 24-hour response. Still no response. I am not sure I want anything to do with a company that is this unresponsive & not interested in helping customers. I think I am to a point where returning this item to Amazon is my only choice!
Once configured, GH is tops - - mainly because my wife likes GH over Alexa. Now if Amazon introduces the 'Silver' . . .? https://youtu.be/YvT_gqs5ETk
universal devices unavailable right now
Having received no further responses from this forum that might help, I was ready to submit a ticket. Google Home cannot control U-D devices. Any spoken command to control an ISY device would result in a response "Universal Devices is unavailable" or words to that effect. My problem is created by having a home with Amazon Dot and this one with Google Home. Both share my ISY Portal account which complicates things a bit as each house move requires tweaking with the Portal settings. After trying different approaches for a week I suddenly stumbled onto the solution! SO I am posting this solution to help me or anyone else who may have this problem in the future. I started with trying to log onto the ISY Portal on my PC. I discovered passwords weren't working AND I had the wrong email account. Once past that hurdle and logged into the Portal, I tried to send my Spokens to Google Home when this message popped up. This got me to thinking the password in GH Assistant may be different (& therefore blocking access between GH & the ISY) Logging into the GH Settings on my cell, I used the Assistant and unlinked the U-D devices account, then re-linked it. (using correct account & password) BINGO! PROBLEM SOLVED!!!
My 1st post wrote: " GH can't communicate with U-D. .. (but) the GH app on my new cell phone can ..." To further test my cell's functionality, I was about to speak to the GH app on my cell and this message pops up: Change your Account You are currently using different Goggle Accounts for the Assistant and your Google Home. To continue, switch to the same account. And I can choose to Cancel or Change Account. When I clicked on Change, I discovered the Google account was for the other house. So I would chose another of my Google accounts and each time that message came up. Well that didn't work for the GH mini no matter what account I used (except the GH App on my cell always worked with any account). Hmmm. I may be on to something but what?
I'm not ready to give up on GH just yet. I have one home with Alexa but my vacation home had GH first. And it worked with much better AI & other options. I know the original post is a few years old but the "Universal-Devices unavailable" problem apparently still persists. I have never had this issue with Alexa DOT. I found after returning, GH can't communicate with U-D. Everything else seems to work fine. Plus the GH app on my new cell phone can even control U-D. So it seems GH can access the ISY. Just not the GH mini I have in the house. I tried unlinking U-D suggested in thread above, but that suggestion but that did not work. And when U-D was not linked, my GH mini gave me the same "Universal-Devices unavailable" reply. How can that be? I have 2 accounts and wonder if I need to unlink U-D from my account and my my wife's account to complete the unlinking. As good as Google AI is, I am a bit disappointed the GH tech support for this issue with U-D.
Alexa can't find new devices
I figured it out! What I was missing is the need to set my "Preferred ISY" to the home I am occupying! My Portal is set up with two ISYs, one for my home and 1 at a vacation home. I discovered I needed to change the Preferred ISY Mac address under the Portal USERS tab. Once I did that, Alexa was able to discover the devices I added to the portal and can now control them.. I'm providing this post as multiple ISY set ups is not covered in the Wiki to this detail. Plus when I move I will probably forget this minor detail. Now I'll have somewhere to go to find an answer to this dilemma.
Amazon Alexa + ISY Portal Not Reliable
This is interesting as I just happened to see something similar recently in my log. It appears there were 12(?) hacking attempts from 192.46.140.90 that were logged on 12-8. That is not an IP in my LAN and a Google search comes up with a 198-46-140-90-host.colocrossing.com which is listed as a SPAM hosting hacking site. Fortunately except for these 12 entries, I did not find any others. At any rate, I closed down my port forwarding to the ISY which hopefully secures my site. I set this forwarding up a long, long time ago for remote access to the ISY. Apparently port forwarding is not required when using the ISY portal. In fact I could never get port forwarding to work at a site where I had 2 routers in series to my ISY. But the ISY Portal never has had an issue seeing through all that to access the ISY. Amazing MOJO by U-D!
Best practices for naming lights and switches with Alexa?
I don't put all devices on my Alexa either. However, now I want to add "Holiday" lighting, how do I add a device? I have the device showing on the Portal now, but when I ask Alexa to discover new devices, she can't find any, Hmmmm, I must be missing a step!
It"s been a while since I initially set Alexa up, now I want to add a few more devices. I've added them to my Portal but when I ask Alexa to find new devices. . . Nada. I just get the "can't find . . ." response. Am I missing a step that tees up the devices for Echo's discovery?
Support Thread: 5.0.16C (ISY994)
Thanks for your response Michel. I suspect I am running into a Windows issue as I am able to call up the AC just fine on my laptop. Glad to say it appears the upgrade from 4.7.3 came through just fine. Now I just need to see why my desktop can't pull up the ISY Finder. AND it's currently going though an extensive Windows update this morning. Hopefully, when that is done, it fixes whatever. . . . (sigh) Update, the association was OK, but my Java 8u181 was apparently corrupt or broken. I uninstalled Java and then installed 8u231 and ALL is working. Your tip pointed me in the right direction. I'll close the ticket I started. Thanks again Michel.
I temporarily disabled firewall protection but the "start.jnlp" still would not launch. I submitted a ticket to help me sort out my issues.
No, I just opened the file. Following your suggestion, I saved it than ran it from my PC. Same result. I deleted the ISY Launcher icon on my desktop, went through all the steps again and only get a temporary splash screen.
WOW, Thanks for responding straight away and Happy Thanksgiving. I cleared the Java cache again. (I also noted the ISY Launcher on my desktop is never removed when I clear the Java cache.) When I clicked the link you provided I get the same response. A UD splash screen pops up for a bit then disappears. Not appearing to do anything. Perplexing.
Just tried upgrading from 4.7.3 following steps above. Cleared Java cache and opened the link http://isy.universal-devices.com/994i/5.0.16/admin.jnlp. I saw the Java splash screen then NADA, Nothing. So as of now, I cannot access the Admin Console. I tried an ISY reboot & tried to open the Finder, but these did not help. I asked Alexa to open a scene and that WORKED! I also checked the ISY portal and it WORKS as well. I can see v5.0.16, devices, programs and ELK status & find I can control devices. So it appears the system successfully upgraded with scenes and programs in tact, I just can't access the Console. I'll need to open a ticket to work through this issue.
Cannot re-link Universal Devices to Google Home
OK, Solved my issue, and that was: I have two ISY's linked to my ISY Portal (North Home & South Home). My Portal account specific the North Home as the "preferred device". Since I am in the south home, I figured out how to change it to the preferred device. Then I was able to get the Universal Devices re-linked to my GH mini. DUH! This also seem to resolve the "Universal Devices not available now" issue as well.
Not sure what happened between now & last spring. GH was set up with ISY and worked well. When we returned this fall, GH could not work the lights. Instead, I'd get response "Universal Devices is not available now". I checked this forum & found some older threads but the fixes (namely unlink/re-link UD from all user accounts) did not work for me. While I was able to unlink UD from all accounts, I find now I cannot re-link the device. I've tried rebooting GH and ISY, but nothing seems to work. I've gone though the steps to "add new" device serval times. I can select UD and the ISY Portal window opens. I then log in and while it appears to be linking, my phone app jumps to the device screen. I go back to see if the device was added, UD is still missing. Any help would be appreciated.
Notification Reliability
OK, I know this post may be a bit stale, but I have a similar issue, only ALL my notifications are failing. I suspected it was initially caused by and update to my Gmail account, then went through the steps in the Wiki and confirmed other needed changes were made, including the Gmail setting to allow access from less secure apps. However, I still cannot get any of the notices to come through to me. UPDATE: I think I resolved the issue. I had checked "access from less secure apps" on the wrong gmail account (DUH!) Once I checked this on my Home account, messages started arriving.
Alexa not that simple . . .
Good ideas, I forgot my Elk produces the garage door open reminder. I need to to put some thought into how the welcome home could work. I would need some sort of timer when Elk is disarmed so the announcement doesn't occur every time someone comes through the door. I have an older whole home audio system. So with blue tooth and using routines, I should be able to send the announcements through all our home speakers, not just the the little Elk speaker. From my limited experience with Google Home, I did not know about "routines". A pretty powerful tool.
Routines appear to be a powerful tool & I'm just getting started. "Alexa, Watch Movie" and "Alexa, Arm Away" commands run my programs as you suggested! Thanks for that tip. Better than saying "Alexa, Arm Away On" I think. Now I should be able to create a routine that replaces my Tuesday reminder "Please take storage up driveway" (by my ELK w/ limited vocabulary) with Alexa stating "Please take the recycle bins up road". But first I will have to upgrade my ELK for Win10 so I can delete the notification. Not looking much forward to that.
What about programs? I added a program to the portal that is called by my remote control & it's labeled a scene for Alexa. The program dims lights to specified levels for movie watching. However when I use the spoken "watch movie" Alexa responds "I can't find any video skills that supports that." Can you trigger programs with the Alexa?
Alexa controls my lighting scenes as defined above. I say "Alexa, turn on the kitchen lights" and both switches (& lights) in the scene respond.
