Everything posted by Ristin
eisy-ui 1.3.4 - Integrated plugins (Beta)
After reading this thread, I updated to the latest EISY version, 1.4.6 I decided to try the plugin migration. I migrated one plug in at a time. (I only have 8) Notification migrated and seems to work Wemo migrated and appeared to be operational but I could no longer connect or control Wemo devices. NOAA would not migrate and produced this error: Bluetooth migrated and appeared to be working, but I lost connection to my Home Pod and old Cync devices that use Bluetooth. Kasa migrated and appeared to be working, but lost connection to Kasa & Tapo devices. iox-matter can't migrate, not in production store. Tried EISY reboot, tried EISY power off and restart. No change Migrated inoperative plugins back to PG3 and devices are functional again.
IoX 6.1.1 let's discuss it!
Usually as soon as I hear of an upgrade and I jump in without reading the forums or making a backup,,,,, That has caused "issues" in the past. This time I decided to wait a while before upgrading AND read through this thread. I created back ups and then started the upgrade. I never received definitive feedback that the upgrade completed, however I did get prompted for my user name & password several times during the process. Eventually the Admin console went through the startup process but got stuck at "Creating Widgets". I left it alone but after 40 minutes, I decided it was stuck. I couldn't cancel out and I couldn't close Admin console. I disconnected the power cord from the Eisy and let it be for a few minutes. I had to kill Admin Console via Task Manager. Power up and boot seemed to take longer the first time, but once loaded, all my devices showed up and worked properly. No issues with plug-ins and my programs are functioning. I have a first gen EISY with Zmatter dongle, and Insteon PLM. I run Insteon, Zwave, Zigbee and matter devices. I have Wemo & Kasa plugins with associated devices. The only other sort of issue after the upgrade was Apple Home could no longer communicate with the Eisy. I removed the Eisy from Home and tried to re-add. Initially, Home would not re-add the Eisy. I waited about 30 minutes and tried again. Home accepted Eisy with no further issues and is working properly. Kudos to the UD developers and everyone else involved!
Successfully connected a matter bulb
Guy, I missed the replies on this thread. Yes, I was on 6.0.5 (still am) Since then, I have successfully direct added several Tapo P125M plugs via Matter.
I added it directly through UD mobile "add matter device with QR code". I don't have another platform to add with. Initially, I wasn't trying to add the bulb to the EISY. My non-device porch light burned out and I was out of regular bulbs. I remembered I had the Linkind bulb so I installed it until I could get to town for new regular bulbs. In the past I was unable to add the Linkind bulb and had given up on them. However, when I powered on the bulb it started flashing to indicate pairing mode. On a whim I tried to pair it using UD Mobile. I was very surprised when it paired and the color slider toggle icon appeared in the Home section.
After months of limited success with matter, I successfully added this bulb to Matter. These are inexpensive on Amazon
EISY, Matter, Apple Home
Not looking for solutions per se, just curious about what's going on. A bit of back story, I work out of state and am gone for 2-3 weeks at a time. Seems like every time I come home I find changes with my system. A couple months ago, I successfully connected a Tapo P125M switch and a generic Matter light bulb I got from Amazon via Matter. I only had on/off control of the bulb, but still it was Matter progress. Both Matter devices worked perfectly via UD Mobile. At that time I also had Apple Home installed, but no Apple hubs/bridges. In Home, Home settings, the EISY showed up under Home Hubs & Bridges. I'm also playing with GE Cync color bulbs and GE Cync plugs that I picked up super cheap at a discount warehouse. These Cync devices are not Matter compatible. However, while using them, when I looked at the devices connection path, and at least one Cync device would show as connected to the EISY via Bluetooth even though I couldn't add/control the Cync devices with EISY/UD Mobile. Current state: I came home last week and discovered neither matter device was connected. I tried rebooting the EISY, syncing UD Mobile and finally removing and re-adding the matter devices. I have not been able to re-add the matter devices as matter devices. I gave up on the cheap Amazon bulb and used the Kasa plugin to re-add the Tapo P125M plugs. I personally have made no changes to EISY or UD Mobile configurations from when the Matter devices worked to not working. EISY may have updated while I was gone, and fairly certain there was a UD Mobile for iOs update as well. Also I noticed, EISY does not show up as a Hub/Bridge in Apple Home anymore and none of the Cync devices are using EISY as a connection point anymore. I tried adding a new Tapo P125M as a matter device and got as far as being asked to assign a name to the new plug. While typing in the name, UD Mobile screen turned grey in the background and an error msg popped up. When I clicked next after entering a device name, the entire processed failed and I was never able to get that far again. I have now added an 2nd gen Apple Home Pod, which shows up as a Hub/Bridge in Apple Home, but I still can't add Matter devices. Anywho, I know Matter is still in development and that I am mostly clueless and my issues could be self inflicted. Just seemed like there had been a giant leap in Matter functionality and then a big step backwards. If you made it this far, thanks, and if you have any suggestions or insights, I would greatly appreciate it. Please don't suggest I give up on Matter. Now that I know it exists, I have to keep poking at it. I'm the guy that has the overwhelming compulsion to press the big red button that says "Do not push this button" 🙂
Favorites gone
I'm having the same issue since the most recent update. (iOs version 1.4.3) Closing the app and re-opening will bring my favorites back. However, after an unknown amount of app inactivity, the favorites page will revert back to a clone of the home page and I'll have to close/reopen. Home page: Favorites page: After app restart:
UD mobile errors after EISY upgrade to 6.0
I've updated to the latest version. Now I get some errors using UD mobile. When UD Mobile is on the same LAN as the EISY and I select Configuration - Portals, I receive this error: When I'm off my local LAN, I can access the Configuration - Portals page properly. Issue 2: When UD Mobile is connected to my local LAN, all my devices work with out error. However when I'm not on my local LAN and I select a Kasa or Wemo device, I receive this error: After tapping OK, the device will turn on/off as requested, so more of an annoyance than a show stopper.
eisy 6.0.0
I tried this update yesterday after receiving the email and I ran into the same issues as the users in this thread.
Matter for Dummies?
Hasn't work for me yet. Tried a matter plug & light bulb.
EISY IP Hostname setup
I don't see the host name on IPv4. I do see the host name with IPv6. I'm running the latest release (updated a few says ago), I have a dedicated IPv4 DHCP address for EISY, and my router is a micro PC running pfSense.
Matter for Dummies?
Thanks! I'll stop wasting my time with the Cync devices. I typically only buy devices that I know work with EISY, but I got the Cync devices from the local liquidator store and were cheap enough not to be a bother if they didn't work. I did find some Matter light bulbs (saw the matter logo) on Amazon last night. They are inexpensive enough to order and play with. I'm sure the code whisperers at UD are working diligently to make Matter, matter.
Matter for Dummies?
I need a Dummies guide to the recently added Beta Matter. I've been messing with it but have not been able to connect to anything. I don't know if I even have the right hardware or if the iOS version works yet. Equipment: EISY with latest updates. Z-matter board iOS 18.3.2 running latest version of UD mobile. I have a mix of Insteon and z-wave devices, and a couple Wemo devices via the Wemo plug-in. Matter shows online & active in the administrative console and shows online in UD Mobile Questions: Is additional hardware required? ( i don't have Alexa or Google home) Where do I use the pairing QR code that is listed in the Iox-Matter plugin notifications? Are GE Cync devices actually Matter devices? I have 3 Cync Reveal color bulbs and 3 plugs. What little info I find seems to indicate yes, but I can't connect to them. (Again no idea what I'm doing) I did install Apple Homekit on my phone and when I select add devices, occasionally a Matter device will be listed but I'm unable to connect. Homekit can't seem to read the QR code on the plug and there were no QR codes on the packaging. Thanks
Where do plugins come from?
Just received an email from U-Tec introducing the Matter version of of the Bolt lock series. Ultraloq Bolt Finger Print Matter
Thanks for the replies. Very informative and way outside my wheelhouse. Last time I tried programming was high school computer class on an IBM XT/286
How do plugins come to be? I just bought two wifi Ultraloq Pro's before I discovered the z-wave versions. I'd like to control the locks from UD Mobile, but not bad enough to return the wifi versions for the z-wave versions. And also, I'm just curious how plugins are made. Thanks
What are hints
What are hints for in the device dashboard? It's down in the info section Example: Hint 0.0.0.112
No remote access through Portal
Disregard. I rebooted the EISY and all has returned to normal.
On Monday remote access was working. Last night I discovered remote access was not working and as of this morning still isn't working. UD Mobile is running on an iPhone 14 Pro, AT&T is the provider. All other internet related items work correctly on the phone. I have made no changes to my EISY, UD Mobile or my network/internet setup. When I attempt attempt to test remote access or try to use a device remotely, I receive a popup stating: ERROR - There are no proxies available. I am unable to access my EISY from the Portal webpage. After login the main page shows my EISY and has a green light but clicking any of the tools generates an error. Clicking ISY Web Access I get - Error accessing /rest/status: Internal Server Error. Clicking ISY information gets me an HTTP Error 500 My Portal license is valid. When connected to my home network via wifi, everything works as normal.
Enbrighten direct wire indoor/outdoor switch doesn't stay connected
lilyoyo1, I bow to you.Your Kung Fu is mighty! I moved the ISY to an exterior window closest to the Enbrighton switch and it now works perfectly. Guess I need to add more line voltage powered z-wave devices to that room to act as repeaters? Thanks
Thanks for the reply. I've read though the Tips & Tricks a couple times. I guess I don't understand Z-wave enough for that to help me. Signal range doesn't seem to be the problem. Now that I've had more time to mess with the switch, I've found that when I press the manual on/off (program) switch on the Enbrighten, it will connect to the ISY for about 3 minutes. During this 3 minutes I can turn the switch on/off remotely and query the energy monitor. During the 3 minutes Agave will see the switch and allow me to control the Enbrighten. After 3 minutes the switch goes dark and the ISY reports no connection and the device disappears from Agave. Press the manual switch on the Enbrighten and it reconnects for another 3 minutes. I've also noticed that the switch does reconnect by itself at some point every 24 hours. Even though I don't have real time communication with the switch, the energy monitor will send an update during the night. I also learned the Enbrighten will respond to queued on/off commands during that middle of the night wake up even though UD Mobile will complain the device isn't connected.
I just installed this switch. I put the on/off switch in the z-wave position and pressed the program button while having my ISY add a z-wave device. The ISY found the Enbrighten switch, connected and installed. Everything was great, for about 2 minutes. Then the ISY lost communication with the switch. I tapped the program button on the Enbrighten and z-wave reconnected and worked fine for another couple minutes. The ISY has no issue reconnecting with the switch but won't stay reconnected. I've just started working with z-wave devices and know very little about the protocol. My other z-wave device is a smoke detector and seems to work ok. The switch is only 20ish feet from the ISY but I did move the ISY closer to see if that helped. No change, same issue. After reading some z-wave posts I updated the ISY's firmware to 5.3.4. Still having issue.
I think my 994ZW+ is dying?
- I think my 994ZW+ is dying?
Dang it! Just realized I posted in the wrong forum sub-topic.- I think my 994ZW+ is dying?
A few months ago the power light started to flicker and go dim. It got progressively worse until now the LED is dim all the time. A quick google indicated the power supply was the likely culprit. Changed the power supply but the LED was still dim. The Rx, TX and Memory LEDS are still retina searing bright so maybe the power LED is going bad? Since everything else was functioning properly I didn't worry about it. Jump ahead a month and I start noticing that every time a door sensor is triggered the ceiling fan lights would briefly flicker. Happens on both fanlinc controlled ceiling fans. Jump ahead again and I noticed one obscure program wasn't working. I don't know how long the program hasn't been working. I logged into the ISY yesterday to investigate and got the following errors: On top of this error, nine more dialogs pop up but they are all blank. Clicking each one closed, this dialog popped up: However nothing loads, its just stuck until I click the close X. I do have internet connectivity and the portal indicates it can communicate with the ISY. Agave can communicate locally and remotely. Clicking Yes shuts down the console, clicking No leaves the console open With the console open, each time I click a tab I get the Java error pictured above, but after closing the error dialog I can make changes. The console isn't displaying any device states but I can control the devices via console. While clicking through menus I also noticed this: I do have the Z-Wave dongle installed. I don't have any Z-wave devices but normally there would be a menu here for configuring Z-wave. and finally after a reboot right before staring this post I received all the above errors and these as well: I tried deleting the Java cache as listed in another post but that didn't change anything. I had planned on upgrading to a Polisy in the near future only to learn Polisy is no more and now its Eisy. I'm happy to upgrade to Eisy but I've been spending money like a drunken sailor the last two months and need to build up the frivolous expenditures account before buying Eisy, so the ISY needs to last another month or so. I guess I need to figure out if this is a hardware or software issue so it doesn't follow me to the Eisy. So the TL;DR of this long post is: Is my hardware failing or do I have a software issue? Thanks - I think my 994ZW+ is dying?
