Michel Kohanim
Administrators
Everything posted by Michel Kohanim
  1. You need to switch to staging, and then upgrade udx first. Then you can go back to Beta/Production and from then on, you can upgrade using eisy-ui. With kind regards, Michel
  2. They should be fixed in the next eisy-ui release. With kind regards, Michel
  3. @apostolakisl , if you are in the staging repo, we made massive changes to support polisy upgrade through eisy-ui (udx 5.0.0_7 to be exact). The only thing is that it will not upgrade the OS above 14.3p5 AND we have no way of testing everything against the old OS. So, although we believe things should continue working, it's just not a guarantee. With kind regards, Michel
  4. @oberkc , we need specific feedback. With kind regards, Michel
  5. Thank you very much for the detailed description With kind regards, Michel
  6. @jrainey , yes, you should be able to. With kind regards, Michel
  7. @jrainey , We don't enhancements on Polisy. But as long as we are in OS14, you can upgrade manually using ssh sudo repo.util (move to staging) sudo pkg upgrade udx isy eisyui
  8. @hart2hart , Please note that your devices must support LR for that to work. Not all do. With kind regards, Michel
  9. @Guy Lavoie , Please submit a ticket and we'll take it from there. With kind regards, Michel
  10. @Guy Lavoie , I doubt it. What exactly is the model number? An Amazon link would be great. With kind regards, Michel
  11. @mmb , currently, if you give it a problem, such as why this is/is not happening, it will review your logs, then reviews all your programs to come up with a reason. It can also summarize all your programs in a folder as well as find relevant programs. It can also figure out if the logic doesn't make sense. What it can't (yet) do is to answer generic questions without any context. For instance, what type of problems? Also, this plugin is configurable to use Claude, ChatGPT, and Grok. So the more expensive the model you use, the better the reasoning. Everything I described above is based on the least expensive models (Claude Haiku and GPT Luna). With kind regards, Michel
  12. Already does very complex ones and can spot and fix errors. With kind regards, Michel
  13. I'd like to hijack this thread and tease you with our upcoming feature: eisy-ai ! With kind regards, Michel
  14. Hello everyone, Just a teaser for eisy-ai to be in beta soon. If you want to have early access and provide your invaluable feedback for features/enhancements, please make sure to sign up for our focus group. P.S. This is from my home and 100% live feedback. With kind regards, Michel
  15. Yes, because you local plugins are "developer" made/deployed, so I am assuming you already know how to ssh and do things on the command line. With kind regards, Michel
  16. Hello everyone, You should not have to uninstall and reinstall "local" plugins. What you need to do is to remove the cert and key files so that they can be regenerated at install time. With kind regarsds, Michel
  17. @sjenkins Local means that it's neither in beta nor production. With kind regards, Michel
  18. @Guy Lavoie , if it's a local only plugin, you need to reinstall it. The migration process upgrades the certificates for production plugins installed in /var/polyglot/pg3 but it does nothing for local ones. With kind regards, Michel
  19. What exactly is the issue with that (sometimes, too much information is not a good idea). The system has 8GB, it uses as much as it needs to keep things smooth (rather than using the swap space). Please note that eisy | lite only has 4GB, and it also used 96% of its memory and still does perfectly fine. In short, please do not spend too much time analyzing "one" number. If you really want to analyze memory usage, you need to use many tools (top, vmstat, procstat, etc.) and figure out what's using what. In my view, 100% futile especially if you don't have any problems with the system. With kind regards, Michel
  20. Hello everyone, my sincere apologies. I was looking at the wrong thing. Memory is the RAM and Storage is the hard drive. Those values all seem correct. With kind regards, Michel
  21. @Techman , Impossible. You have a partition called storage. This is absolutely not the original partition. @Geddy , This is the size of zfs root is about 35G on eisy. It's more on eisy r2. As long as it's less then 50% I would not worry about it at all. With kind regards, Michel
  22. @Techman , Someone has partitioned your disk. Again, boot environments are NOT partitions. What's your storage partition?
  23. @xlurkr , The repos are locked for polisy. So, next time you need to upgrade, just repeat the same command and use prod. Again, this only temporarily unlocks the repo (till next boot). No other side effects.
  24. Please do sudo repo.util and switch to staging. With kind regards, Michel
  25. They probably don't report energy cluster. You can use Zigbee menu | Capture Log | Start and remove/add them again. You should see energy cluster reported if they support it. With kind regards, Michel
