Broyd
Members-
Posts
271 -
Joined
Last visited
Everything posted by Broyd
I've had this problem with several X-10 chimes. The problem is tuning. Open the chime and you well see a small square tunable coil. It is in a shiny aluminum can. There is a threaded tuning slug in the can that you can access from the top of the can. Be very careful of the wires that connect to the piezo sounder; they are soldered to this sounder but will not take much flexing. Obviously you must have the chime plugged into your 120Volt house wiring to do this test with the CASE OPEN - MEANING 120 VOLTS are exposed and you could make contact with those exposed connections if you aren't careful or watchful of what you are doing. What I do is set up a X-10 trigger program in the ISY that I can trigger with a push button like a mini remote. (You can't use the power unplugging method to do this; it must be a real X-10 signal.) MARK the position of the slot in the tuning slug with a fine felt pen on the aluminum can so you can get back to your original position if necessary. Using a NON-METALLIC tool (the slug is magnetic, you can't use a metallic screwdriver with a iron or steel blade. a metallic tool drastically affects the magnetic properties of the slug. using a metal blade will render this testing useless.), having a plastic blade that fits in the tuning slug slot, rotate the tuning slug by very small amounts; TESTING the chime with every small rotation of the slug. You may find the chime starts to work again. You will likely have to try rotating the slug in both clockwise and counterclockwise directions. If this doesn't fix the problem, the part of the chime that detects the X-10 signal may have failed. In my case, I have found these chimes are quite sensitive to temperature, particularly the summer heat. They quit working when my house gets hot. Tuning them slightly has fixed the problem for me. It may take more than one turn of the slug. COUNT the TURNS!
Yes, it is happening to me as well. GMail has changed to Oauth2. So far, I don’t have a solution either. Would changing the ISY’s authentication method to allow for Oauth2 work? I got an email from google some weeks ago that this change was in the works.
I've tried all variations of sending an 200 OK status and there has been no change. I am still getting the exact same message. Incidentally I send network resources to other Python scripts and also get a similar message, only Rule: 65 ... It would be satisfying to be able to send an accepted response, but it actually doesn't seem to matter because the receiving device handles the content of the network resource exactly the way I intended, in all cases.
- 3 replies
- esp32
- micropython
(and 1 more)
Tagged with:
Thanks MrBill, is there a list of the network module rules anywhere?
- 3 replies
- esp32
- micropython
(and 1 more)
Tagged with:
I have an ESP32 device running micro-python to which I send a network resource as shown below. http://192.168.1.150/qry The IP address of the ESP32 is '192.168.1.150' and the command is 'qry'. The resource is sent correctly by the ISY and received correctly by the ESP32. The ESP32 process the 'qry' command just the way it is supposed to. However, I get the following response from the ISY when I test this network resource: "TCP client read response failed. Net Module Rule: 68" MY question is: Does anyone know what is required to be sent back to the ISY such that it will form a valid response to receiving the network resource? I'd just like to get a 'clean' response. What I am currently sending back as a response to the ISY, using Python in the ESP32 is as follows: conn.send('HTTP/1.1 200 OK\n') conn.send('Content-Type: text/html\n') conn.send('Connection: close\n\n') conn.send('<html><head>') conn.send('<link rel="icon" href="data:,">') # prevent browser from requesting favicon.ico conn.send('</head>\n\n') conn.close() I have tried removing the three lines about favicon, but I am getting the same error message: conn.send('<html><head>') conn.send('<link rel="icon" href="data:,">') # prevent browser from requesting favicon.ico conn.send('</head>\n\n') This response works fine when I send the network resource from a browser (Firefox). Thanks for any insight on this :). (I'm not sure resolving this is actually required because the ESP32 processes the command fine.)
- 3 replies
- esp32
- micropython
(and 1 more)
Tagged with:
Initially I was looking for a method to shutdown a Windows PC by sending a 'something' to the PC using a network resource. This involved setting up a task on the Windows PC that could listen on a port and respond to a shutdown command set from the ISY. This task would have to be loaded when the PC was booted. When I had a closer look at this, I realized that I also wanted a task that would play an alarm after the PC was fully booted up. So in the end, I set up 3 python scripts to accomplish this; I am including them here in the event that someone else might find them useful. The first python script's purpose is to start the two other scripts independently and asynchronously. That is these two scripts run as if they were started one at a time with no dependencies associated between either script. They run and terminate independently of each other. So ... here are the three python scripts # First, RunProcesses.py import os from multiprocessing import Pool from time import sleep processes = ('C:\PythonScripts\PIII-10G-ShutDown.py', 'C:\PythonScripts\Pythonplaysound.py') def run_process(process): print('\nRunning process: ' + process) os.system('python {}'.format(process)) def main() : pool = Pool(processes=2) pool.map_async(run_process, processes) if __name__ == '__main__': print('Starting MAIN') main() print('Finishing MAIN') sleep(2) ---=== End of Script ===--- # Second, PIII-10G-ShutDown.py # I give credit to larryllix for the core of this script; I grabbed it from the forum many moons ago. import os import sys import time import datetime from http.server import BaseHTTPRequestHandler, HTTPServer # HTTPRequestHandler class (HTTP requests, either from a browser or the ISY994i are handled using this class. class myHTTPServer_RequestHandler(BaseHTTPRequestHandler): def do_GET(self): self.send_response_only(200) words = self.requestline.split() params = words[1].split("/",2) #debug stuff #print("\n\nNumber of parmameters in input string:", str(len(params))) #print("\nInput string passed into Python:", words) #print("\nParameters received: ", params) Arg1 = params[1] if Arg1 == "Shutdown" : print("\nShutdown received.") os.system('"C:\ShutDown.bat"') elif Arg1 == "StartXYZ" : print("\nStarting Program XYZ.") os.system('"C:\XYZ.bat"') else : print("\nUnanticipated command received: " + str(Arg1)) # Server settings def run(): #print('\nStarting server...') server_address = ('192.168.1.4', 10738) httpd = HTTPServer(server_address, myHTTPServer_RequestHandler) print('\n' * 2) print('Running server...') print('\n' * 2) httpd.serve_forever() run() ---=== End of Script ===--- ~~~~~~~~~ A quick note on the shutdown script above. I set up and used English words in my Network Resource PATH item. You could use variable substitution (numbers) instead which allow any number of functions (for the python script) to use one Network Resource. ~~~~~~~~~ # Third, Pythonplaysound.py from time import sleep from playsound import playsound print('\nBig Ben initiated.') sleep(210) # Note:- use of the FORWARD slash in the filename for playsound playsound('C:/PythonScripts/BigBenClockCV3.mp3') # print('\nBig Ben completed.') ---=== End of Script ===--- And finally, the ISY network resource: Protocol Information: http GET Host: 192.168.1.4 Port: 10,738 Path: /Shutdown Timeout: 500
Where did "Shift Primary to another Controller go?"
Broyd replied to TriLife's topic in Z-Wave - Series 300/500
So I managed to add the Z-Stick to the ISY as a secondary controller. If you haven't already done so, you will need Zensys Tools. You can get it from the link at the bottom of this page: https://aeotec.freshdesk.com/support/solutions/articles/6000226205 Now follow the steps on this page: https://www.activeautomation.co.nz/boards/topic/3/adding-aeotec-z-stick-as-a-second-controller-to-an-existing-z-wave-network When the Zensys Tools page comes up, the right side panel is the NODE panel. But there was NO title on it. There are two icons on that right panel, the lightning bolt and the X. X resets the Z-Stick. The lightning bolt puts the Z-Stick in learn mode. I've added the Z-Stick several times. If I DELETE the Z-Stick from the ISY, the only way I can remove the links from the ISY in the left panel of the Zensys Tools panel is to click the X button which resets the Z-Stick, removing the links. So ... 1. Z Tools: Click the lightning bolt. It will bring up a panel saying the controller is working in learning mode. (Maybe have to click twice if the panel does not come up). 2. ISY: Z-Wave Add device (to the Z-wane network). Now watch the ISY's 'add Z-Wave device info panel'; it should add the Z-Stick. The LEFT Zensys Tools panel should now show all of your Z-Wave devices and their link numbers that are in the ISY. I haven't taken the next step though ... to upgrade the MultiSensor 6's firmware. Not really sure what I do next as the MS's are members of the ISY device ... So ... if you delete the Z-Stick from the ISY, all I could do to remove it is right click on the z-wave controller and select delete. In the Zensys Tools window, all I could do to remove the 'ISY' links was select the X to reset the Z-Stick. A question for you: does resetting the Z-Wave dongle in the ISY reset all the node numbers? Or do you have to reset the whole ISY to accomplish this? -
I’m with you on this one and I’m in the exact same position. It seems that UDI has lost some stuff with their new dongle. -
Thanks Mr. Bill, I have checked those numbers against my network resources and it seems very likely you are correct. They were the resources I was using at the time these error messages occurred. I'll have to watch carefully to see if I can figure out what I'm doing wrong. Perhaps I need more delay between commands.
Hi folks, My question is where or how do I find out the meaning of the numerical codes for the Net Module Rules shown in the collection of these codes I have taken from the ISY Error Log (the numbers at the end of the lines; 11, 27, 29, 38)? I am working with a bunch of Network Resources to control my home theatre system. And I am slowly working out most of the problems I've been having (such as getting working IR codes from a Global Cache IP2IR module). -140005 HTTP_CLIENT_READ_RESPONSE_FAILED Sun 2021/06/20 10:31:43 AM System -140005 Net Module Rule: 11 Sun 2021/06/20 10:26:09 AM System -140005 Net Module Rule: 27 Sun 2021/06/20 10:26:10 AM System -140005 Net Module Rule: 29 Sun 2021/06/20 10:32:15 AM System -140005 Net Module Rule: 38 I'm guessing these numerical codes are generated from the HTTP CLIENT in the ISY and that the ISY is just writing them to the error log. But in any case, is there a document explaining what the codes mean?
Once again, thanks to all of you. I am sure now of how And - Or work. And based on all of your replies, I have done my own testing; nothing works better than seeing the results for yourself. And I know what to expect from the time within construct now. Appreciated
Is the from - to time construct a control or status condition? Thanks
Thank all 3 of you very much for taking the time to provide me with such detailed responses. Much appreciated. I asked for an understanding of ISY programming logic and you provided excellent and complete detailed descriptions of what is happening; more than sufficient to understand things, especially the 'time within' logic. I couldn't have gotten better advice! And thanks Goose66 for your programming example; I will use it to alter my programming setup. I am bothered a little bit though; it kinda 'sticks in my craw' ... that there seems to be no difference to the way the IF statement works whether the operand I used, 'And' is changed to 'Or'. I'll switch it today and see what results I get tomorrow morning :). I expect that the ISY response will be the same. But that would be ok, it would be the way it is. I realize the number of text and/or emails I get is because of the double notifies ... I did this because occasionally I do not get every notify and this logic is an attempt to get at least one. This has worked for me on a number of occasions.
UI and firmware both at 5.3.0. The program: I am having trouble figuring out the ISY logic interpretation in this program. Sunrise - [ID 0024][Parent 003D] If 'South - MS - Dawn Dusk' is switched Off And From 6:00:00AM To 9:30:00AM (same day) Then $Sunset.Flag = 0 Send Notification to 'Broyd' content 'Sunrise Now' Wait 1 minute Send Notification to 'Broyd' content 'Sunrise Now' Else $Sunset.Flag = 0 Send Notification to 'Broyd.Email' content 'Sunrise Now' Wait 1 minute Send Notification to 'Broyd.Email' content 'Sunrise Now' Motion Sensor dawn/dusk detector is switched OFF at Sunrise ============ My question: I am having trouble figuring out the ISY logic interpretation in this program. First: (Just in case you were wondering) The justification for this program is to verify the functioning of both TEXT messages (Broyd) and email messages (Broyd.Email) for important notifications such as leak detection. I have had trouble in the past with notifications and this program lets me weed out problems before I need to receive a more serious notification. And I don't want to be awakened by a TEXT message that is accompanied by a loud tune so I switch between a text and an email ... My UNDERSTANDING: of ISY logic ... hmmm ... The IF statement contains TWO conditions coupled with AND ... - as an independent condition, the first condition is a CONTROL statement that is triggered ONLY ONCE when the dawn/dusk sensor is switched OFF (this happens in the morning) - as an independent condition, the second condition is triggered TWICE, once at 6AM and again at 9:30AM - BUT the AND operator couples these two conditions such that if the dawn/dusk sensor is switched OFF AND the time is within the time between 6AM and 9:30AM then the program runs the THEN clause. But if the dawn/dusk sensor is switched off AND the time is outside the time window, then the program runs the ELSE clause. What happens: - My dawn/dusk sensor switched OFF this morning at 5:21AM and I received two emails, that is, the ELSE clause was run once at 5:20:47AM and another at 5:21:47AM. This is exactly what I expected to happen. BUT ... and now we get to the bit that is confusing me ... - I get 4 more Emails (the ELSE clause is run 4 more times), at 6:00AM, 6:01AM. 9:30AM and 9:31AM It seems to me that my two IF conditions are actually being coupled with an OR operator. What I need to understand: So why does this program even run at 6AM and 9:30AM? Why does the IF statement not take into account that the dark/dusk sensor was only switched off at 5:20AM, not at 6 or 9:30AM, namely the first condition in the IF statement? Thanks for your insights ... (BTW: I can fix the program easily enough to run the way I want, but what I want to do is understand the why.)
It all depends on what your Homelink feature in your car can learn. You take a handheld remote control, put it very close to the Homelink unit in your car, put Homelink into learn mode and maybe/hopefully it will learn a command from your remote when you press a button on the remote control. I know it can learn X-10 commands. Maybe it can learn Insteon commands from one of those tiny insteon remote controls. Then it depends on whether that command being sent from your car can be received by your insteon network in your house. If it can you can write any program you want in the ISY.
I am still using several X10 modules, 2 of which are 25+ years old and am using the latest firmware. All the X10 modules work fine. Also I upgrade the firmware whenever a new version is released and have never had the problem you’ve got. Maybe you have something generating line noise or your PLM is degrading. How old is your PLM?
Hi folks! I just wanted to thank everyone who contributed to this thread. It allowed me to accomplish in an hour or so what otherwise would have likely taken me days (or more)! This includes all of the nuances of the iTach IP2IR unit, it's software, and all of the links to other posts on other sites and the accompanying resources. Best regards!
New ISY994iZW+IR PRO... Cant find devices...
Broyd replied to djgunner's topic in New user? Having trouble? Start here
The Insteon signaling is junk. Open one up, you’ll see what I mean. Compare it to a Leviton 6299. Open it up and you’ll see a well designed band pass filter. On the top is the Insteon unit. The Insteon circuit board is marked with an inductor but it’s only a resistor. -
FYI: The ISY only receives Z-Wave RF and Zigbee RF directly, and IR. All other powerline and RF communication is through the PLM. Have you tried removing one of your motion sensors from the ISY and then readding it to see if the ISY can find it?
Thanks larryllix, I’m pretty sure I did that (because I always clear all of them) but I’ll try it again later when I get time. I just tested this and I can start the console with start.jnlp but I get the same error (Java 10.0.2) and no icon gets created. I can start the ISY finder with start.jnlp, it just doesn't create a proper shortcut.
What version of Java? I have this problem with Windows 7 SP1 and that problem occurred with both Java 8 (181) and Java 10 (10.0.2). My solution is the same as yours. The problem occurs with both admin.jnlp and start.jnlp. For Java 10 I got a popup message saying that: Missing Application-Name manifest attribute for: https://isy.universal-devices.com/launcher/isyfinder-1.3.jar Warning: Java Web Start and Java Plug-in are deprecated and will be considered for removal in a future Java release. Please contact the developer of this content "Universal Devices Inc." and request an update for this program.
That message is one of the most misleading messages the ISY team have ever created! The implication behind this message involves the ISY setting up port forwarding on your router so that you can access the ISY from OUTSIDE your network. If you aren’t planning on doing this, you can ignore that message. Or if you are planning on accessing your ISY from outside your network, set up a port on your router manually. I believe the ISY function depends on enabling UPnP on your router. In my opinion this is an unsafe practice.
CLOSED --- Z-Wave 500 Series Beta
Broyd replied to Michel Kohanim's topic in Z-Wave - Series 300/500
Event Viewer: Device Communication Events: ISY-Events-Log.v5.0.13A__Sun 2018.07.22 09.47.35 AM.txt This is the output for a change in temperature from a Multisensor 6. Are all of these groups of messages normal and/or expected? [ZWAVE-TX ] ... [ZWAVE-RD ] [010A001318038003642500C9] REQ ZW_SEND_DATA [ZWAVE-RX ZW024_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x18 Sun 07/22/2018 09:47:18 AM : [ZWAVE-RX ZW024_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x18 Sun 07/22/2018 09:47:18 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:47:19 AM : [ZWAVE-RD ] [010D001318063105012A02E22500D7] REQ ZW_SEND_DATA Sun 07/22/2018 09:47:19 AM : [ZWAVE ZW024_1] Process value Sensor type=1 scale=1 prec=1 Sun 07/22/2018 09:47:19 AM : [D2D EVENT ] Event [ZW024_1] [CLITEMP] [738] uom=17 prec=1 Sun 07/22/2018 09:47:19 AM : [ ZW024_1] CLITEMP 738 (uom=17 prec=1) Sun 07/22/2018 09:47:19 AM : [ZWAVE-RX ZW024_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x18 Sun 07/22/2018 09:47:19 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:47:20 AM : [ZWAVE-RD ] [010C00131805310505011F250003] REQ ZW_SEND_DATA Sun 07/22/2018 09:47:20 AM : [ZWAVE ZW024_1] Process value Sensor type=5 scale=0 prec=0 Sun 07/22/2018 09:47:21 AM : [ZWAVE-RX ZW024_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x18 Sun 07/22/2018 09:47:21 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:47:21 AM : [ZWAVE-RD ] [010A001318038003642500C9] REQ ZW_SEND_DATA Sun 07/22/2018 09:47:21 AM : [ZWAVE-RX ZW024_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x18 Sun 07/22/2018 09:47:21 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:47:22 AM : [ZWAVE-RD ] [010D001318063105030A003D250022] REQ ZW_SEND_DATA Sun 07/22/2018 09:47:22 AM : [ZWAVE ZW024_1] Process value Sensor type=3 scale=1 prec=0 Sun 07/22/2018 09:47:22 AM : [ZWAVE-RX ZW024_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x18 Sun 07/22/2018 09:47:22 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:47:22 AM : [ZWAVE-RD ] [010C0013180531051B010025000C] REQ ZW_SEND_DATA Sun 07/22/2018 09:47:22 AM : [ZWAVE ZW024_1] Process value Sensor type=27 scale=0 prec=0 I am also getting a lot of these groups of messages which appear to come from some sensor in the Multisensor 6 but these groups are not qualified, that is they don't seem to have any sensor value associated with them. I see sensor types 1, 5, 3, 27. Does anyone know what these are? Sun 07/22/2018 09:36:51 AM : [ZWAVE-RX ZW023_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x17 Sun 07/22/2018 09:36:51 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:36:52 AM : [ZWAVE-RD ] [010D001317063105012A02DF2500E5] REQ ZW_SEND_DATA Sun 07/22/2018 09:36:52 AM : [ZWAVE ZW023_1] Process value Sensor type=1 scale=1 prec=1 Sun 07/22/2018 09:36:52 AM : [ZWAVE-RX ZW023_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x17 Sun 07/22/2018 09:36:52 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:36:52 AM : [ZWAVE-RD ] [010C00131705310505011C25000F] REQ ZW_SEND_DATA Sun 07/22/2018 09:36:52 AM : [ZWAVE ZW023_1] Process value Sensor type=5 scale=0 prec=0 Sun 07/22/2018 09:36:53 AM : [ZWAVE-RX ZW023_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x17 Sun 07/22/2018 09:36:53 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:36:53 AM : [ZWAVE-RD ] [010A001317038003642500C6] REQ ZW_SEND_DATA Sun 07/22/2018 09:36:53 AM : [ZWAVE-RX ZW023_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x17 Sun 07/22/2018 09:36:53 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:36:53 AM : [ZWAVE-RD ] [010D001317063105030A002A25003A] REQ ZW_SEND_DATA Sun 07/22/2018 09:36:53 AM : [ZWAVE ZW023_1] Process value Sensor type=3 scale=1 prec=0 Sun 07/22/2018 09:36:53 AM : [ZWAVE-RX ZW023_1] [98/40] Security Nonce Get ACK,AUTO,EXPLORE From=0x17 Sun 07/22/2018 09:36:53 AM : [ZWAVE-TX ] ... Sun 07/22/2018 09:36:53 AM : [ZWAVE-RD ] [010C0013170531051B0100250003] REQ ZW_SEND_DATA Sun 07/22/2018 09:36:53 AM : [ZWAVE ZW023_1] Process value Sensor type=27 scale=0 prec=0 In the context of these message, what the 'H' does 'Nonce" mean? Thanks for looking :)
