Envirogreen
Everything posted by Envirogreen
  1. Take my upvote some simple way to update all would be great.
  2. HA has integration using their public api so I know it’s possible. I’d be willing to pay for this in the store. Anyone else that would be willing to pay please post. Maybe that will incentivize someone to build it.
  3. HA has integration so I know it’s possible. I’d be willing to pay for this in the store. Anyone else that would be willing to pay please post. Maybe that will incentivize someone to build it.
  4. Any options for integration with Lennox thermostat??
  5. Any options for integration with Hydrawise?
  6. Anyway to use the Schlage node server for this version of the lock or other integration suggestions?
  7. 1.1.35 fixed sizing and most images are fixed a couple still seem overly large but may be an issue on the image I chose being diff than others. Thanks for the quick fix
  8. Work from home tab but not favorite tab
  9. Camera url from wiki doesn’t work can test when we connect on the 13th
  10. And text widgets are now 1/2 instead of 1/3
  11. Looks like there is now two December’s to a widget instead of 3. Result is a very big top row which could be good but looks strange in current incarnation empty widgets are now two rows where they use to be 1/3 the size of a widget
  12. Camera broken or do I need to delete and recreate? widgets quite a bit larger. What use to fit on one screen now is bigger than a screen.
  13. Envirogreen posted a topic in UD Mobile
    Hi. I’m getting an error when pressing buttons. This is using harmony hub. This particular one is with Apple TV but occurs with other devices as well.
  14. it would really help if the height of a widget could be adjusted just like span. additionally it would be good to be able to put text on multiple lines and to be able to move images to different rows. Eg put image at center of widget no text
  15. This is using 10 wide. Some rows work others don’t. have this on other pages but usually can get it to work
  16. Using the nvr ip + case sensitive + testing with VLC did the trick. Thank you
  17. newest version of app fixes the problem (iOS) thanks @Javi
  18. iOS. Yes same in full screen and portrait or landscape
  19. Hi for one camera I’m getting strange artifacts. Checked in VLC and no such artifact exists
  20. Here’s how I worked around this limitation biggest issue is that the url images change all the time. I’m assuming it’s a defect, annoying but not that big a deal Each remote should have same icon Apple should have the Apple logo hopefully you can understand the issue
  21. Yes that is right had been awhile since needed to do this thank you
