skydvrz
Everything posted by skydvrz
  1. I am using the new web interface with the latest updates to everything. I have a scene with a Z-Wave thermostat (amongst other nodes). The thermostat shows up correctly as "DR Thermostat" an alias for ZW003_1, but there is another Z-Wave device in the scene: ZW010_1 that doesn't match any of my actual devices. If I click on the node in the responders list for the scene, I get a Responder Link dialog showing the scene name and the (bad) responder name of ZW010_1. There is an error message that says: Error: Responder node with address ZW010_1 not found. There seems to be no way to delete the zombie node from the scene. This node does not appear in the list of responder nodes for this scene. I ended up deleting the entire scene and that seemed to fix it. There should be a more surgical way to delete nodes from a scene, whether it exists or not.
  2. Nope. I just switched the notification to Text in the Java console and re-ran it. There was no change in formatting in UD Mobile.
  3. I found that the old Java admin console formats notification UD Mobile text perfectly. It is completely WYSIWYG and updates the new Web UI.
  4. Javi, Thanks for the tip! My Arduino code (ESP8266 actually) is pretty stable, so I haven't had any unexpected disconnects. Currently, upon a disconnect it goes into an infinite wait-loop that is only exited with an ESP8266 power cycle. I will implement an unsubscribe and a reconnect/subscription retry in the next version. I assume you mean that upon a connection loss, I should do an eisy-reconnect, unsubscribe, subscribe - in that order? Keeping track of the old subscription ID shouldn't be a problem. I can packet snoop on udm to see how it does it, if I can catch it resubscribing. I assume it unsubscribes when the app shuts down. Will eisy gaak on an unknown/expired subscription ID if I try to unsubscribe using the one from the previous session? I see 8 or 9 (out of 10) expired subscriptions in udm. Is this an issue?
  5. I have been running my Arduino/Insteon Thermostat code for several days now. The EISY SOAP-subscription code works great! It is way more reliable than my old polling code and seems to be less EISY-cpu intense. Subscription events are very fast. Dozens of Events are sent to my Arduino hardware on initial subscription, but then drop to a reasonable frequency. I filter out any events that do not belong to the Thermostat Node ID I am listening for. I wrote a simple XML parser that grabs the parameters out of the event stream. The reset of the code forms up an Infrared data stream that gets beamed to my AC unit. I can think of many alternate uses for the subscription paradigm so if anyone is interested, I'd be happy to publish my full code. Here is some partial code: // Send the SOAP/Subscribe query (This is part of Setup()) MyLogger(TLogDestinations(ESerial + ETCPIP), EStatus, "Subscribing to EISY"); client.println("POST /services HTTP/1.1"); client.printf("Host: %s\r\n", ISYAddress); client.println("Content-Type: text/xml; charset=utf-8"); client.printf("Authorization: Basic %s\r\n", ISYBasicAuth); client.println("Content-Length: 192"); client.println("SOAPAction: \"urn:udi-com:service:X_Insteon_Lighting_Service:1#Subscribe\"\r\n"); client.println("<s:Envelope><s:Body><u:Subscribe xmlns:u=\"urn:udi-com:service:X_Insteon_Lighting_Service:1\"><reportURL>REUSE_SOCKET</reportURL><duration>infinite</duration></u:Subscribe></s:Body></s:Envelope>\r\n"); String ExtractString(String InString, String BeginMarker, String EndMarker) { int ValueBegin; int ValueEnd; ValueBegin = InString.indexOf(BeginMarker); // try to find the BeginMarker if (ValueBegin >= 0) { ValueBegin += BeginMarker.length(); // move past the marker ValueEnd = InString.indexOf(EndMarker, ValueBegin); // try to find the EndMarker if (ValueEnd >= 0) return InString.substring(ValueBegin, ValueEnd); // Get the string found between the two markers else return ""; // no end marker } else return ""; // no begin marker } // In subscribe mode, each EISY XML line contains a single variable name and value // Something like this: // <?xml version="1.0" encoding="UTF-8"?><Event seqnum="952" sid="uuid:89" timestamp="2025-12-01T13:04:04.212685-05:00"><control>CLISPH</control><action uom="101" prec="0">148</action><node>3C 50 F 1</node><eventInfo></eventInfo><fmtAct>74.0°</fmtAct><fmtName>Heat Setpoint</fmtName></Event>POST reuse HTTP/1.1 void Process() { char NodeBuff[15]; String CurrVal; float fCurrVal; int TempVal; String NodeID = ExtractString(LineBuff, "<node>", "</node>"); // We are looking for the ""hh hh hh 1" node id for an Insteon 2441TH thermostat // Is this the droid we are looking for? if (NodeID.equals(THERMID)) { // Yes: Now get the thermostat varname String Control = ExtractString(LineBuff, "<control>", "</control>"); Control.toCharArray(NodeBuff, sizeof(NodeBuff)); // Now get the var value CurrVal = ExtractString(LineBuff, "<fmtAct>", "</fmtAct>"); CurrVal.toCharArray(NodeBuff, sizeof(NodeBuff) - 1); MyLogger(TLogDestinations(ESerial + ETCPIP), EStatus, "Node Traffic: %s = %s", Control.c_str(), CurrVal.c_str()); // now do something with the Control = CurrVal string pairs . . . . } } void loop() { int bytesRead; // Note: This loops every time we hear an EISY event line of http header/XML. This happens even if the event is not intended for us. while (true) { bytesRead = client.readBytesUntil('\n', LineBuff, sizeof(LineBuff) - 1); // read single line from EISY Subscription stream LineBuff[bytesRead] = '\0'; // overwrite the \n with a string termination Process(); // parse the XML payload, if any. Some lines are blank, contain HTTP Headers or are not intended for us if ((CurrMode != tmAuto) && (ModeChanged && SetpointTempChanged)) { SendIR(); ModeChanged = false; SetpointTempChanged = false; } } }
  6. Yes, my current Arduino software uses /rest/query/<node> but due to system loading issues, this isn't working reliably for me. Is the SOAP API documented somewhere? I tried doing a WSDL import query to get some basic documentation but was not successful. AI searches on Google indicate that the UD SOAP documentation is not up to date. I could not get a REST subscribe/WebSockets session to work. I reverse engineered UD Mobile and see that it is using SOAP to read/update its device screen in real-time. That method works OK for me, but it will be difficult to read the huge stream of data in an Arduino program. I am looking in to using streams and filtering out the node data I don't need.
  7. I can successfully subscribe to all events on my EISY but that is not optimal since I have 100+ nodes. I receive a huge dump (212 kB) of the status of every node when I first connect. I am using a SOAPAction subscribe query to X_Insteon_Lighting_Service like so: POST /services HTTP/1.1 Host: 192.168.0.212 Content-Type: text/xml; charset=utf-8 Authorization: Basic MyPassword== Content-Length: 192 SOAPAction: "urn:udi-com:service:X_Insteon_Lighting_Service:1#Subscribe" <s:Envelope><s:Body><u:Subscribe xmlns:u="urn:udi-com:service:X_Insteon_Lighting_Service:1"><reportURL>REUSE_SOCKET</reportURL><duration>infinite</duration></u:Subscribe></s:Body></s:Envelope> Is there some other EISY service name I can use to receive events from only one node? Is there some parameter I can pass to X_Insteon_Lighting_Service that limits events to a single node (like 3C 80 F 1) Note: I am not talking abou PolyGlot/Portal subscriptions. I intend to subscribe to and parse EISY event text on some local hardware running on the same LAN as the EISY.
  8. Andy, I had the exact opposite problem with polling. I have 3 Arduino boxes (one per HVAC zone in my workshop) each polling my EISY every 10 seconds. My EISY seems to lock up from time to time, apparently from hammering it, 18 times a minute when it has better things to do. I poll frequently since I use Alexa to change HVAC settings and too much lag between voice command and sending the HVAC Infrared signal is annoying. It doesn't lock up if I stop polling. That is why I'd like to do a subscription model, preferably subscribing to a single thermostat node (one per Arduino zone box). Yeah, the initial subscribe connection will be a massive data dump but it should quiet down to just show the occasional node update as time goes on. I built this box that powers a 2441TH Insteon thermostat and creates IR remote control signals for the AC unit. It would also work with any thermostat that can communicate with the EISY.
  9. For the lurkers: I did a bit more research by sniffing the packets generated by UD Mobile that arrive at the EISY network connection. I found that subscribing to EISY events is done using SOAP. UD Mobile starts off by querying the local time on the EISY with a Connection: Keep-Alive. My guess is that this is just a way to get the subscription conversation started since we don't really care what time of day the EISY thinks it is. The red text comes from UD Mobile and the blue text was generated by the EISY. I blacked out my authorization credentials. Now that we have a nailed-up keep-alive connection, UD Mobile subscribes to EISY node events using a SOAPAction call: The EISY replies with a gazillion XML packets that show the status of every node it knows about - in my case, around 100 of them. Last, it sends updates for node values that change. I am currently researching if it is possible to subscribe to a single node instead of doing a core-dump of all my nodes. I don't want to be drinking from the firehose in a tiny Arduino project. I suppose I could filter out all node events that don't match my thermostat node ID.
  10. Yes, I know that a 401 error means there was a failure to authorize. The problem is that I used the same basic authorization on my EISY polling software as I am doing with the attempted REST subscription. Polling works, subscribing to EISY events does not work using the same auth code. Once I get past the auth problem I need an example of subscribing to EISY events using REST. The EISY documentation is not too helpful for this.
  11. I am trying without luck to subscribe to EISY events using an Arduino program. I am trying to follow the SDK manuals examples, but I am apparently doing something wrong such that all attempts to do a rest/subscribe fail with either an error 400 or 401. Attached is a screenshot of a Wireshark capture of Postman trying to connect to the EISY. Any idea of what I am doing wrong? I tried both port 80 and 8080. I want to get things working on Postman before I commit to coding the Arduino REST subscription/event handling. Can someone send me Postman setup params that can launch a subscription session on EISY? Note that I can successfully poll nodes on the EISY using the same credentials and REST, but this causes home automation reliability issues when I poll the EISY too frequently. There will be 3 Arduino systems connected to my ISY, so that is a lot of polling. My Arduino project retrieves thermostat mode/setpoint settings from the EISY and forms binary Infrared signals that it sends to the mini-split air conditioning units in my workshop. They have no human interface other than handheld infrared remote controls.
  12. Clicking the Rachio button in the Plugin Store takes me to a page with no buttons other than a "More Info" button that dumps me into the GitHub repo. What do I need to do to install the latest version and pay? I have a shiny new Rachio all connected to my sprinkler valves and my garden is drying out
  13. Thanks guys! I settled on the Rachio 8-channel unit after many of you suggested it. I got the hardware delivered this morning from Amazon. Now, on to replacing my EISY and all the other fried gear! Photos show my dead EISY/ZMatter/PLM + burn marks from the lightning strike.
  14. My 8-channel EZFlora sprinkler controller was working great with EISY and UD Mobile until it got fried by a nearby lightning strike. It It looks like this module is not made anymore so I need some sort of substitute. What are you guys using for irrigation that integrates with EISY? I don't want yet-another app to control the sprinklers and drip systems.
  15. skydvrz posted a topic in eisy
    A lightning strike took out most of my (complicated) LAN, EISY, PLM, serial cable and Zwave / Matter module. There is a big black scorch mark on my plywood Dmark panel where the serial cable plugs into the EISY. To my horror, the sales page says some of these UD items are out of stock. Is there an ETA date for when this stuff will be back in stock?
  16. This problem may be fixed - I tried every trick in the book and have not seen the "Upgrade to Standard" warning message in a few days. Is there any way to tell which Notification plugin version is active in my EISY or UD Mobile?
  17. Did you install the paid version? I thought so. I originally installed the freebie version and then a day later decided to pay for the added features. Do I need to uninstall first? The paid-up version shows in my Paid plugin list on Polyglot. Each subsection shows "Installed".
  18. There is no HTML in my message bodies; I don't think EISY adds any to the text. The reason for failure was pretty clear - the ISP doesn't like text body lines terminated using Unix/Linux style (or maybe Mac) style line endings.
  19. The fix for this is probably a couple lines of code in the EISY firmware. I'd prefer a fix that does not rely on plugins that may not be compatible with future EISY updates... But I will keep your idea in mind if no EISY patch is forthcoming. I need my SMS-via-SMTP notifications! The EISY SMTP code is a lot better than the old ISY code - at least EISY can navigate modern SMTP security where the ISY died of that years ago.
  20. Does anyone else have problems sending notification messages via certain certain ISPs? I get the following error from tmomail.net (my smartphone provider) when I send a text message via SMTP to my phone: Your message to xxxxxxxxxx@tmomail.net couldn't be delivered. Your message contains invalid characters (bare line feed characters) which the email servers at tmomail.net don't support. kgmccoy Office 365 xxxxxxxxxx Action Required Recipient Bare line feeds unsupported I tried adding additional blank lines to the bottom of each notification message, but that did not help. Maybe EISY is sending LF instead of CRLF for blank lines? Maybe EISY needs to send CRLF instead of LF for every line-end?
  21. Thanks for the offer! I am just going to kill the garden program, since it depended on a weather node server that never worked correctly. I was trying to factor in Evapotranspiration (ETo) to determine how much water to apply and it stopped working when the node changed their API. I need a different node server that provides daily ETo numbers and a rewrite of my program. It ping pongs between ankle deep rain water and 120F dry weather around here, so ETo numbers would be nice
  22. I saw that Program ID 0008 according to the error log seemed to be the problem - low and behold the status of my ID 0008 "Water requirements Midnight" program (adjusts the runtime of my veggie-garden drip system) says "Out of Memory". I will take a closer look at that one or just disable/delete it. I am guessing it went recursive somehow and blows up the stack or heap. So - A big thanks to everyone that chipped in with suggestions - Especially MrBill! P.S. UD could make the error logs a bit more verbose/easier to read in the EISY if they haven't done so already.
  23. I followed MrBill's advice and that seems to have fixed the reboot problem. Woo hoo! Can I simply disable each program individually and then slowly add them back in to find the culprit? I have close to 50 programs running so it is going to be like searching for a needle in a haystack. Here is an excerpt from my log covering some of the reboots: Thu 2022/12/29 15:05:41 System -5 Start Thu 2022/12/29 15:05:47 System -110022 /DEF/F6/I1/NLS/EN_US.TXT Thu 2022/12/29 15:05:49 System -7145 ID 0008 :err=0, tag='/var', num=115, nest=4, of Thu 2022/12/29 15:05:51 System -170001 [Network] Established Thu 2022/12/29 15:09:57 System -5 Start Thu 2022/12/29 15:10:03 System -110022 /DEF/F6/I1/NLS/EN_US.TXT Thu 2022/12/29 15:10:05 System -7145 ID 0008 :err=0, tag='/var', num=115, nest=4, of Thu 2022/12/29 15:10:07 System -170001 [Network] Established Thu 2022/12/29 15:14:13 System -5 Start Thu 2022/12/29 15:14:19 System -110022 /DEF/F6/I1/NLS/EN_US.TXT Thu 2022/12/29 15:14:21 System -7145 ID 0008 :err=0, tag='/var', num=115, nest=4, of Thu 2022/12/29 15:14:23 System -170001 [Network] Established Thu 2022/12/29 15:18:21 System -5 Start Thu 2022/12/29 15:18:27 System -110022 /DEF/F6/I1/NLS/EN_US.TXT Thu 2022/12/29 15:18:29 System -7145 ID 0008 :err=0, tag='/var', num=115, nest=4, of Thu 2022/12/29 15:18:31 System -170001 [Network] Established Thu 2022/12/29 15:22:45 System -5 Start Thu 2022/12/29 15:22:51 System -110022 /DEF/F6/I1/NLS/EN_US.TXT Thu 2022/12/29 15:22:53 System -7145 ID 0008 :err=0, tag='/var', num=115, nest=4, of Thu 2022/12/29 15:22:55 System -170001 [Network] Established
  24. I don't recall changing a program in a while. I have *many* programs so it is a possibility that some variable or switch setting started an unexpected infinite loop. I will check that next. I replaced the ISY's 5V 300 mA power supply with a 5V 1A supply I had laying around. Nope... The replacement power supply didn't help. It is still rebooting. "ISY Connection failed" in the screen shot comes from my Arduino split-AC-Infrared-remote bridge log. I will do a backup of the ISY and then delete all the programs to see if that is the problem.
