TheWabit
Everything posted by TheWabit
  1. I have just come across this thread. I have had this issue since the V3 Alexa skill upgrade AND re-adding the spokens through the portal. I kept getting the repetitive message from Alexa that after Nov 4th this device wont work unless V3 is put in place. Ive been doing trouble shooting by restoring devices, trying to figure out triggers, etc. This morning I removed the device that came on randomly from the the spokens in the portal. Havent had the issue since. I think it is an Alexa thing. Of course I cant use voice in this state.
  2. Great feedback - Thanks! I am sure one of these are the issue. I will start working on it and report back!
  3. Good Evening! Trying to resolve an issue. I have 2 switches operating one light. one is a switchlink, one is an Icon switch and the other is a keypad. All three switches turn on the light just fine but the console will not turn it on with any of the three switches. They click and change to "on" (or "off") but the actual light does not come on. I would like to resolve this so I can use Alexa with it. Any ideas?
  4. TheWabit replied to TheWabit's topic in eisy
    Thank you! I have tried this several times now and it keeps coming up as a Dimmer Switch. The EISY is right next to them so I dont think distance is an issue.
  5. TheWabit posted a topic in eisy
    Good Afternoon Trying to Zwave Bali shades. 1 and 2 connected fine as Zy017-1- Class C Motor Control. Works well with Alexa. the other 2 connect as a Dimmer Switch. Alexa just says "Shade 3 not responding. Any way to force these as a Motor Control?
  6. TheWabit replied to TheWabit's topic in UD Mobile
    That is a fantastic idea! I will try it. Thanks
  7. TheWabit posted a topic in UD Mobile
    So I want to open the garage door when "in-range". I have the old garage door kit from insteon with the sensor. Is there any way that the system can check that the door is already opem (sensor open) and only send the command if it is closed?
  8. TheWabit replied to TheWabit's topic in Ring
    Nevermind. Had to authenti
  9. TheWabit posted a topic in Ring
    Under "Node Servers" (Eisy), "Ring", then "Add all nodes", it wont load anything with ring on the left side. Everything is active in the portal. Any ideas?
  10. TheWabit posted a topic in IoX Support
    I have successfully switched to Eisy. But I am now noticing that often, the programs become disabled. I have to manually re-enable all of them, Is there something that that i am missing that could be causing that?
  11. Got it! Thanks
  12. Real dumb question. I have poking around looking to get the nose servers for Ring and MyQ. Where is the store please? And is the required PG3x there available for purchase?
  13. TheWabit replied to TheWabit's topic in ZMatter
    So just an update to this so that someone else may benefit. All I had to do was to set the upper and lower limit: Connect the Zwave blinds to the Eisy: Add it to the Portal through Alexa. If you select "Device\Set-Lower-Raise", then you are all set. You can set it to 1% - 100% and everything in between with your voice. Nothing in the below has to change. I still dont know what some of those things are but its working the way I want it to. I also have a program for them to come to 50% every morning and close every evening to 0% .
  14. TheWabit replied to TheWabit's topic in ZMatter
    They are Bali shades. Zwave with the new Zmatter attached to Eisy. It worked great with the ISY but that set up looked different. I cant figure out how to set these.
  15. TheWabit posted a topic in ZMatter
    Good Afternoon! Just set up Eisy. Trying to understand the shades. Zwave found them fine. It shows it as a class c motor control. There are different levels of percentages (which I assume is 0% for closed and 100% for full open). I have a program set up to put them at 50% in the morning. But I am not sure how to set up all of these boxes showing percentages and fade rates. Any help would be appreciated. When I select "on" shouldnt it go to 50%?
  16. TheWabit replied to TheWabit's topic in ISY994
    Disregard. I figured it out. I have a fanlinc on that light and didnt have it in the scene.
  17. TheWabit posted a topic in ISY994
    Hello - It has been awhile since I have played with the system, and I have a situation that I cant figure out. I have a 4-way switch (1 KPL and 2 switchlincs). I have them wired correctly - the light works when any one of them are selected. I have them in a scene in the control panel. When I turn on the scene they dont come on. In addition, each item individually selected "on" does not turn the light on either. I am wanting to use the portal to set up Alexa to control them. What am I missing?
  18. DB - Great explanation! it makes sense. Thanks for taking the time.
  19. I see what you are saying. ,,I had the MS as a controller in the scene. I removed it and it seems to work fine. For some reason, I was thinking they both had to be in the scene. Thanks for the help.
  20. Matts Office Lamp - [ID 0005][Parent 0001] If ( From Sunset - 1 hour To Sunrise + 1 hour (next day) ) And Control 'Office Motion Detector-Sensor' is switched On Then Set Scene 'Matts Office Light' On Wait 10 minutes Set Scene 'Matts Office Light' Off Else - No Actions - (To add one, press 'Action') I dont believe the lamp module is directly linked to the motion Sensor
  21. So I gues I lied - I can down this morning, and it is well after 1 hour after sunrise. And the lamp came on. Why is the program not honoring the time limitations?
  22. Thank you all very much! Changing it from "adjust Scene" to "Device" and selecting scene, I was able to get it to work correctly. I hope this helps someone else.
  23. It is in the program correctly. Sorry - I mis-typed. It should have said 1hr after SUNRISE next day
  24. TheWabit posted a topic in ISY994
    I cant figure this one out. Can someone please tell me why this doesnt work? if ( from 1 hour before sunset to 1 hour after sunrise next day ) and Control 'office motion detector - sensor' is switched on Then in scene 'Matts Office Light' Set 'office lamp' 100% wait 10 minutes In scene 'Matts Office Light' Set 'office lamp' 0% It keeps turning on OUTSIDE of those times when motion is detected and "then" doesnt trigger. Thanks for the help
  25. TheWabit posted a topic in ISY994
    I am thinking about an irrigation system installation. Is there a particular controller I need to ask the installers for that will will work with the ISY? I have read about EZFlora - but is that an add on AFTER the controller is installed or that IS the controller? Thanks!
